De pin help
Discussion in '2.5 Gen Tundras (2014-2021)' started by War_Wagon312, Mar 23, 2019.
  1. Mar 23, 2019 at 7:54 AM
    War_Wagon312
    War_Wagon312 [OP] Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Looking for some help. I tried de pinning the harness for my drl in my 2016 pro. I have shoved safety pins and thumtacs in there bit it won't budge. I popes the pin release up so I figured it owould come right out but the write snapped. I'd like to get it out of there any tricks maybe @iHacker?
  2. Mar 23, 2019 at 8:01 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I'm not sure what you're trying to explain here, but there's a little plastic piece that goes over the pins that has to come out of the connector. Then you can slip in a depinning tool in the tiny tab on the underside of each pin slot on the connector to pull the pin out.
    JohnLakeman and iHacker like this.
  3. Mar 23, 2019 at 8:10 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    ^ Yes like he said, the white connector have some plastic clips under metal pin, you have to separate the plastic clip from pin to release the pin don’t insert the thumbtack or tool in the metal pin.
    Check this video
    https://youtu.be/5Vp4wjDK19I
    Sas likes this.
  4. Mar 23, 2019 at 8:13 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    Try to push the plastic clip with thumbtack or the tool you are using to the outer side
  5. Mar 23, 2019 at 8:14 AM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Trying to remove that snapped wire. Sorry auto correct on my keyboard is insane
  6. Mar 23, 2019 at 8:21 AM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    So I'm sticking the thumb tack in the right side of your picture?what way am I pushing?
  7. Mar 23, 2019 at 8:28 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    Yes I’m the right side
    But first of all you have to lift the lock tab in this picture
    Insert a small screw driver on each side to lift this up
  8. Mar 23, 2019 at 8:29 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    The video shows all this
  9. Mar 23, 2019 at 9:11 AM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Refusing to come out lol
    JPritch likes this.
  10. Mar 23, 2019 at 10:12 AM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Thank you guys for the help. I taped it the best I could and I'll just have to hope for the best.
    Watt maker likes this.
  11. Mar 23, 2019 at 12:24 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The only problem is...the wire that needs to be de-pinned to do the amber delete is a GRAY wire! That wire that you pulled apart, apparently leaving raw strands exposed, appears to have purple color insulation. You sure you were working with the right connector shown in @iHacker amber delete instructions and video?
  12. Mar 23, 2019 at 12:48 PM
    JohnLakeman
    This photo is showing the cavity where the GRAY was installed BEFORE de-pinning. Note that the white wire on one side has a black stripe, and the wire on the other side is light green.
    If you're using a thumb tack, you need place the tack against the outside wall of the hole, and then when you feel the point hit resistance (B), pry the point gently toward to the other side (pry thumb tack point up in photo B) to lift the locking tang (blue) before tugging the wire. See the attached pics from @iHacker thread.
  13. Mar 23, 2019 at 1:09 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
  14. Mar 23, 2019 at 1:19 PM
    JohnLakeman
    True, fifth one in...just be sure you started counting from the correct side.
    You probably would not need to pry up if you were using the tool. When using the thumb tack, the sharp point is going the embed in the tang and there is nothing raising the tang, and you will continue to push harder and harder with nothing happening...UNLESS you pry the point (and the tang) up gently.
  15. Mar 23, 2019 at 1:25 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Ya my camera mad it look purplish. Its grey. You thinkbi can grab one at auto zone or advances auto parts? You know what one it is by chance?
  16. Mar 23, 2019 at 1:32 PM
    JohnLakeman
    Quite possible. If they sell any depin tool it'll probably work. Note that the illustration shows an angle on the end of the tool. if you have the tool turned properly, the tang tends to slide up that angle when you push the tool harder. With a thumb tack, the tang probably isn't going to move unless you gently pry it up.
  17. Mar 23, 2019 at 1:43 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Aye sir. Hopefully I didn't mash it to bits and there's nothing left to lift haha
  18. Mar 23, 2019 at 1:45 PM
    JohnLakeman
    Well, it's still holding that wire stub tenaciously, so you should be fine. :laugh:
  19. Mar 23, 2019 at 1:52 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Hahaha you are 100% correct sir! That thing is in there!
  20. Mar 24, 2019 at 11:02 AM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    3/64 precision screw driver. Because I had already gorilla F@#$ed the terminal, I was able to fit the precision screw driver in there and got it!. Lesson I learned... Buy the proper tool for the job... Thank you again guys. Especially @iHacker I apologise for being a PITA! Your a busy man and I appreciate you taking the time to provide all the pics and video!!... NNNNEEEXXXTTTT!
  21. Jan 8, 2022 at 12:38 PM
    Gav91183
    Gav91183 New Member
    Gerard
    2017 TRD Pro
    I know this is an old thread, but I'm having issues too. Can't get the damn thing out and I'm starting to lose my patience
  22. Jan 8, 2022 at 2:08 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I've seen where the right size paperclip works better than a pin. What are you using?
