Dash cam power question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stocky Balboa, Oct 9, 2019.
  1. Oct 9, 2019 at 6:39 PM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    I’m looking to add a power source for my dash cam parking “shock” feature. (Starts recording if it senses movement)
    Where did you guys use an add a fuse link?
  2. Oct 9, 2019 at 6:40 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    My cam has a power reserve built in and will come on automatically to record. Yours doesn’t have that?
  3. Oct 9, 2019 at 6:50 PM
    Stocky Balboa
    OC , CA
    It does have an internal battery but they recommend a hard wire kit. Plus it will declutter my console of a plug in
  4. Oct 9, 2019 at 6:54 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I don’t think you need a true add-a-fuse (dedicated fuse) for this application, your dash cam shouldn’t require much power. I’m not sure of where/what exactly what a shock sensor is, but I do have a dash cam in front of my windshield mirror that records while the truck is parked. It’s wired into a power source in the ceiling. I’d assume they tapped into the dome light wiring as I’m pretty sure it’s operational without keys and when you open door (24/7 power), and hopefully they put a fuse in-line on the red wire powering it.
  5. Oct 9, 2019 at 7:12 PM
    Stocky Balboa
    OC , CA
    Thanks. Shock sensor is a built in gimmick that just starts recording if the truck is bumped or detects movement.
  6. Oct 9, 2019 at 7:32 PM
    greener
    greener New Member
    2019 TRD off-road MBM
    I just installed a viofo a129 with hardwire kit. tapped "dome" for constant parking mode, and p/outlet 2 for acc. working great so far.
    Stocky Balboa[OP] likes this.
  7. Oct 9, 2019 at 7:36 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have a Kenwood DRV-410, I hard wired it into the wires inside the upper console, I was able to get both constant and switched power but don't remember the colors.
  8. Oct 9, 2019 at 8:12 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  9. Oct 9, 2019 at 8:53 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    I have a blackvue 2 channel dash cam. I used their hardwire kit. I used the add a fuse and and used the fused panel next to the steering wheel.
