Dash, windshield ticking noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mad Max, Feb 26, 2021.
  1. Feb 26, 2021 at 2:13 PM
    Mad Max
    Mad Max [OP] New Member
    Max
    2021 Tundra Limited
    I have a very slight front of dash / windshield ticking noise. almost sounds like leaf hitting windshields. I thought there was post detailing the solution but cannot find. Does anyone remember the thread? It was a plastic piece or something that was loose. Thanks
    DMart19 likes this.
  2. Feb 26, 2021 at 2:24 PM
    DMart19
    DMart19 New Member
    Dude. I am getting something similar as well. Almost sounds like a plastic piece or maybe a wire tapping up under the dash on certain bumps.
  3. Feb 26, 2021 at 2:32 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If i recall, I think it was something loose up in the rear view mirror area?
  4. Feb 26, 2021 at 2:41 PM
    Mad Max
    Max
    2021 Tundra Limited
    I will check around rear view mirror. It is very soft almost like a pine needle tapping that stuck in a trim piece. Extremely random, i ride down extremely rough road not a sound. thought it was speed related but did it even go 40 mph
  5. Feb 26, 2021 at 2:42 PM
    DMart19
    DMart19 New Member
    Same. Very random
  6. Feb 26, 2021 at 4:47 PM
    Mad Max
    Max
    2021 Tundra Limited
    I went and checked by rear view mirror there is/was a piece of plastic that covers one wire on driver side and it was loose. I don't know if that was the cause yet but when I slid it back up against the headliner and it was much "tighter". I havent gone for a drive.
  7. Feb 26, 2021 at 8:07 PM
    tdiantonio
    tdiantonio New Member
    Also check the A pillar on the passenger side. Check the very top corner where the pillar, windshield and headliner meet. Mine is making some noise from that spot and I think I recall reading in one of the threads that was a trouble spot for noise, etc. with the pillar rubbing against the the top of the windshield.
  8. Feb 26, 2021 at 8:52 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Windshield cowl. Stick a took between the glass and cowl (outside) and see if it’s gone.
    Rdrcr likes this.
  9. Feb 27, 2021 at 1:14 PM
    Mad Max
    Max
    2021 Tundra Limited
    great suggestions!!! I will give it a try!
  10. Mar 18, 2025 at 12:45 PM
    Scotishbuldog
    Scotishbuldog New Member
    2010 TRD DC 5.7
    Parts of a 2007, 2008, 2013, and (3) 2010s .are my ride up
    I have a similar noise. It's a very quiet plastic rubber rubbing noise. What I would describe as low audible like creaking of a rubber wiper across a smooth surface.
    Mine is only Audible 30 mph or less. Predominantly from the right front speaker and a pillar area at the dashboard to Glass interface. Pressing on any of the interior panels doesn't seem to help I remove the a-pillar trim didn't see anything obvious.
    Noise wasn't there before I had the truck painted they took the front windshield out to get the headliner out. My thoughts are an issue with the windshield setting in the urethane or possibly the wiper cowl panel. But the panel looks like it's sitting properly
  11. Mar 20, 2025 at 6:02 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There is a TSB for the windshield locator tab contacting the windshield on the passenger side. It’s a simple matter of bending the locator away from the glass with a plastic trim tool. Do a search.
    Rdrcr likes this.
