Dash cam install issue
Discussion in '2nd Gen Tundras (2007-2013)' started by VikNewco, Oct 21, 2024.
  1. Oct 21, 2024 at 8:44 AM
    VikNewco
    VikNewco [OP] New Member
    Toyota Tundra
    New member. My husband went to Best Buy to have a dash cam installed well needless to say he is not sure what they may have attached or cut but now his truck will not start. What could have caused this besides the obvious of using Best Buy!!
  2. Oct 21, 2024 at 8:46 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    They tapped into the ignition circuit. The fuse box is under the hood. Start there. Make sure you have the tech
    from Best Buy there to show what he did. He may have forgotten to install the fuse back. I'm suspecting the camera uses a fuse jumper and that's where the problem is most likely. BTW does the camera come on with the key, without starting the truck?
    D4x4TRD likes this.
  3. Oct 21, 2024 at 9:32 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    I have nothing to add. Sorry. But I’m definitely watching this thread to see what the cause is. Good luck and I hope it’s nothing major.:popcorn:
  4. Oct 21, 2024 at 10:29 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I'm thinking stupidity on the part of a best buy person.
    D4x4TRD[QUOTED] likes this.
  5. Oct 21, 2024 at 10:32 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    Seems very possible to blame the Best Buy tech. But I definitely need more info. Like what year truck the tundra is. The newer the model the more electronics to mess up.
  6. Oct 21, 2024 at 10:36 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I'm used to dash cams being stand alone. Things get a bit vague when they integrate into existing systems. Why I usually
    have degrees of separation on my rigs.
  7. Oct 21, 2024 at 12:40 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    All we know is a Best Buy. No idea where the initial OP is from
  8. Oct 21, 2024 at 5:53 PM
    VikNewco
    Toyota Tundra
    After market alarm was installed which was stripped so another wire that he installed made contact with that wire causing the problem.
    D4x4TRD and Cruiserpilot like this.
  9. Oct 21, 2024 at 6:29 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
  10. Oct 22, 2024 at 4:25 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    So it was simple thank goodness. Still a blundering Best Buy tech. Glad things weren’t so detrimental.
