DC 10inch Sub and keep under seat storage!
Discussion in 'Audio & Video' started by MTRock, Jan 12, 2021.
  1. Jan 12, 2021 at 8:01 AM
    MTRock
    MTRock [OP] 1889
    Montana
    2024 Tacoma TRD Off Road
    Box build
    13 1/2 inches deep
    27 1/4 inches wide
    5 inches deep
    Cut out for the middle seat belt is 6 1/2 X 6 1/2
    Used 1/2 inch MDF
    Gorilla Glue all joints! And use a lot. The glue should ooze out of ALL seams for a complete seal. Let it cure for 1-2 days before cranking the sub.
    Box Volume is .58 Cubic FT
    Sub must be under 4 1/2 in mounting depth.
    NVX NSW 104V2 Sub is 4.20 inch mounting depth.
    Total cost $200
    Not sure? But should work for 3rd gen also?
    Powered by Boss R1100M mounted underneath the drivers seat, sub is a dual voice coil wired to 2 ohms.
    7FAD3723-BDCB-4A46-AA35-900391A0A980.jpg 4535B60D-9DB8-46B0-9561-47184A6655E9.jpg
    Sound turned out nice! Great for Rock/Heavy Metal/Country.. The Bass is tight and very responsive. But still hits deep.
    Total functional storage loss is 3 1/2 inches x 27 1/4
  2. Jan 12, 2021 at 8:03 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Oh this is mint. Thanks for posting. :)
    Rica25, rons23 and MTRock[QUOTED][OP] like this.
  3. Jan 12, 2021 at 8:10 PM
    MTRock
    MTRock [OP] 1889
    Montana
    You bet neighbor...It’ll make the Goat thump!
  4. Jan 12, 2021 at 8:19 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’ve been wanting to so long.
  5. Jan 12, 2021 at 8:20 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    This is SAAAAWEEET:thumbsup: A great option.
  6. Jan 12, 2021 at 8:35 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Thanks for the post!
    MTRock[OP], Rica25 and Mountun Goat like this.
  7. Jan 24, 2021 at 1:58 PM
    MTRock
    MTRock [OP] 1889
    Montana
    FYI.. Had a few issues with the sub touching the bottom of the seat! Added 2 washers to raise the seat and a heavy duty grille to prevent the seat from touching the sub..
    619Tundra and Mountun Goat like this.
  8. Jan 26, 2021 at 2:36 PM
    MTRock
    MTRock [OP] 1889
    Montana
    Added this grille to keep the seat off the woofer.. look close towards the front you can see the outer ring of the woofer was rubbing on the seat. Is was enough that I noticed better performance after adding the grille.
  9. Feb 18, 2021 at 1:31 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    What did you paint the box with? I’m planning to build one for under the single seat I think, which is where my sub is sitting now but the generic box it’s in is slightly too tall for the seat to go flat
  10. Feb 18, 2021 at 1:40 PM
    MTRock
    MTRock [OP] 1889
    Montana
    Can’t remember the brand? Cheap flat black with texture, it wasn’t enough so I grabbed another can of just flat black.
    The problem I had was seat sags a little more toward the front/middle. You might need a grille so the sub can move freely? Maybe a shallower box? Or raise the rear seat?
    619Tundra and kparrow like this.
  11. Feb 19, 2021 at 7:31 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I currently have the box setup as down-firing to the floor and the box itself has a lip that keeps it about 1/4” off the floor, the box is just too tall, so I need to shorten it’s height and expand width a bit. I also need to make a solid mount for the amp that is sitting under the back seat too.
  12. Feb 19, 2021 at 7:46 PM
    MTRock
    MTRock [OP] 1889
    Montana
    DC sub is kinda a puzzle? I thought about moving my jack and tool to the other side and filling the smaller side with the sub/amp? That way you can have the larger side for storage..
    I see your now from Idaho! Move went well?
    kparrow[QUOTED] and Rica25 like this.
  13. Feb 19, 2021 at 8:13 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I moved my jack and fit my 10” on the small side but I like this idea of using half of the big side. Probably sounds a little better
  14. Feb 20, 2021 at 9:47 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I have that sub in place with the jack and tools in place, small box packed with stuffing so it does the job. It’s a little 8 inch Kicker and works good.
