DD SS3 question
Discussion in 'Lighting' started by ggg888, Oct 8, 2023.
  1. Oct 8, 2023 at 9:36 AM
    ggg888
    ggg888 [OP] New Member
    2016 Tundra CM MGM Pro
    Planning on replacing OEM fogs on my 2016 Tundra, leaning towards DD SS3 vs the BD Squadron SAE. One thing that concerns though me is the wiggle. Somewhat unacceptable to have to zip tie $300+ fog lights in place so they stop wiggling around (and go in and replace the zip ties every time they break). Eventhough performance-wise the DD is superior for road applications, it could be deal breaker for me. Aware that it's a toyota problem.
    Is it true the BD system has a a more sturdy mounting system?
    Thanks in advance
  2. Oct 8, 2023 at 9:50 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I have BD Squadron Sports for fogs, which mount up the same. The BD install kit has some rubber “shim” material that takes any slack out of the fit. They all mount to a somewhat pliable bumper end cap assembly, so asking for a rock-solid mount is a bit unreasonable.
    That said, I do not notice any wiggle or shimmy with my fog lights. They’ve been fantastic.
    I have no knowledge of Diode Dynamics lighting, but would assume they should mount up similarly. May need a small rubber shim to make a tight fit?
    bulldog93 likes this.
  3. Oct 8, 2023 at 10:12 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    I have the DD's and yeah they wiggle a lot and it's annoying. I did the zip ties for a few times but now uses wire tie and that hasn't broken yet. The output of the DD pros are insane and once I wire tied them up, i've had no issues.
  4. Oct 8, 2023 at 10:39 AM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    I thought the same thing with the zip ties. If it’s made for the tundra, it shouldn’t need them. They are a pain to adjust, so you really want to make sure it’s where you want them before putting everything back together and hope you never have to mess with them again. Huge difference once they are on. I did the SS3 max in Amber.
  5. Oct 8, 2023 at 10:52 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Interesting. No real wiggle with my DDs.
    Have them in my wife’s Suburban as well. The trim bezel could be a little better fitting on the Suburban but a solid mount.
  6. Oct 9, 2023 at 7:35 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    the morimotos i had in before were solid, no movement. the DD def have movement, i could tell when i was mounting them
  7. Oct 9, 2023 at 7:42 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    I went with DD and I thought the same thing. I ended up using zip ties because of the flimsy mount area anyway. The zip ties were really helpful to tighten and align them exactly how I wanted. I really don't have any vibration issues since and they are extremely bright and a good value.
  8. Oct 9, 2023 at 7:46 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    It's all about the fitment of your OEM fog light bezels and very little to do with the aftermarket light. Some have bezels that wiggle more than others. Doesn't seem to have a rhyme or reason for it. BD does have an overall better approach to brackets and such vs DD, though.
    BlueRibbon4x4 and RobertD like this.
  9. Oct 9, 2023 at 7:53 AM
    ggg888
    Thank you everyone for the very informative replies! Very much OEM bezel problem which I have to deal. @TRDFURGUSON brought up a good point and the answer I was looking for.
  10. Oct 11, 2023 at 4:45 AM
    Tundra_1307
    Tundra_1307 New Member
    DD SS3 max here, no wiggle
  11. Oct 11, 2023 at 5:06 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Got the DD3 also ......yea the wiggle
  12. Oct 11, 2023 at 5:33 AM
    PermaFrostTRD
    Northern NY
    Same.
  13. Oct 11, 2023 at 5:42 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    DD's do wiggle. Zip tied appropriately they work fine though. I ran mine for a while on rough terrain, snow, etc. without ever needing to replace zipties. For me its worth the performance even if i have to mess with zip ties. I run a steel bumper now and fabbed mounts so its rock solid.
    PermaFrostTRD likes this.
  14. Oct 11, 2023 at 6:59 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    SS3 Pro Max. On the road, not a whole bunch of wiggle unless the road is real bad. Off-road, they wiggle a lot. It kind of sucks. Because, the light output is really good. They by far are more powerful then my high beams. I rarely even use the high beams.
