De-pinning radar cruise connecter
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Apr 13, 2020.
  1. Apr 13, 2020 at 9:11 PM
    Genuine Cooling Systems [OP] New Member Vendor
    Anyone know how to depin the radar cruise connecter that you disconnect from the grill? I made a mistake and broke the clip, the replacement is I'm the mail I just dont know how to de-pin this connector since it's a odd connection and with small holes.
    dcsleeper408 likes this.
  2. Apr 13, 2020 at 9:32 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
  3. Apr 13, 2020 at 9:33 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Pull off the cap. It will expose the pins. Use very small clip or t pin to unlock and you can pull right out.
  4. Apr 13, 2020 at 9:48 PM
    Thanks man!
  5. Apr 16, 2020 at 2:16 PM
    Could you point out where this clip is at. I been messing with my new connector and I cant open it.
    dcsleeper408[QUOTED] likes this.
  6. Apr 16, 2020 at 2:31 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    You should be able to remove the black cap. its either on the sides. Or on the backside.
    once you remove that it will open to slide the terminal pins through the back side.
  7. Apr 16, 2020 at 2:36 PM
    I tried prying it open but it wont budge. I don't want to break it going any further. I didn't know if there was a special way to open the damn thing.
  8. Apr 16, 2020 at 6:27 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Check this video out. Visuals might help you understand better.
    https://youtu.be/znP_uZCak7M
    The tools would make it easier but I use very small t pins. Try not to damage the lock tabs on the terminals.
