Dash cam install with A-pillar curtain airbags
Discussion in '2.5 Gen Tundras (2014-2021)' started by CStewTAMU, Nov 14, 2021.
  1. Nov 14, 2021 at 8:11 AM
    CStewTAMU
    CStewTAMU [OP] New Member
    Charles
    2021 CrewMax SR5
    I got my 2021 CrewMax SR5 about 6 weeks ago. Previously, I had a 2008 Nissan Titan. When I cleaned out the Titan for my trade in, I uninstalled a few things in its interior to keep. One of them was a dash cam, a Rexing V1 cam. In my Titan, I just plugged it into the cigarette lighter, routed the wire under the passenger side glove box, tucked it into the A-pillar and under the headliner. I used a couple of zip ties along the way. Took 10 minutes to install.
    On my Tundra, I’ve been hesitant to do the same as the A-pillar has these curtain airbags. Any advice? If it’s safe to tuck into the A pillar, which side-windshield of passenger window side? Do
    I have to remove anything or just lessen stuff for access? Should I disconnect the car battery befor installing?
    Any advice would be appreciated. Not looking to hard wire this into the truck, just install it safely.
    Wallygator likes this.
  2. Nov 14, 2021 at 8:23 AM
    Wallygator
    Would something like this work for you instead? Plugs right into the mirror.
    https://www.amazon.com/gp/product/B07DMW3DML?ie=UTF8
    EDIT: just noticed it's "not available". They do come up available, just have to keep an eye on it.
    1UP likes this.
  3. Nov 14, 2021 at 8:26 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    There's plenty of room in the a pillar to route the cable through. Just dont put it directly in front of the airbag.
    It's super easy to remove, one 10mm (I believe) behind the indented oval towards the top and a few clips.
    Alternatively, you can remove the sunglasses holder thing in the headliner and tap into the 12v up there.
    Or, you could grab 12v from the mirror (that's what I did for my radar detector)
    prevent and Occidentalis like this.
  4. Nov 16, 2021 at 8:32 PM
    xeuxaz
    xeuxaz New Member
    2024 MGM Platinum
    This is definitely the way to go. Worked great for my setup!
    1UP and Wallygator[QUOTED] like this.
  5. Nov 28, 2021 at 12:03 PM
    Diesel Fumes
    Diesel Fumes Big Member
    Georgetown, Ontario, Canada
    2021 TRD Sport Premium
    MK4 Backflip, Go Rhino runners, Huskey liners, LED bulbs throughout, Chortau dashcam, decals/badges removed or blacked out.
    Dyeing for these to come available again just to save some time and hassle. Can't find any other suppliers online that build/sell them for a Tundra.
    Wallygator[QUOTED] likes this.
  6. Nov 28, 2021 at 1:02 PM
    Wallygator
    Mine has since acted up on me. The USB plug to the camera is now positional and will not maintain charging the camera while driving. :mad: Not happy. Debating whether to buy another one or hard wire the camera? Currently I have it plugged into a USB port that is installed in the Rago dash plate. Only issue is the wire running from the cam down to the plug. Hardly notice it until I do if that makes any sense. Dang OCD
  7. Nov 28, 2021 at 1:15 PM
    Diesel Fumes
    I hear ya on OCD with the exposed cable....I just can't have that or I would go insane. You're making a good case for me to just hardwire it and be done.
  8. Nov 28, 2021 at 2:36 PM
    Wallygator
    Yeah maybe I got a bad one as I have not heard of anyone here having any issues like I'm having.
  9. Nov 28, 2021 at 2:43 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    No issues with mine. Ordered from their site with the Garmin mini
  10. Nov 28, 2021 at 5:05 PM
    Mine is down the passenger side. Plenty of room to keep it away from the airbag and the yellow wire. IIRC, there's a harness that mine is zip tied too.
  11. Jan 2, 2022 at 3:00 PM
    wsutundra
    wsutundra 2021 Smoked Mesquite 1794
    This wont drain the battery?
  12. Jan 2, 2022 at 4:06 PM
    Wallygator
    Only works when the ignition is on.
  13. Jan 2, 2022 at 4:42 PM
    wsutundra
    And will this device enable parking mode? I know most cameras will not have parking mode unless hard wired
  14. Jan 2, 2022 at 4:46 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    There’s plenty of space to tuck another wire in the clips that hold the existing harness above the side curtain airbag.
    Wallygator and Patch999 like this.
  15. Jan 2, 2022 at 6:28 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Open it up. You’ll see there’s plenty of room to run the cable. Don’t waste your money on an adapter.
  16. Jan 2, 2022 at 7:00 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    If you want it on all the time I’d run it down the driver side since it’s a shorter and easier run to the fuse box
  17. Jan 3, 2022 at 7:03 AM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    As another option, a wire tap to the back of the rear view mirror works well. I did that with my Escort 9500ix radar detector AND Mobius dash cam. I used a 12v to 5v step down for the Mobius.
    Remember to double check voltage of any device you want to power. The rear view mirror is 12v. If you piggyback devices you’ll probably need a RF deflector between the devices.
  18. Jan 3, 2022 at 11:22 AM
    Wallygator
    Nah, has to be hard wired for parking mode
