De-pin help camshaft sensor socket
Discussion in 'Electrical' started by Dalandshark, Jul 18, 2021.
  1. Jul 18, 2021 at 9:54 AM
    Dalandshark
    Dalandshark [OP] Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    image.jpg Tried a few different pins and needles. Locking clip is out. Wire pin won’t budge.
    This is the socket on the crankshaft position sensor. Wire pulled out of the pin.
  2. Jul 18, 2021 at 10:23 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Hard to see, but insert terminal tool from the plug side and push the tab that is holding the pin towards the long flat side of the connector, then you should be able to remove the pin
  3. Jul 18, 2021 at 10:36 AM
    Dalandshark
    Northwest
    Eibach Level LIft
    Thanks. I just got it out. I also found out can remove the center plastic insert which helps.
