DA polishing pads
Discussion in 'Detailing' started by Pudge, Aug 28, 2018.
  1. Aug 28, 2018 at 1:07 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    Posting this so everyone can see the input that guys have to share.
    I have lake country hdo orange polishing pads. These seems to be fairly versatile for my use. Question is should I have more colors for different grades of "cutting"?
    Should I have a cutting, polishing, finishing, waxing?
    I don't have deep scratches and think I can get away with megs 205, but might need 105 at some point. And I also may want to use a glaze at some point between polish and sealant.
    Do the pads really make that much of a difference? Or is it more of the product you apply with the pads. I'm all for buying quality stuff that will last. But would I be wasting product such as a compound or glaze by using it with an orange pad?
    Let's here what the experts and novices have to say. This is such a great detailing crew. When I was I. Tacomaworld I never checked out the detailing forum but I think I visit this one more than others here at tundras.com
    Thanks everyone
  2. Aug 28, 2018 at 1:08 PM
    Pudge
    CT
    Sas likes this.
  3. Aug 28, 2018 at 1:12 PM
    I have a wide variety of different color pads by Lake County but I use there CCS pads. I personally never use a cutting pad to wax and vise versa don't use a wax pad to cut.
    Pudge[OP] likes this.
  4. Aug 28, 2018 at 1:15 PM
    Pudge
    CT
    I have 3 orange hdo pads and 2 orange ccs pads. No other colors. But may get some finishing pads or cutting pads based on what I find here.
  5. Aug 28, 2018 at 1:34 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I have a number of different pads for different tasks. Even have several different cutting pads for the various grits of cutting compound I use.
  6. Aug 28, 2018 at 2:12 PM
    Pudge
    CT
    SouthBoundSteve likes this.
  7. Aug 28, 2018 at 2:28 PM
    Sky's the Limit Car Care
    Sky's the Limit Car Care New Member
    James
    All Vehicles
    Sky’s the Limit Car Care 309 Altamonte Commerce Blvd. Suite 1506 | Central Florida 386-259-0759 | service@carpro-us.com
    The hard part about pads is that there is no clear cut way or formula that one can can just plug in a pad and a compound and have a secure result. all pads are so different and different pads react with pads in different ways. In reference to your exact question Pudge, the product or compound that you use will have a large affect on the vehicle than the pad will, BUT, not by much. There are so many combinations of pads and compounds out there that can wield you different results or the same results if you were to try another combination. Overall though we suggest using pads for the suggested purpose for the best results. this can assure consistency and allow results for the desired affect.
    Long story short, I can say for sure if you use that polishing pad with the meg 105 you wont get the same results you would with a pad more suitable for cutting. If you are at a point in which you are going to be cutting, then I would go ahead and grab a cutting pad for that purpose.
    In regards to the 205, that one should be ok, but it may give more cut than you need though. I haven't used that combo for sure to know.
    Ill run it by corey and see what he says though.
    Hope this gives some insight.
  8. Aug 28, 2018 at 2:50 PM
    Pudge
    CT
    Thanks so much. This is exactly why I posted this!
  9. Aug 28, 2018 at 8:45 PM
    Pudge
    CT
    I decided to grab a couple lake country hdo black finishing pads on ebay with their 15% coupon. I'll be testing the orange hdo and black hdo pads with 205 soon. Reading up about the 205 I think I can get come cut with the orange pads, and its versatile enough to also get some good finish by changing to a black pad.
    If I need more cut at some point I'll look into 105 with more of a cutting pad. I'm not sure I wanna get into more cutting that I achieve with 205 and an orange pad though. We'll see
  10. Aug 29, 2018 at 7:07 AM
    War Machine
    War Machine SSEM # 5 3MW
    @Pudge I’ll be following this thread so I can learn the same things you are.
    I have almost no experience with doing this yet. I’ve acquired quite a bit of products, but outside of just playing around with a few panels here and there, I haven’t done much. I have yet to do a whole vehicle. I was able to get some pretty good scratches out of my wife’s truck though using cheap black pads and Meguair’s Scratch X 2.0.
    Luckily I haven’t paid actual money for much of it. I have blown a good bit of Amazon gift cards on it though. I started collecting stuff to get ready to apply CQuartz to my truck, but time and weather have kept it from happening the last few months. I don’t have a garage big enough to hold any of my vehicles, unless I take them to my workplace. I can do that, but I haven’t had enough time.
    I have way more products than I’ll likely need for anything. I have several colors and brands of pads, and probably a dozen different compounds and polishes sitting there being wasted. I’m hoping that I can really get going on this once it cools off outside.
    I’m also keeping my eye out for some junk fenders or hoods people have. I’d like to get some pieces I can put in my garage to practice on.
    Bones2012 and Pudge[OP] like this.
  11. Aug 29, 2018 at 7:24 AM
    Pudge
    CT
    I'm with ya Jason. I used megs ultimate polish on my truck last month and was semi happy with the results. I used lake country ccs orange pads. I still see some scratches and swirls that I really think I should be able to get out with the right combo of polish and pads. I may need a heavier compound such as meg's 105 which I'm open to trying.
