Daytime Running Lights
Discussion in '1st Gen Tundras (2000-2006)' started by Dlormand, Oct 26, 2021.
  1. Oct 26, 2021 at 10:58 AM
    Dlormand
    Dlormand [OP] I'm a "Mechanic"
    Dillan
    Louisiana
    05 Tundra 2WD Limited Double Cab
    Flowmaster Flow FX, Kicker Coaxial Door Speakers (All doors), aftermarket Android head unit (unsure of what brand)
    So I have a 2005 Double Cab Tundra Limited 2WD. When I put my headlights on, only the headlight assembly comes on. I've seen on other trucks like mine that both the blinkers and the headlights come on. I'm wondering how can I do that to my truck bc it looks goofy how it is right now
  2. Oct 26, 2021 at 3:23 PM
    shifty` In South Dakota Trouble ain't hard to find
    Just asking, since it's an important question: Have you added any LED bulbs for headlights, foglights, turn signals?
  3. Oct 26, 2021 at 3:47 PM
    Dlormand
    Dillan
    Louisiana
    No I haven't
    shifty` likes this.
  4. Oct 26, 2021 at 9:46 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Do your turn signals work?
    1lowlife likes this.
  5. Oct 26, 2021 at 10:08 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Is the truck new to you?
    Is this something that has always been, or something that recently happened?
    The turn signal bulb should be a 3157A (A for amber).
    It is a 2 filament bulb.
    The turn signal should light up on low with the headlights on as a parking light.
    Make sure it has the right bulb in it..
    As @Toyoda Tundra asked, do the turn signals work with headlights on and/or off?
    Your DRL is in the headlight bulb.
    Its a low power headlight with the head lights off.
    I always unplugged mine, the plug is in between the battery and the side fender.
    There is also a worthless tiny bulb in the headlight assembly.
    Does it come on?
    shifty` and Toyoda Tundra like this.
  6. Oct 26, 2021 at 10:37 PM
    Toyoda Tundra
    . Consider what @1lowlife has stated, as he mentioned, the corner lights use a two filament bulb, 1 for turn signals and one for parking lights. If your turn signals do work but parking lights don’t, then most likely one of the elements is burned out. Inspect the bulbs, if they are in fact burned replacing them should fix that issue. check your fuses as well.
    1lowlife[QUOTED] likes this.
  7. Oct 27, 2021 at 4:24 AM
    Dlormand
    Dillan
    Louisiana
    I'm going to look into all that and fill y'all in I appreciate the help everyone
  8. Oct 27, 2021 at 9:33 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    One more question;
    Are the tail lights working properly?
    Parking lights, turn signals, brake lights?
    Good luck..
  9. Oct 30, 2021 at 7:31 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    In my '06 DC I unplugged the DRL harness like @1lowlife mentioned and leave my headlights on all the time. The door switch on the driver's side B pillar will automatically shut off all the running lights (park front/rear, head, fog) when the truck is off and driver's door opened. I'm not certain if the park lights operate when DRL is operating, in my other truck it just appears as a dim headlight with no other lights operating.
  10. Oct 30, 2021 at 6:07 PM
    Dlormand
    Dillan
    Louisiana
    I changed the bulbs and that seemed to fix it thanks guys
  11. Oct 30, 2021 at 10:17 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    That is great news..
    Glad you got it fixed...:thumbsup:
