Dash Button Extension Harnesses
Discussion in 'Electrical' started by HulkSmurf14, Apr 14, 2025.
  1. Apr 14, 2025 at 2:34 PM
    HulkSmurf14
    HulkSmurf14 [OP] ...Weighted Average...
    2014 Tundra Limited
    Tastefully enhanced...
    I'd like to move my Parking Sensor On/Off switch above my right knee to below my climate controls in the center console area...is there an extension harness I can buy that makes this look less like a homemade radio? What about the traction control switch, also? Anything like this exist?
    Saltyhero13 likes this.
  2. Apr 21, 2025 at 3:03 PM
    HulkSmurf14
    2014 Tundra Limited
    Does anyone know if anyone would make such a harness? Having my BSM disable switch lower, and in a "not used as much" location would be most functional for my lighting switch considerations...Anyone have any thoughts?
  3. Apr 24, 2025 at 9:39 AM
    HulkSmurf14
    2014 Tundra Limited
    Bump...they make rear window harness extensions, but not for anything else? I'd like to thro wmy taction control switch down lower too if that's a possibility...BANZA!!
  4. Apr 24, 2025 at 11:08 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Cut, crimp, heat gun, ???, profit
  5. Apr 24, 2025 at 11:36 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    as far as I've seen no one makes them for those buttons, I have seen for speedo light dial. Just get the proper heat shrink butt connectors and a good crimper and cut the connectors off, add extra wire, and attach the connectors back on. Make sure to leave room on either side of your first cut for the butt connector.
  6. Apr 24, 2025 at 12:02 PM
    HulkSmurf14
    2014 Tundra Limited
    Yeah, that's the likely easiest approach...I like being able to
    "go back" if needed to help troubleshoot if an issue arises...granted, this isn't a terrible thing to figure out...good call, I'll just extend myself.
  7. Apr 24, 2025 at 12:04 PM
    HulkSmurf14
    2014 Tundra Limited
    Thanks for the response! Makes sense to do myself and yes, cut once and measure twice, as they say, right?! I'll leave as long of extensions on the original harnesses to ensure I have room in case my hands of thumbs decide to work against my eyes! :spy:
    joseph_womack[QUOTED] likes this.
  8. Apr 24, 2025 at 1:28 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
  9. Apr 24, 2025 at 1:33 PM
    HulkSmurf14
    2014 Tundra Limited
    Thank you! :muscleflexing:
    When I didn't want to do it myself and I re-read what I was asking, man, that's what a wet fart sounds like! Ha! I'm very capable of doing it.myself and if anything, it'll be bespoke to what I'm wanting. Thanks for everyone's suggestions, links and prodding! :boink:
    BlueRibbon4x4 likes this.
  10. Apr 24, 2025 at 3:16 PM
    biebs96
    PA
    I moved a bunches of switches around.
    Ethernet cable works well. It’s similar gauge and all the wires are color coded inside. Just match them up on each side.
    HulkSmurf14[OP] likes this.
  11. Apr 24, 2025 at 3:19 PM
    HulkSmurf14
    2014 Tundra Limited
    Awesome!! Thank you!!
  12. Apr 24, 2025 at 3:58 PM
    biebs96
    PA
