D3's Black 18' Crewmax Tundra Build
Discussion in '2.5 Gen Builds (2014-2021)' started by D3Tundra, Sep 11, 2018.
  1. Sep 11, 2018 at 4:12 PM
    D3Tundra
    D3Tundra [OP] New Member
    Dennis
    Atlanta, GA
    2018 Midnight Black Tundra Limited 4x4 CM
    Rigid fog lights Interior Led light upgrade Spray in Bedliner CRUX Avity-01 VIM Bypass module 5% tint all the way around 50% on the windshield Wireless charger arm rest mod Amp Research Steps Bak Revolver X4 Tesla Style Headunit Procomp 4" lift Toyo M/T's 35x12.5xR22 Fuel Maverick D538 wheels 22x10 -24 offset
    I've already started this slow build, but I'll catch you guys up. Then I'll update this post overtime.
    CURRENT LOOK
    OLD TRUCK: 2011 Limited Double Cab 5.7 Black built by someone else which minimized my attachment to it. Hence I sold it.
    And let me say this... for everyone who is debating on which cab configuration to get let me answer it for you from experience. Its simple. Crewmax. Had I got a Crewmax originally there's a good chance I would still have it (glad I didn't though) because it was nice, but it was someone else's project. I needed to start from scratch. I was feening for my own project.
    Day 1: 2018 Toyota Tundra Crewmax Limited 4x4 Midnight Black
    Purchased: 1/24/2018
    MOD 1: Upgraded Interior and Exterior lighting to LED's
    1/25/2018
    MOD 2: Wireless phone charger
    1/30/2018
    The first mod I did was put in a wireless charger in the arm rest spot. Disassembling the armrest is simple. I've since upgraded the charger to a Mophie Wireless Charge Pad (Apple Optimized) 7.5W charger. The One I had in there originally was a cheap 5W wireless charger off Amazon. The charge speed was just too slow for me. The Mophie is expensive, so I couldn't justify destroying a brand new one. So, I found a used one on amazon prime (which ended up being brand new because someone opened the box and that's it). So I ended up keeping that one and using the one I've had for about a year so it showed much more wear and tear. Opening this one was a pain! Because of the higher quality, there is a plastic housing then the coils are set on the top of a metal housing. So, all I had to remove was that outer plastic. None the less, it's a much faster charging option and worth it.
    Old charger that I used.
    MOD 3: Line-X bed liner
    2/13/2018
    MOD 4: Window Tint - 5% all the way around 50% on the windshield :cool:
    2/14/2018
    MOD 5: Rigid Industries Smoked Fog Lights
    2/24/2018
    MOD 6: Bak REVOLVER X4
    6/13/2018
    MOD 7: Amp Research Steps
    8/23/2018
    MOD 8: Tesla Style Head Unit
    9/10/2018
    MOD 9:
    Procomp 4" lift
    10/26/18
    MOD 10: Jam Handle (4 finger)
    10/31/2018
    MOD 11: Tundra Door Seal Protectors
    11/5/2018
    MOD 12: Power folding mirrors
    11/9/2018
  2. Sep 12, 2018 at 1:50 PM
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    Nice build so far.
    D3Tundra[OP] likes this.
  3. Sep 12, 2018 at 4:14 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    The new model Telsa is sweet! I had the 1st version, sold with in 1 week, too many issues. Would like to get this version.
  4. Sep 12, 2018 at 4:20 PM
  5. Oct 28, 2018 at 5:50 AM
    D3Tundra
    Dennis
    Atlanta, GA
    D871A9CF-DBC1-462F-88F1-36116213A528.jpg Finally got her lifted this past week.
    Procomp 4" lift
    Toyo M/T's 35x12.5xR22 ☺️
    A46CDE0B-2A8B-427E-B9E8-61741AFA4353.jpg 5ABF1B85-0028-45FF-9825-28F7B2EDBE66.jpg 10A68659-2F16-4A13-8BC1-F1948EFADC28.jpg 09D44CE4-6576-44DD-BA34-41A8EAFA1B92.jpg
  6. Oct 28, 2018 at 5:56 AM
    D3Tundra
    Dennis
    Atlanta, GA
    I went with the 4" because I still wanted to fit in my garage. Measured this a ton of times and my calculations were correct thankfully haha. Have about 2" to spare. ADCF9D49-B2C9-4346-9E7E-961E9809F206.jpg DFD7DE74-6B15-4BE0-8A06-081672AF7151.jpgA2DDF3FD-2116-4CB7-990F-DD5EB1CDC9E6.jpg
  7. Oct 28, 2018 at 6:25 AM
    Berdine
    Binghamton, NY
    Turned out great! Looks mean!
