Dash Wiring Connector Question
Discussion in 'Audio & Video' started by fdreano, Aug 19, 2018.
  1. Aug 19, 2018 at 7:08 AM
    fdreano
    fdreano [OP] New Member
    2013 Tundra Double Cab
    Kenwood DNX694S Radio, step up bars, wheel flares, bug shield
    I was just wondering if anyone has access to a schematic and could check something for me....
    My dash radio crapped out so I'm putting an upgraded Kenwood GPS/Bluetoot/rear camera/DVD/Apple Carplay unit in the dash...
    In taking the dash panels off I noticed this connector (first pic, far right, 4 pins, two wires) hanging loose behind the AC/heater control panel (second pic).... The only panel options I have are the AUX port (which uses one of the other connectors - already know that one) and everything else has a blank-off plate. I don't think this connector goes to any option I have and was just disconnected but I'm not 100% sure.
    If you have access to Toyota docs maybe you can tell me what it is - maybe an unused connector fog light switch (which I don't have) in that panel or something. I don't want to button things up until I resolve this. No hurry as the radio doesn't come until Tuesday night...
    If you don't have access to the schematic - no problem; I'll go to the dealer if I have to (the local dealer is pretty bad though)...
    Thanks in advance for anything you can do and hope your weekend is going great!
    Its a 2013 double cab without navigation or the JBL factory radio - basically its a work truck...
    THE FIRST IMAGE IS UPSIDE DOWN FOR SOME REASON SO ITS THE FAR LEFT CONNECTOR !!
  2. Aug 19, 2018 at 7:15 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    In my '10 SR5 Crewmax, I have the far right connector not connected to anything. I have the aux & power socket.
  3. Aug 19, 2018 at 8:29 AM
    fdreano
    Thanks - pretty much what I thought.... I looked closely and couldn't find anything that would accept that plug in the vicinity...
  4. Aug 19, 2018 at 8:38 AM
    e30cabrio
    No problem. The blank has space the loose connector will go in so it's not hanging around. (not that it really matters)
