Dealer's 40k maintenance suggestions aren't listed in the manual
Discussion in '2.5 Gen Tundras (2014-2021)' started by 0331YOTA, Nov 28, 2022.
  1. Nov 28, 2022 at 7:50 AM
    0331YOTA
    0331YOTA [OP] New Member
    2019 SR5 5.7L 4x4
    Ranch Hand rear bumper
    Good morning everyone. I’m approaching the 40K mileage mark on my 2019 Tundra. Last time I had my truck at the dealership for service (35K mileage) they suggested the following services:
    • Brake flush due to prevent moisture buildup in brake system
    • Fuel injector cleaning service
    • Induction service recommended - Top Induction Platinum Service
    I did not see these recommendations until after I got home as the rep at the dealership never mentioned it to me. If anyone has any experience or recommendations it would be much appreciated. I didn’t see these listed in the mileage maintenance reference manual so I figured that I would reach out to y’all. I’m going to start taking care of my own oil changes just for peace of mind.
    Thanks
  2. Nov 28, 2022 at 8:22 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    If it's running fine why would anyone clean injectors. Never flushed or changed brake fluid on any vehicle I've ever owned yet. Induction service, lol. Sounds to me like these guys are bored, broke or both.
  3. Nov 28, 2022 at 8:32 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I unfortunately did the last two services once and did not see really any difference on performance or mpg’s.
    However I did do a brake fluid flush on a 7 year old 2003 Tacoma and the brakes felt significantly better after the service. No other brake work was done during that service. So personally, I would not say that particular service is a waste…quite the opposite in my case.
    ATV25 and LS3 like this.
  4. Nov 28, 2022 at 10:21 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    In my experience, you don’t typically notice a difference in preventative maintenance until you put a lot of miles and/or years on your vehicle. Either it’ll keep running like a top, or you’ll really notice the lack of care then.
    ATV25, Mike59, TheBeast and 4 others like this.
  5. Nov 28, 2022 at 11:41 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    I agree with everything you said.
    Many years ago my family and I had this excellent mechanic. He believed in preventive maintenance but be also believed in the use of quality gasoline and motor oil. On the same 2003 Tacoma the dealership mentioned how clean the intake looked, after the service of course…
    Terndrerrr[QUOTED] likes this.
  6. Nov 28, 2022 at 2:11 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Maybe the brake fluid flush...No for the injector cleaning and induction service.. IMO..
    bfunke, LS3 and Doxiedad like this.
  7. Dec 1, 2022 at 9:20 AM
    0331YOTA
    2019 SR5 5.7L 4x4
    Thanks for the replies everyone.
    @Terndrerrr that’s a great point. Ultimately, I want to balance the proper preventative maintenance to extend the life of this truck as far as possible while not paying for unnecessary service at a high markup from the dealer. I still need to get my headlight recall taken care of
    WILLINH likes this.
  8. Dec 1, 2022 at 7:40 PM
    evanhauer
    evanhauer Snow Chaser
    Erik
    VT
    ‘16 Tundra CM SR5 TRD OR 4x4
    OHwendTrd likes this.
  9. Dec 1, 2022 at 8:07 PM
    mgrs
    mgrs New Member
    '20 OR
    Looks like a maxed out early prius display.
  10. Dec 2, 2022 at 3:56 AM
    Most vehicles made today will not need service beyond oil changes and tires for the first 100k miles. Coolant, spark plugs etc. are long life items in most. Brake fluid is one thing I would do based on time or mileage anyway as it is hygroscopic and will absorb moisture easily. It’s most at risk for contamination in the calipers themselves VS the reservoir. Bleeding the 4 corners occasionally (every 25-40k miles or so) will help prevent corrosion and water intrusion and ABSOLUTELY improve brake performance and component life. Easy $5 job at home with a bottle of appropriate brake fluid and a small wrench or two. A drinking buddy makes the job easier and more funner. One man drip bleeding is ok, but the ol’ pedal pump 2 man method is better at forcing the fluid out with new fluid from the resi and lines.
    Terndrerrr likes this.
  11. Dec 2, 2022 at 5:44 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Under the theory that the current Toyota trucks are at least as good as their older brothers...........my 1997 T100 with 272,000 miles has never had a "fuel injector cleaning service" and it runs today, 25 years later, as good as the day I drove it off the lot. Soooo............there's that.
    NH 2018 Limited and Suprafantx like this.
  12. Dec 3, 2022 at 7:51 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Do the brake fluid at 100k or 5 years/ or really whatever the manual says. Don't do the other two services and save yourself hundreds of dollars.
  13. Dec 3, 2022 at 2:15 PM
    0331YOTA
    2019 SR5 5.7L 4x4
    What OW-20 oil and cartridge filter would y’all recommend ?
    Thanks
  14. Dec 3, 2022 at 2:30 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Costco Kirkland brand oil and Mama Toyota filter (from a dealer, NOT FROM Amazon). I buy my filters for a very fair price (just under $4.00 each) in a box of 10 each, from Joseph Toyota of Cincinnati.
  15. Dec 6, 2022 at 10:39 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I asked a boat mechanic about cleaning the injectors on my Mercury. He said don't worry about unless it is running rough. Out of the 3 the only one I would even consider is the brake fluid flush and then only when I replaced pads. For me that would be at least 100k. I am very easy on brakes even though I tow a 5000 lb boat. Boat trailer has brakes. Dealers make their money selling those services to little old ladies.
    sask3m[QUOTED] likes this.
  16. Dec 6, 2022 at 1:58 PM
    Rocko9999
    Rocko9999 New Member
    I would do zero of those-all money makers for dealer and not required.
    sask3m likes this.
  17. Dec 7, 2022 at 5:12 AM
    agrestic1
    2016 CrewMax
    Presently at 85,000 miles, now I use Mobil 1 High mileage 0W-20, CarQuest { Advance Auto } Premium oil filter....
  18. Dec 7, 2022 at 5:58 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Brake fluid change is reasonable since it's hygroscopic. Induction service and injector cleaning waste of time/money. Use only OEM for filters, gaskets. For electrical use OEM or Denso. Oil - any brand full synthetic 0W-20 or 5W-30. I used Walmart full synthetic either in 5 qt jugs or 12 qt boxes. Your truck needs 8.5 qts. Recommend you buy Motiv filter wrench and drain tool. A lot of folks use the Fomoto valve in place of oil drain plug.
    MGMTundra18 likes this.