  8. Nov 1, 2018 at 10:07 AM
    D3Tundra
    Dennis
    Atlanta, GA
    The one I got is perfect. Every now and then it will have a small issue. Like a phone, tablet, or computer, I've resolved every "glitch" by going into the settings and doing a "save and reboot." I honestly don't understand the issue people get. I just took my time installing it and made sure everything was connected securely.
    Berdine[QUOTED] likes this.
  9. Nov 1, 2018 at 10:41 AM
    D3Tundra
    Dennis
    Atlanta, GA
    Got a chance to pull my trailer (7'x16' enclosed) the other day, post lift.
    A few things I was concerned about...
    1. Any type of power loss because of the larger wheels and tires?
    2. Power loss due to the increase in height?
    3. Rear end sag?​
    1. Tow/Haul mode is such a beast. It's just crazy how that 1 button basically unlocks the truck. So with that said, I literally didn't notice any type of strain due to the wheel/tires.
    2. I know people often do a re-gear from what I've seen but typically when the ran 37's. So, I knew there could be a chance I would need to do this. I no longer think so. I had 35's on my previous double cab that had a leveling kit but it only had 20's and had almost no offset compared to these. So when I seen them (these 22's) they looked massive and heavy. I thought for certain I'd notice a power loss considering the wheels and tires add 2 extra inches of height.
    3. One reason why I ended up settling on the Procomp and not the BDS (my preferred option until I did research), is because the Procomp adds a leaf. Now they say it doesnt increase load capacity or anything like that. Its purpose is to add height and be an addition to the rear 1" block. Well I'm here to say that if anything it stiffened up the rear end for sure. I was prepared to order an AirLift suspension kit, but as you can see in the pictures, everything including the trailer looks pretty level. The trailer isn't loaded how I normally load it or with what I normally load it with, but there's a good amount of weight in the front of the trailer. I'm still using the same hitch receiver as I was before (2" drop) but before when I had to flip it and put the ball basically upside down because loaded it made the trailer and rear end sag. Now since I get to use it regular I'm thinking I can get bags to keep it level for when the trailer is fully loaded. So, I think I'm going to hold off on getting one of those nice polished, adjustable, expensive hitches and just run with what I have and just get bags if necessary. The only way I see me needing another hitch is if a tow a smaller trailer.
    Looking pretty level with the trailer gross weight probably about ~3500 lbs
    Very little rear sag thanks to the Procomp add-a-leaf style of kit in my opinion.
    Reference pic. Here I'm using the exact same hitch/receiver set up. The trailer is brand new and completely empty in this pic and there's clear rear sag. Which confirms that add-a-leaf is helping.
    My14Tundrs and Vizsla like this.
  10. Nov 1, 2018 at 12:07 PM
    D3Tundra
    Dennis
    Atlanta, GA
    Added the Jam Handle today. Love it so far... When I remember to use it haha. Still getting used to it. I have the little clear protection on the edge of the door, but this make it so that it stays more fingerprint free. I'm going to order two more for the back doors as well.
    I chose this location because from test fitting this (putting the jam handle on using masking tape), you get the most leverage in that spot which will make it easier for the ladies to use it ;)
    Vizsla likes this.
  11. Nov 1, 2018 at 1:11 PM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    That's a better option I grabbed the pocket on the inside of the door panel to shut mine
  12. Nov 9, 2018 at 11:45 AM
    D3Tundra
    Dennis
    Atlanta, GA
    Added a little protection to the step area. Ever since I lifted the truck it seems as if my feet got heavier because a bunch of scuffs have been appearing in this area.
    My14Tundrs, Vizsla and Berdine like this.
