DC cigarette power. Any way to make it always on?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Sep 10, 2018.
  1. Sep 10, 2018 at 9:00 AM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    Is there a easy way to my truck run the cigarette lighter always run? Even when the truck is off. I hate that I have to turn my truck on to run anything.
  2. Sep 10, 2018 at 9:07 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    I did this mod for front and rear on my Crewmax. Check out my DIY videos.
    JoshuaA and Sas like this.
  3. Sep 10, 2018 at 10:01 AM
    Erick
    Erick
    Thornton Colorado.
    Okay. I'll look for it. Is it called DIY forum?
    nk1794 likes this.
  4. Sep 10, 2018 at 10:02 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    It's in his sig block but you cant see it from a mobile device. Have to switch to desktop view.
    nk1794 likes this.
  5. Sep 10, 2018 at 10:05 AM
    nk1794
    San Jose, CA
    saybng and PMG like this.
  6. Sep 10, 2018 at 10:52 AM
    nk1794
    San Jose, CA
    I never noticed that. Thanks for pointing that out.
  7. Sep 10, 2018 at 1:39 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I pulled a fused dedicated wire from the battery through the firewall to one of my 12 volt receptacles, while I was pulling a bundle of switch wires. I abandoned the old "switched" + lead and connected my always hot +. Remember if you do this to make sure the old + is well insulated as it will be "hot" whenever the ignition is on.
