Dash creak/squeak/rattle
Discussion in '2.5 Gen Tundras (2014-2021)' started by MikeyMTBs, Dec 1, 2017.
  1. Dec 1, 2017 at 11:02 AM
    MikeyMTBs
    MikeyMTBs [OP] New Member
    2017 SR5 with 15k on the clock. As the cool weather has come around, my dash has developed the most annoying plastic on plastic creak/squeak that I cannot seem to find. I’ve double checked all the obvious spots to include the glove box and dash speaker covers- even drove around with the covers removed for a few days and no change.
    My Wife thinks it’s behind the radio and I guess the FRAC harness wire stuffing could be rubbing somewhere.
    Before I pull out the stereo, I thought I’d check for other obvious or common areas that creak.
    Thanks
  2. Dec 1, 2017 at 11:03 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Dash and A pillars, need to fix mine.
  3. Dec 2, 2017 at 3:56 AM
    Stig
    Stig New Member
    Same as mine in my 2017. Started with the colder weather, or possibly the frac install. I already checked the frac harness. It's coming from around the glove box/radio.
  4. Dec 2, 2017 at 4:34 AM
    I would say that's probably the culprit...the frac install...I have a 2014 with 48000 miles NO frac install no creaking squeaking noises at all
  5. Dec 2, 2017 at 11:19 AM
    Beaverscott1
    Beaverscott1 New Member
    Scott
    Renton Highlands
    2017 tundra trd pro
    I’ve got the same issue. Passenger side dash area is what it sounds like to me. I’ll be following this thread to hopefully see a fix...
  6. Dec 3, 2017 at 3:03 AM
    MikeyMTBs
    I plan to dig into it more today and see what I can find.
    Beaverscott1 likes this.
  7. Dec 3, 2017 at 4:32 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I have the same but no FRAC installed. It is worse when I’m getting on the gas, pretty sure it’s the a pillar handle panel
  8. Dec 3, 2017 at 7:27 AM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    Same, 2017. Only with colder weather. Seems to be coming from dash/glove box/radio area. Driving me nuts!
  9. Dec 3, 2017 at 4:39 PM
    IrishViking
    IrishViking New Member
    Platinum
    Leveled TRD Dual Exhaust TRD Sway Bar TRD Cold Air Intake Tonneau Cover GTR Lighting LED Headlights GTR Lighting Fog Lights GTR Lighting LED Interior Lighting
    I think I have the same issue. I’ve got a ‘17 Platinum with 7300 km and the rattle I’ve had for the past month or so, sounds very similar to what’s being explained in this thread. This may be an odd question but was is the FRAC that’s being referred to as the possible culprit?
  10. Dec 3, 2017 at 4:43 PM
    dsimonl
    dsimonl New Member
    Sounds like this may be common in '17s. I thumped around a bit today and couldn't isolate it. Too far to lean while driving.
  11. Dec 3, 2017 at 4:44 PM
    dsimonl
    dsimonl New Member
    Oh, FRAC is 'front and rear anytime camera' aftermarket upgrade
    rodm1 and IrishViking like this.
  12. Dec 3, 2017 at 4:49 PM
    IrishViking
    Platinum
    Ah ok, I don’t have one of those. At least I can scratch that off the list!
    RoVASr5 and Eclipsed & Floating like this.
  13. Dec 3, 2017 at 5:22 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Today I made it go away
    I had my son fold a small piece of paper and wedge it under the oh shit handle panel at the bottom to apply pressure. Not sure that was it.....but it stopped
    Tundy Chuck, tbrown, rodm1 and 4 others like this.
  14. Dec 3, 2017 at 5:33 PM
    IrishViking
    Platinum
    Glad to hear you have it fixed
  15. Dec 3, 2017 at 5:35 PM
    dsimonl
    dsimonl New Member
    The handle on the a-pillar or above the passenger door?
  16. Dec 3, 2017 at 6:07 PM
    Eclipsed & Floating
    Voluptuous Whitey
    bottom of the A-Pillar panel by the dash speaker grill. It might not be the answer but it certainly went away today when we rigged it up. I don't like having to "rig" anything inside the cab where you can see it. looks ghetto but if it doesn't happen anymore then i'll figure out a more permanent solution
  17. Dec 3, 2017 at 6:58 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Yup, as I mentioned above.
    I had squeaks from there myself. You can also see where the speaker has actually wore into the a pillar panel a little from dash vibrations.
