Debadging
Discussion in 'Detailing' started by dak13, Jul 11, 2019.
  1. Jul 11, 2019 at 3:29 PM
    dak13
    dak13 [OP] Butt Stuff
    2015 Tundra SR5
    So I decided to debadge my truck and started on one side, but I'm having trouble getting the adhesive residue off.
    What is the best way to get the residual adhesive off without messing anything up?
    Not sure if this is the correct forum to be in for this, but it seems like a good place to start.
  2. Jul 11, 2019 at 3:45 PM
    PotentPotables
    Washington
    If the residue is heated up, you can use a plastic card (credit card, library card, ID etc) to plow the chunks off. Follow up with copious amount of rubbing alcohol on a clean cloth to remove the rest. Once clean, apply some wax and copious amount of ethanol for you.
  3. Jul 11, 2019 at 3:49 PM
    dak13
    2015 Tundra SR5
    It's pretty warm here in San Diego right now. All I used to get the badges off were some 8 lb. test braided fishing line and a bit of Goo-Gone with a plastic card, but it did not get the residue completely off. It's mostly off, but you can still see where the badges once were.
    I'll try some rubbing alcohol, and follow up with some wax.
    Thanks!
  4. Jul 11, 2019 at 3:55 PM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    i used the tubing alcohol and bunch of rags, just don't be tempted to use anything abrasive
  5. Jul 11, 2019 at 4:02 PM
    dak13
    2015 Tundra SR5
    Man, I was totally about to use a brillo pad...
    :sawzall:
    don3032[QUOTED] likes this.
  6. Jul 11, 2019 at 4:02 PM
    War Machine
    War Machine SSEM # 5 3MW
    I used Goo Gone on mine, and it worked perfectly. I did it when it was brand new though, so I don’t know if that made a difference. Possibly a clay bar?
  7. Jul 11, 2019 at 4:03 PM
    dak13
    2015 Tundra SR5
    I was thinking there might be some fading.
    It's MGM.
    jewsNbrews and OR18TRD[QUOTED] like this.
  8. Jul 11, 2019 at 4:05 PM
    dak13
    2015 Tundra SR5
    The adhesive is about 4 years old so it might be a little more stubborn than yours was for sure.
  9. Jul 11, 2019 at 4:07 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    3m eraser wheel works wonders
    Jmad1997, nowayout and War Machine like this.
  10. Jul 11, 2019 at 4:09 PM
    dak13
    2015 Tundra SR5
    Just youtubed it, 15 seconds in..
    That thing looks terrifying.
    War Machine likes this.
  11. Jul 11, 2019 at 4:11 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Little intimidating at first but once you try it you will never go back to goo gone sticky fingers and curse words!
  12. Jul 11, 2019 at 4:11 PM
    War Machine
    I’ve seen that recommended a few times.
    jewsNbrews likes this.
  13. Jul 11, 2019 at 4:13 PM
    dak13
    2015 Tundra SR5
    Solid. I'm going to have to look into this.
  14. Jul 11, 2019 at 4:13 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Soak it in goo gone. Softens the adhesive to come off easier. If really bad, soak paper towel in it and press and hold to area to soak. Clean area afterwards with alcohol. Because its older and you dont want shadow badges showing you'll need to buff the area then wax and polish.
    War Machine, OR18TRD and dak13[OP] like this.
  15. Jul 11, 2019 at 4:19 PM
    Amnesiac
    Amnesiac When I am king, you will be first against the wall
    PDX
    2019 Superwhite TRD Sport
    My truck is pretty much brand new which made it easier, but I did the following. Heated it up with a heat gun, then ran thick gauge fishing line behind the badge to separate from the adhesive. I then heated the leftover adhesive (which was a lot) and slowly picked/rolled it off with my fingers. After that I just wiped down with a microfiber towel and Goo Gone, took the residue right off. Washed the truck and enjoyed the clean look :cool:
    jewsNbrews and OR18TRD like this.
  16. Jul 11, 2019 at 4:22 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Mine was a similar process.
    Step 1 fishing line
    Step 2 eraser wheel
    Step 3 googone leftovers
    Step 4 wax
    Step 5 have fiancee tell me its ugly without badges enough times that I drive to dealership and buy new ones to replace what I removed few days prior
  17. Jul 11, 2019 at 4:24 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :facepalm:should have just got double sided tape and reapplied the badges. Or did you toss them? Cause could sell here or blacked them out as well.