  13. Nov 9, 2018 at 12:12 PM
    D3Tundra
    Dennis
    Atlanta, GA
    With the -24 offset wheels I decided to get, it became increasingly more difficult to pull into my garage. I finally had to pull the trigger and do the power folding mirror upgrade/mod. Its ludacris that my old 2011 came standard with power folding mirrors, but now they made these a platinum only option.
    Overall this was easy to do. The hardest part was by far feeding the wire through the door jams and feeding the wires from the passenger side to the drivers side.
    Parts:
    Kilmat
    Roller for kilmat
    Wire
    Connector 1
    Connector 2
    Mirrors
    Switch
    Helpful post
    Ill keep this simple. You only need 4 wires. 2 for the power folding mirrors (pins 7 and 8) and two for the puddle lights (pins 5 and 6). I discovered that the mirrors I got don't have auto dimming and neither did the oem ones. So I didn't use those pins. I made a cheat sheet the summarizes and explains where everything needs to go. I just highlight the important stuff.
    I made this to test the pins to make sure I had the correct ones and connected the other end to the battery on the truck.
    The pins are easier than I thought to put on. I discovered that there is a little door on both connectors that if you take off makes it significantly easier to push the pins through.
    On the pins that go into the mirror clip, theres a little hook thing on the left side. If you look at the connector its supposed to be on the right side, so I just cut it off. If you don't its almost impossible to slide the pin in.
    When running the wires, straighten a hanger or whatever else you have to feed the wire through. But lube the grommet. Thank me later :)
    Finished product.
    As you can see, I have a two car garage, but for some dumb reason they decided to put a wall in the middle of it. Forcing me to figure this out sooner, rather than later.
    Because I knew I was pulling the doors off, I also decided to add the Kilmat in the door which significantly increased the time it took to do this but I wanted to do it.
    bulldog93, 406Michael, JayCO and 5 others like this.
  14. Nov 9, 2018 at 1:05 PM
    D3Tundra
    Dennis
    Atlanta, GA
    Did a little photo shoot the other day
    bulldog93, jdh564, ManoTundra and 7 others like this.
  15. Nov 9, 2018 at 1:43 PM
    Midnightcrew
    Midnightcrew New Member
    NorCal
    2018 Crewmax SR5 Version 2.0
    I always appreciate seeing some chrome!!! Nice looking truck!!!
    TundraLuv and D3Tundra[OP] like this.
  16. Nov 10, 2018 at 4:57 AM
    D3Tundra
    Dennis
    Atlanta, GA
    DDFBD92C-5657-4176-84A5-695CB46AB6F8.jpg Couldn't stand the yellow light in the puddle lights so I sacrificed my dome lights until I get some more bulbs via Amazon prime haha AA9DE0DB-69AE-4296-BEEC-055286372A87.jpg
  17. Nov 10, 2018 at 5:16 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Nice job on the mirrors. Where did you order the mirrors from?
  18. Nov 10, 2018 at 6:13 AM
    rangrs34
    rangrs34 New Member
    Brad
    2018 Cement Tundra
    4" Fabtech lift with dirt logic coilovers and rear dirt logic shocks, 305/55R20 Grapplers, 20X10 Fuel Coupler wheels, 30" Rough Country Light Bar, Painted grill surround, hood bulge, and top half of side mirrors cement color, wrapped front and rear bumper endcaps, blacked out badging.
    Nicely done!!
  19. Nov 10, 2018 at 8:21 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Very nice! How do you like the pro comp 4”? Did you just use their spacers and such?
    Love that new Tesla lookin head unit too! How is that thing holding up? Any good pro/cons with it?
  20. Nov 11, 2018 at 12:06 PM
    D3Tundra
    Dennis
    Atlanta, GA
    A1auto. I linked it under the parts section. They are worth the cheaper price. Good quality, but not OEM quality. But good enough. Don't think the $800 OEM ones are worth the price over these.
    jtwags[QUOTED] likes this.
  21. Nov 11, 2018 at 12:12 PM
    D3Tundra
    Dennis
    Atlanta, GA
    I love it! I think it's the perfect height. Plus it allowed me to still fit in the garage. No wheel spacers. The offset covers that. Just a shock spacer on the top of the coilover that came with the kit. Was going to upgrade to fox coilover but figured I'd try this first. Still rides a Lil better than stock. Haven't been able to justify the fox shocks in my head. I would need to feel the difference in another vehicle first.
