Dash Cams?
Discussion in 'General Tundra Discussion' started by Silv333, Mar 9, 2019.
  1. Mar 9, 2019 at 11:02 AM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Group, who is currently using a dash cam?
    I am looking at buying one, and was hoping for the following options;
    - Works with an app
    - Dual cameras which records the road as well as in cab
    - Can record in the cab in the event someone breaks into your truck when your truck is parked.
    Anyone use owlcam??
  2. Mar 9, 2019 at 11:23 AM
    hooter
    hooter New Member
    2019 SR5 TRD Off Road Crewmax
    I have a dual cam blackvue dr750s that works for me. The videos are fast to download on the app and look great. It will start recording in the parking mode any time it registers an "event". Someone hitting your car or bumping into it. Mine starts to record when you slam the door shut too hard. The dashcam store sells a 3 camera rideshare version of it that records inside. They have the dr750s-2ch on sale right now for $379. You can get another 10% off if you sign up for their emails.
  3. Mar 9, 2019 at 11:29 AM
    Silv333
    NJ-NC-MD-NC
    How hard was the install? How was it powered?
  4. Mar 9, 2019 at 12:05 PM
    hooter
    hooter New Member
    Install is pretty straight forward and easy. There are a lot of good you tube videos out there on how to install them. I have mine wired through a power magic pro. It's only an extra $20 when you buy one. The power magic pro is wired hot all the time, but you can set the switches on it to cut off the power when the battery voltage gets to a certain level. That way your battery won't go dead. It's simple and works good.
    https://www.thedashcamstore.com/blackvue/
    Sas likes this.
