Dash rattle after S&B Intake Install
Discussion in 'General Tundra Discussion' started by TexasTundra15, Oct 1, 2018.
  1. Oct 1, 2018 at 6:54 AM
    TexasTundra15
    TexasTundra15 [OP] New Member
    I installed the S&B Cold Air Intake in my 2015 5.7 Tundra a few months ago. Sounds amazing (better than my TRD exhaust), but I now have a rattle in my dash. I removed my aftermarket stereo and felt around inside the dash while having wifey drive and I cannot put my hand on anything rattling. Any ideas?
  2. Oct 1, 2018 at 8:14 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Check the cabin air filter for something stuck in there?
  3. Oct 1, 2018 at 8:19 AM
    TexasTundra15
    I did that and no luck.
    The sound is just to the right of the center of the dash (maybe a few inches to the right of the stereo and up to the mountains ddle of the top of the dash (at least that is where it sounds from the driver seat)
  4. Oct 1, 2018 at 8:21 AM
    Sas
    OKC, OK
    Can you hear it in the engine bay?
  5. Oct 1, 2018 at 8:28 AM
    I have same CAI, no rattle here
  6. Oct 1, 2018 at 8:31 AM
    TexasTundra15
    Hard to say. It only happens on acceleration (not reving in park).
  7. Oct 1, 2018 at 8:32 AM
    TexasTundra15
    Did you put in the rubber side gasket and clear cover on it?
  8. Oct 1, 2018 at 8:33 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Maybe check your center speaker?..
  9. Oct 1, 2018 at 8:36 AM
    TexasTundra15
    I do not have a center speaker. I have felt around the space for the speaker with no luck. Sounds farther down inside the dash.
  10. Oct 1, 2018 at 8:37 AM
    No on side, yes clear
  11. Oct 1, 2018 at 8:39 AM
    saybng
    Gary
    Ventura CA
    Did you collect all your tools after install?..screwdriver may be fell between box?..and rattling against something?.
  12. Oct 1, 2018 at 1:01 PM
    TexasTundra15
    Good idea, though I did not use any tools inside the dash.
  13. Oct 8, 2018 at 9:29 AM
    sandboxjoe
    sandboxjoe New Member
    Joe
    Chandler, AZ
    2018 Cement Crewmax
    A little bit of this... A little bit of that.....
    Is it possible the tabs on the engine cover aren't seated correctly? The ones that hook in closest to the firewall.
