Dealership vs local shop
Discussion in 'Suspension' started by TeamTakaha, Sep 18, 2021.
  1. Sep 18, 2021 at 10:52 AM
    TeamTakaha
    TeamTakaha [OP] New Member
    Brandon
    2021 Toyota Tundra SR5 Crewmax 4x4
    The lift kit I've been trying to buy, I can't get or order through the dealership. Is it just as good through a local shop like big o tires for a lift kit? Is there any difference? Thanks.
  2. Sep 18, 2021 at 5:37 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    What lift are you going to use? I personally wouldn’t use a tire shop for anything but tires and maybe an alignment. Ive seen enough shoddy work first hand from Les Schwab I can’t recommend a big chain tire shop. I’d look for a local 4 wheel drive shop or see what the dealer can do for you. The other option is see if they will install your parts for you. If you’re just swapping coilovers it’s pretty dang easy to do a driveway install and then have it aligned.
  3. Sep 18, 2021 at 6:18 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Unless it is warranty work nothing goes to the dealer.
    I do most things myself but if I can’t I have a local shop that is cheaper and better than the dealer.
    While I use Big O to mount my tires most of the time they would not be installing my lift if I could not do it myself.
  4. Sep 18, 2021 at 7:03 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I wouldn't order a lift kit through any shop unless they specialize in your truck, otherwise order shit online and then find somewhere thats mildly competent and have them install it.
  5. Sep 19, 2021 at 12:26 PM
    TeamTakaha
    Brandon
    Thanks for all the advice I appreciate it. I was looking at the TRD lift.
  6. Sep 19, 2021 at 1:37 PM
    Black
    Much better stuff for less money out there.
