DASH CAM
Discussion in 'General Tundra Discussion' started by William jinks, May 19, 2025 at 6:23 PM.
  1. May 19, 2025 at 6:23 PM
    William jinks
    William jinks [OP] New Member
    Willie
    None
    Is there a dash cam that you can buy to fit into the Tundra? I have a 2025 model. I want something that's not in your face. I feel a dash cam is important.
  2. May 19, 2025 at 6:32 PM
    Storm4x4
    Storm4x4 New Member
    2022 Tundra SR5 TRD
    I have a Wolfbox x5. Its kind of bulky but it works great and has parking monitoring. No subscriptions or fees. Cheaper option would be Kingslim D4 dash cam.
    William jinks[OP] likes this.
  3. May 19, 2025 at 6:57 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Wolfbox G-900 Pro in my '18 that replaces your rear view mirror
    Latest model has a 3 camera option
  4. May 19, 2025 at 8:57 PM
    William jinks
    Willie
    None
    That's nice but I'm not so sure replacing my rear view mirror and voiding the warranty. It seems Toyota would put a recorder in thier cameras. I mean that's a thought. Right?
  5. May 19, 2025 at 9:01 PM
    William jinks
    Willie
    None
    Do you go under the headliner? I'm curious. I have the big sunroof if so.
  6. May 20, 2025 at 5:37 AM
    TacomaTRD4x402
    Southern California
    Out of the box, these Wolfbox mirror style cams come with straps to allow you to install it over your current rear view so removing the OEM mirror is optional. For your 3rd gen I do believe you have the option to install using the OBDII as your power source so no need to hard wire.
    As for the rear camera, yes I have the wire running alongside the passenger side headliner. There should be no need to remove any pillars. It's mostly just tucking the wiring in.
    Storm4x4 likes this.
