Dashcam wiring help
Discussion in '2.5 Gen Tundras (2014-2021)' started by artbides, Jan 25, 2021.
  1. Jan 25, 2021 at 6:23 PM
    artbides
    artbides [OP] New Member
    Arthur
    Which wires do I tap into to power my dashcam?
  2. Jan 25, 2021 at 6:27 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Surely your hardwire kit came with some sort of instructions and you have an idea or done some research on which to use? :confused:
    If not, it's probably something you should have professional installed.
  3. Jan 25, 2021 at 6:59 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    KingsAustin likes this.
  4. Jan 27, 2021 at 10:14 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I have been eyeing this adapter, but I was wondering about draining the battery since the mirror is constantly hot?? Had any problems??
  5. Jan 27, 2021 at 10:43 AM
    YotaBro
    Calvin
    FL
    Nope, no issues with mine. It turns off when I turn the engine off.
  6. Jan 27, 2021 at 12:08 PM
    KingsAustin
    Morgan County, AL
    Perfect! I am getting ready to pull the trigger on a dash cam next week. I guess this will be in my cart as well. Thanks for the update!
    YotaBro[QUOTED] likes this.
  7. Jan 27, 2021 at 4:33 PM
    YotaBro
    Calvin
    FL
    Of course! Which one are you going with?
  8. Jan 27, 2021 at 5:15 PM
    KingsAustin
    Morgan County, AL
    Looking at the Aukey duo with the capacitor for our high heat demands.
  9. Jan 27, 2021 at 5:24 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    If you are tapping power at the harness right at the rear view mirror plug, then blue = positive and white with black stripe = negative
    artbides[OP] likes this.
  10. Mar 30, 2022 at 12:02 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    I bought this from your link and it is not compatible, my 2016 tundra has a 14-pin connector and the Amazon part is only a 12-pin connector. Anyone know of one that works with the Tundra? Maybe mine is different because it has the compass and HomeLink buttons?
