Debadging
Discussion in 'Detailing' started by Cpa757va, Oct 9, 2019.
  1. Oct 9, 2019 at 9:45 AM
    Cpa757va
    Cpa757va [OP] New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    I’m curious if anyone has ever seen anything like this after debadging. Only visible in bright, direct sunlight and at certain angles.
  2. Oct 9, 2019 at 9:47 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I debadged a 10 year old truck, and the outline of the badge remains.
    I expect it to be less noticeable after a few years of weathering.
  3. Oct 9, 2019 at 9:47 AM
    Cpa757va
    Chad
    Hampton roads VA
    This is a 2019
  4. Oct 9, 2019 at 9:49 AM
    Rex Kramer
    Georgia
    Wipe it with Goof Off, or some other adhesive remove and wax the area often.
    War Machine and Pudge like this.
  5. Oct 9, 2019 at 9:52 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That is a lot of residue from the adhesive, but also that area is scratched and swirled like crazy. Definitely needs to be clayed and polished out. It looks like whatever was used to attempt to clean off the tape was quite abrasive.
    BravoDeltaRomeo and Rex Kramer like this.
  6. Oct 9, 2019 at 10:06 AM
    Cpa757va
    Chad
    Hampton roads VA
    When I run my fingers across the area it feels very smooth, only reason I’m not so sure it’s residue.
  7. Oct 9, 2019 at 10:11 AM
    Pudge
    CT
    Interesting, try a clay bar and some polish. It could be hard water stains in the clearcoat. Water does tend to get trapped behind those badges
  8. Feb 6, 2020 at 2:52 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    OP did you ever find a solution? Did you use a heat gun? Looks like you may have burned the residue into the paint.
  9. Feb 6, 2020 at 2:56 PM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Rub it with some orange go-jo with pumice. Then wax it.
  10. Feb 7, 2020 at 5:53 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I removed my badges with dental floss and used the 3M eraser wheel to get rid of all the adhesive.
    Damie Street likes this.
  11. Feb 7, 2020 at 6:47 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    By the looks of your paint, I would say you'd benefit from a clay bar/compound/polish/wax. I'd start softer like just a polish, but looks like you may need compound. It almost looks like the adhesive did something to your clearcoat(which seems nuts) for a 2019.
  12. Mar 17, 2020 at 10:44 AM
    D Tundra
    D Tundra New Member
    I've used this in conjunction w dental floss on my BMW's . It worked great every time. Best of luck.
    I just bought a 2020 Platinum and will be using it soon to get rid of chrome emblems for blacked out.
  13. Mar 17, 2020 at 11:36 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    I did the exact thing and then washed and waxed the truck.
    https://youtu.be/1T_E-sVFYdE
    Also may want to check this guy's video out. Useful for me.
  14. Mar 18, 2020 at 7:24 AM
    Pudge
    CT
    :eek2:
    How about no, don't do this. That's so freaking abrasive. Bad advice.
    Newm likes this.
  15. Mar 18, 2020 at 7:35 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    Id hit it with WD40 or goo gone, then rubbing compound and wax.
