Dead battery after one year?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BRTundra, Jun 29, 2018.
  1. Jun 29, 2018 at 9:52 AM
    BRTundra
    BRTundra [OP] New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    Apparently I had a defective battery and the battery cells failed after only one year of ownership. Had to have my truck towed to my toyota dealership. At least everything was covered under warranty. Is this a common problem?
    Alabama crosby and Coolhardy like this.
  2. Jun 29, 2018 at 9:55 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Why not jump start it and drive it to dealership?
    Clemsonman14, Joe333x, Hoff and 10 others like this.
  3. Jun 29, 2018 at 10:00 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Stock batteries suck. I have always had the stock battery start leaking within a year and go out within 3-5 years.
    UNTMatt, 4x4_Angel and RitcheyRch like this.
  4. Jun 29, 2018 at 10:09 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Batteries are somewhat iffy. Two identical batteries can have completely different life spans.
    Sometimes there are other issues, like alternator not charging as needed. If #2 is short life, need to look at other things.
    Hoff likes this.
  5. Jun 29, 2018 at 10:09 AM
    Trooper2
    JR
    Right, no jumper cables?
  6. Jun 29, 2018 at 10:10 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Tow trucks always have jumper packs or cables
  7. Jun 29, 2018 at 10:25 AM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    I don't believe that is one of the Toyota approved towing methods.
    I keep a spare battery charged and ready to go. I also use it for the electronics and trolling motor on my little boat. Unfortunately, it won't help if I am away from home.
    When they design batteries, they design them so they don't quite make the warranty time. For example, a 60 month battery might be designed to last 55 months. The credit you get is minimal and you have to buy their battery to get it. Planned obsolescence.
    Joe333x, Sas and 15whtrd like this.
  8. Jun 29, 2018 at 10:39 AM
    BRTundra
    Tony
    Baton Rouge, LA.
    I forgot to mention that I did try to jump it. Left it charging for a good 15 minutes and nothing. Battery was completely drained, wouldn't even hold a charge. Had no choice but to call the damn tow truck lol.
  9. Jun 29, 2018 at 10:41 AM
    Professional Hand Model
    Hand Protectors
    Batteries usually last one day longer than warranty! Or, very close to it. One year unacceptable! Marine battery is way to go. $ but worth it. Why you tow your truck? Get some jumpers man.
  10. Jun 29, 2018 at 10:46 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    dead cell. Batteries with dead cells will not jump or take a charge. Usually when they fail prematurely that is reason. I had a Ford battery go bad in 6-9 months. Luckily I had boat with me and used a battery from it. Problem with that year Ford was it required a low profile side mount battery and it died on a Sunday. I had to drive home with hood partially opened. Battery in my 2009 Tacoma did not make it 3 years.
    BRTundra[QUOTED][OP] likes this.
  11. Jun 29, 2018 at 10:52 AM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    My stock battery sucked and would turn over several times in weather near or below freezing even when the truck was new.
  12. Jun 29, 2018 at 11:04 AM
    rds95991
    rds95991 New Member
    That's my backup/boat battery. Completely sealed. Three times the cost of a normal car battery.
  13. Jun 29, 2018 at 11:19 AM
    I finally changed out my 07's battery at 7 yrs even though was still good. Bought a Bosch labeled piece of crap at Pep Boys. After 18 moths got a Yellow Top. I'm thinking those dealer True Starts are crap too!
    BTBAKER likes this.
  14. Jun 29, 2018 at 11:35 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    On the same day in Nov 2014 I bought me a 2015 Civic Si and my wife a 2015 Civic EX-L as new daily drivers. Both batteries died exactly two years to the date of purchase. Drove to the dealer and they installed new batteries in both cars.
    Honda installs a cheap 400 cca battery from the factory and the replacement is 500 cca. You cannot even purchase the battery that is installed from the factory.
    I bought my 2012 Crewmax July 2014 and I had to replace the battery at the end of 2014. Seems factory batteries do not last very long.
  15. Jun 29, 2018 at 12:37 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  16. Jun 29, 2018 at 1:23 PM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Not all that uncommon in Arizona. My battery lasted just about 18 months.
  17. Jun 29, 2018 at 1:40 PM
    These batteries suck. Upgraded mine after a few years when it began to show signs of dying.
  18. Jun 29, 2018 at 4:23 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    yup mine died at year two..swapped it under warranty till i pony up for an optima/northstsar type
  19. Jun 29, 2018 at 5:59 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    So what's the correct north star battery to replace the stock battery on a 2016? Would like to get that group buy!
  20. Jun 29, 2018 at 6:14 PM
    trainracer
    trainracer New Member
    i have a 27f in my 2014
  21. Jun 29, 2018 at 7:43 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    My OEM battery lasted 2 years, My walmart battery has now exceeded that ! lol
  22. Jun 29, 2018 at 7:52 PM
    mazmaz17
    mazmaz17 New Member
    2017 Cement TRD Pro
    IMG_1597.jpg Yup happened to me 2 weeks ago. Tried jumping it also and wouldn't work. Toyota told me I had a dead cell.
    BRTundra[OP] likes this.
  23. Jun 29, 2018 at 8:25 PM
    Aron9000
    Aron9000 New Member
    Aaron
    Had a Lexus brand battery in my old 1992 SC300. That's what it came with in 2012 when I bought it, no idea how old it was. I think the old man who owned that car before me kept it in the garage with a trickle charger on it most of the year(car was 20 years old with 60k miles in 2012). Sold it about a month ago, 105k on it, same battery after 6 years.
