Day time lights option..
Discussion in 'Lighting' started by netranger6, Feb 15, 2018.
  1. Feb 15, 2018 at 5:32 AM
    netranger6
    netranger6 [OP] New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    2018 SR5 premium head unit. Under setup/vehicle/light settings Check marking or I'm checking daytime running lights. Can not see any effect of this option. What gives?
  2. Feb 15, 2018 at 7:51 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    On my 2018 I turn the DRL on/off on the headlight switch.
    netranger6[OP] likes this.
  3. Feb 15, 2018 at 8:23 AM
    netranger6
    Jeremy
    Same here. I' talking about the actual option on the head unit in vehicle settings.
  4. Feb 15, 2018 at 9:30 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I just went out and checked my truck. When I uncheck the DRL option they will not come on, I have the JBL head unit (if that makes a difference).
    TTund16 likes this.
  5. Feb 15, 2018 at 5:17 PM
    netranger6
    Jeremy
    I uncheck mine, and they come on when I turn them to eyebrows only, regardless.
  6. Feb 15, 2018 at 5:31 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Are you talking about the lights on the body panel between the bumper and headlight that comes on the TSS package? If so those will be on regardless because that is a dealer regional add on not from the factory.
  7. Feb 15, 2018 at 6:42 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    What kind of DRL do you have? I have LED headlights with the C=clamp surround DRL since mine is a Limited.
  8. Feb 15, 2018 at 8:52 PM
    netranger6
    Jeremy
    None unless I turn it to that position. But it' an option under vehicle setting is set up on head unit.
    18 SR5 Not led
  9. Feb 16, 2018 at 2:39 AM
    TTund16
    TTund16 New Member
    is this for 2018 models? I don't recall seeing this option!
  10. Feb 16, 2018 at 5:27 AM
    netranger6
    Jeremy
    Figured it out. The option makes the led brow in day time running light brighter or dimmer. Cool.
  11. Feb 16, 2018 at 8:48 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Yes, 2018 Limited.
