Deciding between Pro Comp, Ready Lift and BDS kits?
Discussion in 'Suspension' started by XDS, Jun 15, 2017.
  1. Jun 15, 2017 at 10:01 PM
    XDS
    XDS [OP] New Member
    Sam
    Portland Oregon
    Red 2016 Tundra Crewmax
    Hi Tundras!
    So i know theres a million topics on lift kits. I been researching forever now and i have decided to go with either the 4in pro comp lift kit, 4in ready lift kit or should i get the 4.5 BDS? I will be putting 35s on 20 in wheels. Still looking at what kind atm. But any helpful info between those would be great. Or if you suggest something else please lmk. Autoanything.com has the procomp 4 in lift kit for 1729.00 and a 200 dollar mail in rebate, ready lift is about 1000 and BDS is around 2k(more than i kinda wanna spend). I dont do much off roading but would like to have fun on the weekends or whenever i feel up to it. Wanting to lift it very soon here. Thanks!
    Jsena likes this.
  2. Jun 15, 2017 at 10:09 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Just fyi, I tweaked your title a bit to help attract the attn of the folks familiar with your particular choices! :thumbsup:
  3. Jun 16, 2017 at 6:17 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I have a procomp stage 2 6 in and I like it. Just an fyi I believe all 3 of the lifts you're looking at are spindle lifts. So you are going to need a rim with a 5in bs. Other words stock rims won't work unless you use spacers and even then it may be close. 18x9 rim would be a 0mm OS to achieve 5in BS
    Jsena, XDS[OP] and GNTundra like this.
  4. Jun 16, 2017 at 6:19 AM
    No personal experience with any of those, but ProComp I hear has nothing but rough rides.
    Jsena likes this.
  5. Jun 16, 2017 at 6:31 AM
    U want a spacer lift? IMO stay away from..spacer kit is a rough ride not too great for off-roading i came into lift kit scene blind til i got great info on here but it's too late cause my cross member is cut i would avoid a kit that cuts into your cross member cause mine came with a 6" RC kit and my CV axle angles are flexed out that i dont like you wanna keep cv axle angles pretty much horizontal remember these are our opinions its up to you on how or what you gonna do with your ride look at some coil over kits also Check out toytec.com BOSS Kit...post pics of your ride
    Jsena, XDS[OP], GNTundra and 2 others like this.
  6. Jun 16, 2017 at 8:50 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    NO experience with the 4 in but my procomp with coilovers rides better than my buddy's 7in bds with coilovers. Just my $.02
  7. Jun 16, 2017 at 9:14 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    I would stay away from the readylift since its just a spacer lift. Same for rc. Alot of people say they get terrible cv angles on the rc 4 and 6 inch kit.
    If you are going with anything over 3", a drop bracket lift would be better (except for rc) as you keep the stock cv angles. Procomps 4" lift looks like it has good cv angles and bds also, plus with bds, you can upgrade to coilovers leter if you want.
    Jsena and XDS[OP] like this.
  8. Jun 16, 2017 at 1:05 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Same with ProComp
  9. Jun 16, 2017 at 1:26 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    BDS and ProComp are the most popular ones for our trucks. I like ProComp's because, unless they removed it, it comes with support braces behind the bracket to one of the frame crossmembers. However, I went with BDS because it had a skid plate integrated with it. I believe ProComp now offers a skid, too, though.
    Both kits drop the front differential the exact same distance. ICON makes a "large lifted application" coilover stated for ProComp but it works just fine for BDS (I'm running them). It's really just their regular coilover offering for the Tundras but with a integrated spacer at the bottom of the shaft. It's theoretically the same as using the bottom strut spacers that come with the BDS kit.
  10. Jun 16, 2017 at 4:34 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Pro comp stage 2 here. 6". Rides fine. My wife prefers the ride over her escalade.
  11. Jun 20, 2017 at 2:15 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Just researching lifts like usual at 2:13 Am, had a question for all you lift guys... so this particular lift Ready Lift 6 inch or 8 inch comes with 3 inch or 5 inch blocks in rear.. depending on which you get.. it also comes with Bilstien 5125 for Rear shocks. Says it's 3-5 inches in lift.. so what's that really mean?? If you get the upgrad d shocks, are they not using the blocks anymore?? Or does it still use blocks and the 3-5 inch lift Bilsteins ??? :help:
    GNTundra likes this.
  12. Jun 20, 2017 at 3:08 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Both. Block lifts rear. Shock dampens rear. Ideal set up is upgraded shocks and a combo of new leafs and or shackles. Blocks compromise ride some.
    Jsena and Dustydirt19 like this.
  13. Jun 20, 2017 at 9:40 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    ??? So it used both but why is it saying it gives 3-5 inches of lift in rear.. the blocks going to give you 3-5 inches depending on if you get the 6-8 inch lift kit, so you're getting 3-5 inch blocks for rear and you're also getting 3-5 inches with th bilsteins??
  14. Jun 20, 2017 at 10:11 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Rear lift is given by block only. The stocks are just correct length for lift.
    Puud and Jsena like this.
  15. Jun 20, 2017 at 10:29 AM
    renlo
    renlo New Member
    Rene
    What ^^ said. Basically the shocks will work with a rear lift of 3-5".
    GNTundra and Jsena like this.
  16. Jun 20, 2017 at 12:54 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    6 in lift comes with 3 in blocks
    8 in lift comes with 5 in blocks
    Bds 7 in lift comes with 4 in blocks....
    See the pattern :D
    Jsena[QUOTED] and GNTundra like this.
  17. Jun 20, 2017 at 1:39 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea, I was just thrown off by when they say it also has bilsteins rear shocks for 3-5 inches of lift.. I was thinking that's addition to the blocks height.. which its not right???
  18. Jun 20, 2017 at 1:49 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh, he can handle much more than 5"... o_O
  19. Jun 20, 2017 at 1:56 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Correct. 3 in of height is what you'll get with a 3 in block and 5 with 5. Shocks don't lift just give you your squishy feeling
  20. Jun 20, 2017 at 2:41 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Even 5 inches is a bit much for me
    619Tundra, Jsena and GNTundra like this.
  21. Jun 20, 2017 at 3:09 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Lmao
  22. May 12, 2018 at 3:31 PM
    dongkatsu
    dongkatsu New Member
    Dong
    2017 Black Tundra Platinum
    7" bds gone due to issues and switched out the kit to Readylift 6" and up to 7"
    @Spvrtan may I ask for your alignment spec? I have some people having issues with outside wear on tires and would like to see if we can dial as close to as possible to reduce outside wear.
  23. May 12, 2018 at 8:47 PM
    Spvrtan
    Kris
    San Diego, CA
    I'm going to have to try and dig up my alignment sheet later but having Coachbuilder's tie rod ends helps. More importantly, having adjustable UCAs (ie. any aftermarket arm) will allow your alignment tech to adjust the caster for better alignment numbers.
    dongkatsu and Jsena like this.
  24. May 13, 2018 at 8:22 AM
    dongkatsu
    Dong
    Thank you! i'm having outside wear on tires. I got 4th alignment done and seems to work much better than before but having new tires will help more to see if it's wearing better. And yea if you can get the alignment sheet it would be greatly appreciated!!