    The move went good, beat the weather by a week! We got out and done with the move before the temp plummeted from 40 to -35! Tell ya the truth I missed it a little bit, but the Treasure Valley got a dump of 12” of snow that they usually are not used to getting, felt right at home, slaloming around all the drivers doing 10mph. Move!!! Montanan here used to driving in snow hahahahahahaha
    Loving the area and new job is going good. House is closing on the 12th of March, can’t wait!
  15. Feb 23, 2021 at 10:18 AM
    tglyder
    tglyder Wise & Heimer
    NW Oregon
    Silver 2010
    Nice! That is exactly where I wanted to place my sub, on small side. I have storage under large side. It didn't occur to me that I could pull my old kicker 8" sub out and build a new box to go under the seat. Then stick the amp under the passenger seat. My truck came with an Alpine single stack stereo which doesn't connect to my phone automatically and the steering wheel controls don't work. I'm hoping it's as simple as getting a new streo with back up cam and reconnect the steering controls. I'm dumb so, Whats the diff in flipping the speaker up or down?
    MTRock[OP] and kparrow like this.
  16. Feb 23, 2021 at 10:45 AM
    MTRock
    MTRock [OP] 1889
    Montana
    No noticeable difference up or down. You just have to make sure the subwoofer has enough room to move back and forth to make sound.
    kparrow likes this.
  17. Feb 26, 2021 at 6:59 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    No real huge difference. I have it down firing to help protect it from above, and to my ear it sounds to have a little bit more “punch” facing the floor that up, but to each it’s personal preference. I can’t remember if I have it setup on reverse polarity or not, again a “play music and see which sounds cleaner and louder and go with that setting” preference.
    MTRock[OP] likes this.
  18. Jun 13, 2021 at 11:08 AM
    MTRock
    MTRock [OP] 1889
    Montana
    Updated the sub..the nvx was decent but not enough! Installed an audiomobile GTS 10inch not cheap $300! but well worth it!! FYI Mounting depth is 4.5in..Bought it from a new local audio shop that does impressive work.. he’s almost got me convinced to bump the box size to 1.0 cubic feet to add another 10 and ditch the cheap boss amp for something bigger and better$$
    https://audiomobile.net/
    TK1979 and 619Tundra like this.
  19. Nov 7, 2022 at 11:07 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Pics?
  20. Nov 8, 2022 at 5:10 PM
    MTRock
    MTRock [OP] 1889
    Montana
    Same box just dropped in the new sub.FYI The nvx required.75 cubic feet. The GTS required.50 cubic feet. The only complaint I have with the GTS is when the temperature gets below 0 it needs to warm up. Not a big deal but probably not a good idea to crank it up before it warms up?
    619Tundra[QUOTED] likes this.
  21. Nov 8, 2022 at 6:37 PM
    619Tundra
    I don't have that problem here in SoCal.
  22. Dec 18, 2022 at 11:49 AM
    619Tundra
    I just bought some Audiomobile Evo 12D4s . I can't wait to hear them.
  23. Dec 18, 2022 at 5:50 PM
    MTRock
    MTRock [OP] 1889
    Montana
    :thumbsup: You building the enclosure?
  24. Dec 18, 2022 at 6:17 PM
    619Tundra
    Yes I am.
  25. Dec 18, 2022 at 6:29 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  26. Dec 22, 2022 at 12:51 PM
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    Does he have specs on his page?
    It's so shallow under that seat and it tapers back too, all I've found premade that works is a ported Skar 6.5
    Edit to add, I feed that little shit 500W at 2 ohms from a Kenwood mono amp and it handles it in stride. Little 6.5 in that ported box rattles the rearview.
  27. Dec 22, 2022 at 1:18 PM
    That Boss amp is dragging you down. You’ll never be happy with that sub until you put a decent amp on it. Boss=trash. They overrate those amps, essentially false advertisement, and they sound horrible. Don’t even have to spend big coin, just buy an amp from a more reputable company. Snatch up a monoblock from Scamazon for under $200
    TK1979 and MTRock[QUOTED][OP] like this.
  28. Jan 5, 2023 at 6:14 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Agreed, but I'd go to James at tech12volts. He'll fix you up really reasonable.
  29. Jan 5, 2023 at 9:21 PM
    MTRock
    MTRock [OP] 1889
    Montana
    Have a local guy.. he sold me an Audio Dynamics in my DD with same sub and it crushes the boss! The boss is getting the boot soon!
  30. Jan 5, 2023 at 9:31 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    James is a huge fan of AD.
    MTRock[QUOTED][OP] likes this.
