Dead Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by tiki dog, Mar 17, 2023.
  1. Mar 17, 2023 at 7:48 PM
    tiki dog
    tiki dog [OP] New Member
    Vernon
    2011 Tundra Crewmax 5.7
    Handicap lift in bed
    Battery is good . Went to start alternator light on check engine light on no engine roll over. Next morning no instrument lights on at all. 2011 crewmax 229000 miles.any ideas?
  2. Mar 17, 2023 at 8:24 PM
    Welcome from NY.
    How many volts is your battery showing?
  3. Mar 17, 2023 at 8:33 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    How did you come to the conclusion the battery is good? Because it sounds pretty dead to me.
  4. Mar 17, 2023 at 11:05 PM
    tiki dog
    Vernon
    12.75 volts
  5. Mar 17, 2023 at 11:12 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    So, did you end up trying to jump it and it still wouldn't start... or did you get that far??
    If you are 100% sure your battery is good, the very next step that I'd try would be to disconnect the negative cable for a short while (at least 10 minutes), then re-connect it and try to start it again....
