DD SSC2 Sports vs Pro
Discussion in 'Lighting' started by YotaBro, Jan 1, 2022.
  1. Jan 1, 2022 at 4:04 PM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    Lots of shenanigans.
    Are the pros really worth double the amount of money? I would like to purchase some for my bed rack for camp lighting.
  2. Jan 1, 2022 at 4:08 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    No way you need pros for scene lights.
    YotaBro[QUOTED][OP] likes this.
  3. Jan 1, 2022 at 4:10 PM
    YotaBro
    Calvin
    FL
    Have you run either of these?
  4. Jan 1, 2022 at 4:12 PM
    alb1k
    Left Coast
    It's good
    I have the S1 wired and sports in the box. The S1 puts out ridiculous light and is much smaller.
  5. Jan 1, 2022 at 4:13 PM
    alb1k
    Left Coast
    It's good
    Edit: my mistake - you are talking DD, no I haven't...
  6. Jan 1, 2022 at 4:14 PM
    YotaBro
    Calvin
    FL
    Ah, no worries! I still think that the pro may be a bit excessive. I just can't find too much information on the sports
  7. Jan 1, 2022 at 4:19 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    If you’re using the lights for scene lighting you don’t need the pros. Can confirm it would be overkill. :thumbsup:
  8. Jan 1, 2022 at 4:20 PM
    alb1k
    Left Coast
    It's good
    I haven't looked at the lumens side by side, but (2375 lumens) is the BD S1 I have in the hitch and it's gnarly. You don't want to look into it.
    I did just learn the switchpro can dim to 50% and 10%, that's useful.
  9. Jan 1, 2022 at 4:20 PM
    YotaBro
    Calvin
    FL
    Your sale is the reason why I was looking into them more. I was kinda hoping you'd comment. Do you have any pictures of the sports in action?
  10. Jan 1, 2022 at 4:27 PM
    YotaBro
    Calvin
    FL
    @memario1214 Do you know how will I be able to wire the SSC2 to my trigger system? Specifically, it looks like the 3rd wire is meant for the backlight.
  11. Jan 1, 2022 at 4:32 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You can run the backlight on it’s own trigger circuit, tie it into another circuit like parking or cargo lights, or just snip the blue wire and not use it at all (my choice for now).
    Mater and YotaBro[QUOTED][OP] like this.
  12. Jan 1, 2022 at 5:27 PM
    YotaBro
    Calvin
    FL
    Can I connect it to the positive wire on the SSC2?
  13. Jan 1, 2022 at 5:30 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You could, but it wouldn't do anything useful. The high optics would overpower anything the backlight would do. The backlight is pretty low-powered if I remember what I read while doing my install.
  14. Jan 1, 2022 at 5:32 PM
    YotaBro
    Calvin
    FL
    Ok, good to know. Dumb question but is there a good way to combine 4 wires into one? I would prefer not to use a wire nut.
    TRDFerguson[QUOTED] likes this.
  15. Jan 1, 2022 at 5:39 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Crimp connectors are the way to go. There are some with heat shrink tubes built into them and are great for under-hood applications. Please don’t use wire nuts on 12-volt though… @BiggHertz might have a brain aneurysm.
    BiggHertz likes this.
  16. Jan 1, 2022 at 5:48 PM
    YotaBro
    Calvin
    FL
    Something like this?
    https://www.amazon.com/Nilight-Term...imp+connectors+for+wiring+4+way,aps,86&sr=8-3
  17. Jan 1, 2022 at 5:50 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    indeed a crimp using the proper tool and a quality adhesive lined heat shrink is in my opinion the best recipe for a durable termination.
    @YotaBro - what are you trying to accomplish?
  18. Jan 1, 2022 at 5:51 PM
    YotaBro
    Calvin
    FL
    I would like to combine 4 light pods onto one switch on my trigger system. In the past, I have been able to connect 2 light pods onto one but never tried 4.
  19. Jan 1, 2022 at 5:55 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Not much difference there. Just a larger sum conductor cross sectional area. Do you know what size (awg/mm) wire you’re trying to terminate?
  20. Jan 1, 2022 at 5:56 PM
    YotaBro
    Calvin
    FL
    Uhh, I don't know what that means. Mind dumbing it down?
  21. Jan 1, 2022 at 5:57 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  22. Jan 1, 2022 at 5:58 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    AWG - American wire gauge, typical ranges are from 8/0 to 32, where 32 is the smaller end of the spectrum.
    look at the wires sheathing for markings.
  23. Jan 1, 2022 at 6:01 PM
    YotaBro
    Calvin
    FL
    I don't have the light pods with me. Basically, I want to combine 4 of the DD SSC2's into one switch. What is the best way to combine 4 different wires into 1? I was looking online to see if there is a connecter similar to this:
    https://www.amazon.com/gp/product/B07114RK67?ie=UTF8&smid=A31E7B3UFJ5DLK
    But I would like all 4 wires go into one connector to connect to a different wire. Hopefully I am making sense.
  24. Jan 1, 2022 at 6:03 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I tend to use open barrel splices and expensive tooling and heat shrink to make connections, but a humble close barrel but splice like the ones listed below or equivalent should get you what you need.
    Assumption being that the 4 conductors are 16 awg or less.
    250PCS Yellow Heat Shrink Butt Connectors AWG12-10,haisstronica Marine Grade Heat Shrink Wire Connectors,Tinned Red Copper 1mm,Waterproof Insulated Crimp Butt Splice Electrical Connectors https://www.amazon.com/dp/B09B9NP9F4
    TRDFerguson likes this.
  25. Jan 1, 2022 at 6:06 PM
    YotaBro
    Calvin
    FL
    So do I splice the four wires (4 light pods), put it in that connector, and put the last wire (the one that will connect to the switch) on the other end?
  26. Jan 1, 2022 at 6:07 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    correct
  27. Jan 1, 2022 at 6:08 PM
    YotaBro
    Calvin
    FL
    Well, you just made it so much easier. Last time I made it wayyyy more difficult then it needed to be.
  28. Jan 1, 2022 at 6:25 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Note: wire used is 16 AWG Tefzel wire (thinner insulation than most automotive PVC or TXL wire)
    4 into 1 (un-crimped and not sealed) be sure to use crimped designed for insulated terminals
    My connection using open barrel splice and tool (not insulated In this picture)
    Hope this helps.
  29. Jan 1, 2022 at 6:29 PM
    alb1k
    Left Coast
    It's good
    That's very nice. Looks like you may have mocked up a splice to help illustrate?
  30. Jan 1, 2022 at 6:32 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Jason don’t mess around when it comes to this stuff… I’ve learned a lot from his insanity.
    alb1k[QUOTED] likes this.