  18. Jul 11, 2019 at 4:32 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Originally purchased black overlays. Broke the tundra badges upon removal tossed 1 5.7 badge wasnt planning on needing it and the other went on wall in garage. Damage was done cant win every time
  19. Jul 11, 2019 at 4:42 PM
    dak13
    2015 Tundra SR5
    It’s hilarious because my wife told me it looks trashy. I told her badges are tacky. The fight continues, but I’ll never win and probably end up with blacked out ones in the future.
  20. Jul 11, 2019 at 4:49 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Makes sense. I removed mine and replaced with black badges, then posted the chrome ones up on freebies for others if they wanted them. Gone same day.
    Getmeacoors[QUOTED] likes this.
  21. Jul 11, 2019 at 4:54 PM
    Professional Hand Model
    Hand Protectors
    Go organic bro. Let nature work its wonders. The essence of badge removal is wetness.
  22. Jul 11, 2019 at 4:55 PM
    ZPMAN
    Minnesota
    If a body shop was to take an emblem off they would most likely use an 3m eraserwheel along with this.
    Screenshot_20180513-233013.jpg You can pick it up at Walmart, Home Depot, Fleet farm and any auto-body supply store for around $20. Also a great cleaner for applying stickers ect and tar removal.
    War Machine and dak13[OP] like this.
  23. Jul 11, 2019 at 8:20 PM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
    Rubbing alcohol and fishing line. Soak behind badge then use line to cut away badge you will have to keep applying alcohol when running the line behind to loosen adhesive.
  24. Jul 11, 2019 at 8:21 PM
    MAK
    MAK Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    This is a great tool to pry the emblems off and to scrape the rubbery padding part of the adhesive off of the paint.
    https://www.amazon.com/Mr-Zogs-Surf...ogs+wax+comb&qid=1562899503&s=gateway&sr=8-11.
    Be sure to take your time scraping that thick crap off before using goo gone. (watch this video. The dude used a plastic spoon! https://www.youtube.com/watch?v=GLnGh3sIUrE ). A heat gun for a few seconds really helps to soften the thick rubbery crap.
    I didn't use fishing line. I actually heated up my emblems for about 15 seconds, waited 20 seconds for the heat to transfer to the adhesive and then heated again. Then I used Mr Zogs wax comb tool to pry off the emblem from the body panel. This method beats the fishing line method hands down. If you heat it well and push the tool between the paint and the adhesive gently but firmly, most of the thick crap coms off with the emblem.
    After I scraped off the thick crap and used goo gone on the thin adhesive residue, I used a microfiber with automotive paint polishing compound to get the paint all shined up.
    I did all 4 emblems in less than an hour with this method.
    dak13[OP] and jewsNbrews like this.
  25. Jul 11, 2019 at 10:45 PM
    dak13
    2015 Tundra SR5
    Braided fishing line worked well for me, had no problems with that or getting the thick adhesive off after. It’s the residue I had issues with, but the rubbing alcohol definitely worked better than Goo-Gone. I still have some shadow emblems going on though.
    I hope buffing and waxing takes care of it.
    OR18TRD and jewsNbrews like this.
  26. Jul 11, 2019 at 11:53 PM
    Jmad1997
    Jmad1997 New Member
    Turtle wax makes a sticker and decal remover in an aerosol can. Works wonders when I remove badges or old vinyl wraps or decals. Can be bought at autozone for about $7. I use the 3M eraser wheel on double sided tape when it is still caked in good then I go back with the turtle wax.
    dak13[QUOTED][OP] likes this.
  27. Jul 12, 2019 at 9:13 AM
    dak13
    2015 Tundra SR5
    update:
    Buffed, polished, and waxed. There is still a shadow of the emblems unfortunately, but it’s better than it used to be. Hopefully it fades out over time.
    Jmad1997 and jewsNbrews like this.
  28. Jul 14, 2019 at 8:41 AM
    chewey46
    chewey46 New Member
    Seattle-ish
    I debadged my truck yesterday and used this 3M adhesive remover. It worked great. Now I need to do a coat of wax.
  29. Jul 14, 2019 at 9:06 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Try some rubbing compound to blend it in. Be careful with it though, it is abrasive. You will need to re polish and wax. Turtle Wax makes it.
  30. Jul 14, 2019 at 9:06 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Ship the badges over this way!
    chewey46[QUOTED] and jewsNbrews like this.
