Dealer in DFW area that will install 4.88 gears
Discussion in 'Texas' started by JWS, Sep 7, 2017.
  1. Sep 7, 2017 at 12:24 PM
    JWS
    JWS [OP] New Member
    I'm new to the forum so forgive me if this has already been covered - I haven't waded through previous posts. I traded in my white 2015 tundra pro for a cement 2017 tundra pro and put slightly larger than factory tires on. My gas mileage went down and I feel like I'm pulling a parachute. It has 4.30's, but I think I will need 4.88's. Is there a Toyota dealer in the north Dallas area that someone could recommend to do the work? Thanks in advance!
  2. Sep 7, 2017 at 12:38 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    We recommend heading over to Tandem Automotive in Fort Worth.
    817-633-3225 is their number, shoot them a call and they will gladly help you out!
    Let em know we sent you!:thumbsup:
    -David
    4x4_Angel likes this.
  3. Sep 7, 2017 at 3:11 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Welcome aboard from AZ!
    Curious what other mods do you have planned?
    Also, what size tires did you go to that had this impact on mileage and power?
  4. Sep 7, 2017 at 3:47 PM
    If your gona run 37s or higher yeah switch...if not.. stay stock spend money on other mods...IMO
    JTP likes this.
  5. Sep 8, 2017 at 12:44 PM
    JWS
    JWS [OP] New Member
    Thanks for the replies. I had the cold air box taken off my old 2015 tundra pro and installed on the 2017. I also had LED's installed up front and had it tuned. The factory tire size on the Pro is 275/65-18 (height is 32.1 inches) and I put 275/70-18 (height is 33.2 inches) on the factory wheels. The 2017 truck feels like it has 80-85% the power of my old Pro with stock tires. The old truck got about 15 mpg combined City/Hwy and the new one is getting just over 12. I find it hard to believe that such a small tire size increase made such a difference in performance. If I was confident that new gears would restore the fuel economy and performance, I'd install new gears - just not sure it will help.
  6. Sep 8, 2017 at 4:27 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I wouldn't expect a 1" increase in tire height to warrant a gear change. Must be something else going on. Put it in Tow/Haul-ass mode and see if it appears to give you back your power. Also, at the risk of stating the obvious, make sure you aren't driving around in 4WD.
  7. Sep 8, 2017 at 6:12 PM
    JWS
    JWS [OP] New Member
    An update...I spoke with Keith at Dirty Deeds and now have a better understanding of the problem...just don't ask me to give you the details. He seems confident that the increase in tire size has resulted in an approximate 10% loss of hp and that the 4.88's will restore power and fuel economy. I don't live in the same part of the country so he won't be doing the install. I'll plan to post the results a few hundred miles after the installation. Thanks again for your replies.
    Theonlyway likes this.
  8. Feb 25, 2018 at 6:04 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    So did you get your new 4.88 gears, and did it help? I did the same tire change and I'm really disappointed in the loss of power.
  9. Feb 25, 2018 at 6:13 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  10. May 15, 2018 at 12:10 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    I’m curious also did you end up going with 4.88? I’m thinking I’m going to 315/70/17 and looking at regearing :popcorn:
    @JWS