    Love the head unit! Arguably my favorite upgrade. I haven't had a single issue that wasn't resolved with a reboot. The capabilities it unlocks are well worth it. There's nothing I can't do. Not to mention I have three different ways of connecting my phone and mirroring/playing what's on it. Not to mention being able to play from the app I.e. Netflix. We'll worth it.
  22. Nov 14, 2018 at 11:00 AM
    Navi
    Navi New Member
    2019 CrewMax Limited
    Very nice build! About the AMP Power Steps: did you install yourself? If so, how was that install any specific advice or gotchas to be aware of?
    Lake.Life24 likes this.
  23. Nov 15, 2018 at 7:08 AM
    D3Tundra
    Dennis
    Atlanta, GA
    I was going to, but I did not install them myself because 4wheelparts was doing a free install on amp steps. Looking at what they did, I still think its fairly easy. Only issue is the 18's have different wiring then the 17's. So take note of that if you have an 18 and make sure you have the correct directions.
  24. Oct 21, 2019 at 6:09 AM
    Tom_Tundra_TN
    Tom_Tundra_TN New Member
    Tom
    2016 TRD CM
    TRD Exhaust, TRD Front&Rear Sway Bar, TRD Shifter Knob, BFG TAKO2, Toyota GBS, 3/1 Leveling Kit, K&N CAI, Leer 100XQ Topper, Tinted Windows, Tacotunes Upgrade, Bed LED Lights, Mirror Caps & Door Handle Color Match, BedRug, LED Interior Lighting, Tailgate Tundra fill, Toyota Step Rail, Katzkin Leather Seats, Leather Console, FRAC Harness, Stubby Antenna, Power Folding Mirrors, Autoloc One-Touch Window Mod, TRD Pro Wheels w/ Lug Nut Covers, Color Match Bumper Ends
    D3Tundra
    I have a 2016 SR5 TRD with BSM, Heat. I purchased a set of 2014 OEM Platinum mirrors with all the bells and whistles. When I plugged them up the adjustment works, the turn signal works, the heat works but I get the "Check Blind Spot Monitor, See Dealer" code on my dash. Also the BSM light does not light up on the mirror like it normal does when I turn the key on. Any Suggestions?? Thanks..
  25. Oct 21, 2019 at 7:50 AM
    D3Tundra
    Dennis
    Atlanta, GA
    I had the same issue. Short term, I just turned off the BSM in the settings. The issue is the pins on the mirror don't match the ones on the truck. You have to test for the bsm signal from the truck and match/switch pins around so they match the mirror. I've been lazy and haven't done this, but I never really relied on BSM anyway. I always found myself still looking over my shoulder anyway.
  26. Oct 21, 2019 at 8:33 AM
    Tom_Tundra_TN
    Tom
    2016 TRD CM
    Thanks for the reply. My OCD will make me fix this lol.
    TC
    D3Tundra[QUOTED][OP] likes this.
  27. Dec 21, 2019 at 10:53 AM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    See you went with the ProComp 4" lift. About to pull the trigger on mine. Just wondering if you could share your experience with it now that you've had it for a while?
  28. Dec 23, 2019 at 6:51 AM
    D3Tundra
    Dennis
    Atlanta, GA
    Still love it! I haven't had a higher lift, but coming from a level, I still think its the most practical lift especially if you do some towing/hauling (aka use your truck haha) every now and then. The only reason I see to go with a higher lift is if you want to put on 37's.
    Ckatz53[QUOTED] likes this.
  29. Jan 2, 2020 at 9:01 PM
    BillDig
    BillDig New Member
    2016 Tundra DC TRD Bronze
    Did you ever figure this out? I tried with one mirror and got the same dash error. I’m going to try again this weekend and do both, and see if it’ll avoid the BSM error. My 2016 has BSM but I want to add folding tow mirrors with BSM.
  30. Jan 6, 2020 at 9:07 PM
    Keoki_m
    Keoki_m New Member
    What lights did you use for your amp steps?