    My old 1993 Toyota pickup, I knew the owner, new battery from Autozone a couple months before I bought it. Dead in about 22-26 months and 10k miles. Highly annoying knowing he spent $100+ on that new battery to just not have it last. Lucky me I knew it was going bad, I always parked to where I had a good chance at a clutch pop start, either on a hill, in the back of the lot, not in front of another car.
    My experience is your mileage may vary in terms of battery life. Also keep an eye on the battery terminals for corrision and apply some dielectric grease. For some reason all the Toyotas I've owned have been bad about corroding on the positive battery terminal. That 1993 Truck also had a no start because of corrsion. Bought a Coke out of the vending machine at work, poured it on the battery terminal, chemistry did its thing with the C02, it fired right up.
  24. Jun 29, 2018 at 9:19 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    You got a whole year out of your stock battery. My battery lasted 3 months before it started having problems. If my truck sat for 5 days after charging it to 100% it would not start. I waited for the first maintenance and it was replaced under warranty. I told them i would keep track of this new battery. Can anyone guess how the new battery worked? Everything seemed to be going good and what do you know. At EXACTLY the same 3 months the battery started having problems. On my next scheduled appointment I told them about the battery and I would pass on a new one. They checked the battery and they said it was OK (not). If a battery will not even start your truck after sitting for only 5 days then there is definitely a problem. I will be buying a real battery soon.
  25. Jun 30, 2018 at 1:18 AM
    Twinky
    07 double cab work horse
    The main thing to getting a battery isnt so much the brand (fyi, there are only 4 major battery manufactures in the world). Its about the date it was manufactured compared to the current date. Batteries can sit on a self for a long time, and the worst thing for a battery is for it to just sit doing nothing.
    Home depote sells exide batteries now for around $100 dollars. Thats a really good deal.
    Wallmart batteries actually arent bad at all. Just make sure to take a picture of your receipt.
    For a premium bat., Odyssey is a good choice.
    As for Optima, its a tough call now. Since the plant that makes them is now in mexico the quality control has diminished. It will either last 6-10 years or just a couple.
    As for Northstar, probably the number 1 batteries in the world. If you can afford one, then thats the one. My 2 on my boat where over $900 a piece, but that is specifically for a marine application. A vehical one might only be in the $300+ range.
    Edit:
    Oh yeah, Interstate, Die Hard plat., and Deca(sp?) Are top notch too.
  26. Jun 30, 2018 at 3:56 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Good morning all:sorry: about battery issues
    I have new 18 Tundra only a month old
    Don’t want to have this issue
    Fortunately I have a company vehicle and my boy sits in the garage all week
    I keep a battery tender on my ATV-because it sits and have had 2 replace batteries often- gets expensive!
    U guys think I should buy another battery tender for the Tundra?
    Will it harm any electronics/ computers?
    Think this would cure this issue or it’s just junk batteries?
    Thx:bikewheelie2:
  27. Jun 30, 2018 at 7:04 AM
    UNTMatt
    UNTMatt New Member
    2015 Attitude Black 4x4 Limited
    TRD Pro grille, TRD Pro black badging, TRD Pro shift knob, LED under dash lights, GBS, Llumar ceramic tint, BackFlip HD.
    Heat kills batteries. In any car, truck, or motorcycle I've owned, and with various brands of batteries, I've never had one last much over 4.5 years here in Texas. The only battery that I'll never purchase again is Optima. I probably got a defective one; however, I had the positive post completely melt down the side of the battery completely encasing the terminal in plastic. The battery was less than six months old and was installed on a previous truck I owned. I had run other brands before it and several after before selling that truck with NO issues. When I took the Optima back, the guy behind the counter was a bit taken back and said he had never seen that happen before.
    That being said, our 2015 Tundra battery started leaking at just over a year old. I cleaned up the corrosion, put dielectric grease on the posts, added the felt washers, and sprayed the terminals with battery spray. That protection lasted about two years and two days ago, our 3.25 year old battery died. There was no corrosion on the terminals (they looked clean as new) but there was battery acid under the battery.
    Interstate Battery MT7-34r AGM was the replacement.
    OEM batteries seem to be iffy at best. My wife drives a 2014 Acura MDX and her OEM battery was replaced by the dealer after just over a year due to bad cells. I'm waiting for the replacement to die.
    --Matt
  28. Oct 6, 2018 at 9:45 AM
    like the fish
    like the fish New Member
    David
    4runner, tacoma, now tundra
    Also stung by dead battery...
    My 2017 Tundra TRD Pro, 14 months old, with just 17k miles suffered a battery failure as well.
  29. Oct 6, 2018 at 11:07 AM
    Twinky
    Doesnt the tundra's ecm regulate the alternators output for the purpose of extending our batteries life cycle? If so, its starting to seem like someone with that team of engineers forgot to carry a number or put a decimal point in the wrong place. Lol..
    I know its not funny that ppl are having their batts fail on them. Dont want my "lol" to be taken the wrong way. The possible irony is tragically humorous.
  30. Oct 6, 2018 at 3:16 PM
    Hand Protectors
    Was up at Autozone the other day and asked the guy about the Optima batteries that were sitting behind the counter. He said he has never sold one period in the 5 years time being there. I asked why and he shrugged his shoulders. I then said so those batteries have just been sitting there and he said they cycle them out. This is a high dollar area of living.
    UNTMatt[QUOTED] likes this.
