Damaged copper housing replacing dome LED’s
Discussion in 'Lighting' started by dez nuttz, Jul 22, 2018.
  1. Jul 22, 2018 at 8:38 PM
    dez nuttz
    dez nuttz [OP] New Member
    Yan
    18 tundra
    Changed the dome lights to led and copper housing is damaged and now won’t work any one else have the same problem and how to fi
  2. Jul 22, 2018 at 8:49 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Sounds like you blew a fuse.
    Check the fuses.
    If you blew a fuse I would fix any damage, install the old bulbs, put in new fuse. See what happens.
  3. Jul 22, 2018 at 9:15 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Fuses first. If good, use a pry tool and remove the cover in front of the sunglasses holder, unscrew 3 torx screws so the whole bulk head comes off, check that the copper strips are intact. Examine Dorman 924-798. Order a new one if you broke it by mistake fiddling with the copper.
    Runnerstrom28 likes this.