    I have just been reading that meg's 205 may be versatile enough to get a slightly heavier cut with the LC hdo orange, and also a light polish/jeweling with the LC hdo black. But have not tried it out yet. Obviously the amount of product, pressure, and technique have a lot to do with it, which is why I need practice and insight.
    @SouthBoundSteve have you found that this is possible or am I way off here?
  12. Aug 29, 2018 at 12:54 PM
    War Machine
    25 minutes? That’s not long at all.
    Pudge[OP] and SouthBoundSteve like this.
  13. Aug 29, 2018 at 1:14 PM
    War Machine
    Here’s a decent pic of my paint with the sun hitting it. The marks aren’t generally visible, but I see them in the sunlight. What type of pad / product would you guys recommend?
  14. Aug 29, 2018 at 1:25 PM
    Pudge
    CT
    That's what mine looked like, kinda spiderwebby, I used megs ultimate polish and an orange LC ccs pad. It did just ok but did make a significant improvement. Next time I'm gonna use LC hdo orange and then black pads with megs 205.
  15. Aug 29, 2018 at 2:14 PM
    Pudge
    CT
    Damn it Steve now I wanna buy and try that with my black pads after I use the 205 with orange lol.
    And you've been right all along..... Once I get this paint corrected and shined up....I will coat it. Might take me a year of trial and error as far as paint correction. But some day I'll get it to where I can coat it
  16. Aug 30, 2018 at 4:06 AM
    War Machine
    I have Essence, so I’ll try that. I also have Carpro Clear Cut and Reflect, along with a couple of Maguiar’s, and a bunch of CG stuff that came with my polisher.
  17. Aug 30, 2018 at 5:03 AM
    War Machine
    Here’s to hoping I get to actually use all this stuff I have at some point.
  18. Sep 15, 2018 at 7:32 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    What scratch and swirl polisher do you guys like best. Just started using V36 from CG, with a orange pad. Haven't tried VSS yet, has anyone tried it? Should I get a different product?
  19. Sep 15, 2018 at 8:37 PM
    Bones2012
    Bones2012 2012 CM
    Windy City
    2012 Black Crewmax
    Step Tubes BakFlip VP Dee Zee Bed and Tail gate mats Pop A Lock tailgate lock Smitty Built M1 Rear Bumper Weather Tech mats Interior LEDS Remote control Bed Lights Cabelas seat covers
    I stopped at a body shop and they gave me a trunk lid to practice on. all they ask was to bring it back when I was finished. They just sell the parts for scrap.
  20. Sep 15, 2018 at 9:00 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That's pretty cool. What color is it? How bad is the paint. I'm interested!
  21. Sep 16, 2018 at 3:56 AM
    War Machine
    Cool. I’ll check with a couple. My old neighbor works at one. Too bad I wasn’t into this when I lived there.
  22. Sep 17, 2018 at 4:51 AM
    briarpatch
    briarpatch New Member
    I've been through the whole Chemical Guys 'V' lineup.....V32/34/36/VSS/V4......and was disappointed in each product. I'm not knocking CG in general, they're no different than any other line...some good products, some not so good. Their compounds/polishes leave a little to be desired, in my opinion. I've had good success with the Griots Garage BOSS creams for defect removal, and it's tough to beat the tried and true combo of Meguiars 105 and 205. As far as pad choices, I think thin is in. I use the Griots BOSS pads (5.5"), and I've heard good things about the thin pads from Lake Country.
    Nidahogirl and War Machine like this.
  23. Sep 17, 2018 at 4:54 AM
    War Machine
    How would you compare this method to using a dedicated headlight restoration kit? I currently have one of Meguair’s kits I haven’t used yet. My wife’s Sequoia is in bad need of this.
  24. Sep 17, 2018 at 6:34 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Driverdog's "vicious" cycle of headlight hazing will continue until Driverdog decide to use a UV clear coat after polishing. Of course buffing the headlights every 5 months may be an exercise in zen for him..;-)>
    B
    driverdog likes this.
  25. Sep 18, 2018 at 1:19 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
  26. Sep 18, 2018 at 5:35 AM
    bvia
    bvia New Member
    None
    https://www.amazon.com/SYLVANIA-Hea...7273953&sr=1-2&keywords=sylvania+headlight+uv
    SYLVANIA - Headlight Restoration UV Block Clear Coat - Most Important Step to Restore Damaged Headlights, Surface Activator, UV Protection for Clearer Headlights - 1 Fl Oz
    It's Consumer Reports #1 rated product and I've personally used it on the Mrs' car('05 Mazda 3s) as have most of my friends (2011 Tundra-2012 Tundra). Follow the directions and you'll be loosing that "zen and the art of headlight polishing" in no time..;-)>
    B
    driverdog and 4x4_Angel like this.
  27. Sep 18, 2018 at 8:57 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
  28. Sep 19, 2018 at 5:35 AM
    bvia
    bvia New Member
    None
    Taco-Blender[QUOTED] likes this.
  29. Sep 19, 2018 at 7:13 AM
    Taco-Blender
    AZ
    2010 DC 4x4
    Thank you.
    I was surprised at how little effort it actually took. About an hour to do both sides. I think the key was getting some 3" pads for my Porter Cable DA. That and the Chemical Guy's kit. Can probably do another dozen pairs of headlights with the leftovers from that.
