Dead front outside turn signal/marker light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Djone27, May 11, 2021.
  1. May 11, 2021 at 5:13 AM
    Djone27
    Djone27 [OP] New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Both of my outside turn signal/marker lights died. I'm thinking since both died at the same time this is most likely a fuse issue. As far as I can tell nothing else is dead. Just seeing if anyone knows what fuse that might be. Wanted to try fuses before pulling the light bulbs out.
    2017 SR5 so no factory LED.
  2. May 11, 2021 at 5:16 AM
    I'm not aware of a fuse just for those. If you put bulbs in and they work that would rule out a fuse. It is just a pain that you have to pull the headlight out to get to them.
    Black Wolf likes this.
  3. May 11, 2021 at 5:19 AM
    One of mine is loose but too lazy to pull the headlight assembly out.
  4. May 11, 2021 at 5:20 AM
    Djone27
    That's the issue. Poor design to pull the grill and headlight assembly to change a bulb. Was hoping to avoid that.
  5. May 11, 2021 at 5:34 AM
    I have a Ranch Hand mounted out front too that's in the way. Not fun just to get to one bulb.
  6. Jun 19, 2021 at 5:52 AM
    Djone27
    So pulled the headlights and both bulbs were toast. These were GTR amber leds. Swapped them out with VLED leds. Not having much faith in GTR anymore. Had these 2 amber bulbs and 2 switchlight blinkers all go bad (which weren't cheap).