  18. Dec 3, 2017 at 7:06 PM
    Eclipsed & Floating
    Voluptuous Whitey
    It's really only when i'm giving it a substantial amount of throttle, but yes...same here.
    by the way, you need to wipe that dash down a bit :boink:
    Mine gets the same way and I have to clean the interior regularly
  19. Dec 3, 2017 at 7:10 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I did, small area wiped down...rest to follow :p
    Just got around to finally dping the exterior, interior will be a long project.
    classiccat likes this.
  20. Dec 3, 2017 at 7:12 PM
    Eclipsed & Floating
    Voluptuous Whitey
    :rofl:that's really the only spot you need to wipe down. the rest is fine, as long as that 3" by 1" section is clear
  21. Dec 4, 2017 at 5:31 AM
    Stig
    Stig New Member
    It probably is common to the 17s. My 17 didn't have any noises. My 17 has had 4 in different spots in the interior. I found them all except the passenger side dash rattle. Those that don't hear it should drive with the radio off to see if it's there
    tbrown and jHpowderhound like this.
  22. Dec 4, 2017 at 5:50 AM
    multimile
    multimile New Member
    2020 Crewmax Cement
    Yeah, I’ve noticed the same annoying squeeky sounds when the temp dips. It sounds like it’s coming from that spot on my 17’ as well.
  23. Dec 4, 2017 at 6:39 AM
    MrWrench
    MrWrench New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    I have 21000 on my ‘17 CM and I have a rattle in the driver side door panel coming from the master control switch. The dealership tried putting felt tape around the switch to tighten it up but they only made it worse. It only rattled when it was cold, now it does it constantly.
    NewImprovedRon likes this.
  24. Dec 14, 2017 at 4:30 AM
    MikeyMTBs
    Man, this is making me crazy and it’s getting worse. It isn’t the a-pillar/dash speaker cover in mine - I drove with them out. The glove box is empty. Wife says it sounds like it’s coming from behind the radio, center dash. I guess my next step is to pull the radio and dive around with it out to try to isolate the noise. For me it’s a hard plastic on hard plastic creaking.
  25. Dec 14, 2017 at 4:38 AM
    Stig
    Stig New Member
    Exact same as mine. I might describe it as plastic on plastic tapping in fast succesion. I have some free time coming up I might go at it then.
    wwolvverine and nowayout like this.
  26. Dec 14, 2017 at 4:46 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Not isolated to the 2017, my 2018 has some creaking/thumping noise at times since it got colder. I think it comes from the center console, not very noticeable and it goes away once the interior warms up. I just try to ignore it. Not Toyota specific either as my previous truck (F-150) did it as well. My wife's BMW on the other hand is whisper quiet.
  27. Dec 14, 2017 at 5:17 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    If you have noises from the glove box and its still there with nothing there.....could be the ECM in the firewall.
    Toyota was diagnosing some issues for me, they isolated one to be the ECM bracket. They reinforced it and noise no longer present. I think I have read a few others with the same experience in regards to the ECM making noise.
  28. Dec 14, 2017 at 5:29 AM
    Stig
    Stig New Member
    Most trucks are going to be noisier than a sedan. They are box on frame design and we'll, it's a truck. However they don't have enough to be noisy. My 16 Tundra which got totalled had zero rattles. Something must have changed with the 17s
  29. Dec 14, 2017 at 5:34 AM
    BigTimber
    BigTimber New Member
    Ben
    Casper, WY
    2016 TRD Pro
    my creak on my '16 is from the passenger side dash area. Just sounds like the plastic on the air bag area rubbing where it meets the harder plastic vent/dash area. Happens whether its cold or hot.
  30. Dec 14, 2017 at 6:37 AM
    dsimonl
    dsimonl New Member
    I tried isolating mine over the last week. It is not the A-pillar or headliner. It could be the glove box bottom as mentioned earlier in this thread. It is very noisy when I tap it. trying to shim it seems to have made the rattle worse. Could also be the ECM bracket since I played with that as well
