Cylinder 6 & 8 Misfire after head gasket repair
Discussion in '1st Gen Tundras (2000-2006)' started by tundra04v8, Jun 30, 2024.
  1. Jun 30, 2024 at 12:36 PM
    tundra04v8
    tundra04v8 [OP] New Member
    2004 Toyota Tundra v8 4.7L
    none
    I recently just did a head gasket replacement on a 2004 Tundra V8 4.7L. After putting everything back together Cylinder 6 & 8 are missing. There is also a code for bank 2 running too rich. The idle is very rough but the engine smooths out around 2500 RPM. The engine was shutting down on idle until replacing the PCV valve. I have swapped plugs, injectors, and coils, none of which cause the misfire to travel. Does anyone have any insight on this? My next thought is to test compression to see if maybe the heads didn't seat right. I had them resurfaced and followed the recommended torque specs and tightening pattern. Any help would be appreciated!
  2. Jun 30, 2024 at 2:21 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Head gasket failures are very rare on the 4.7. How did you diagnose this?
  3. Jun 30, 2024 at 2:28 PM
    tundra04v8
    none
    Started losing coolant, pressure tested the cooling system, coolant was leaking out between head and block
    bfunke[QUOTED] likes this.
  4. Jun 30, 2024 at 2:29 PM
    Sorry to hear about your troubles! Your Misfires and bank 2 rich are probably related to the misfires themselves. Compression check on bank 2 is a good first step if a gauge is handy. Make sure to get the coil packs hooked up in correct order? Plugs are good? Fuel rail connections and injectors good? Should be hard to get them swapped. Trouble with idle is often vacuum related. Check all the vacuum connections.
  5. Jun 30, 2024 at 2:32 PM
    tundra04v8
    none
    Thanks for the reply, I double checked the coil packs and injectors to make sure they were hooked up correctly, definitely would be hard to get it out of order. plugs are brand new, even tried putting the old ones back in, just to make sure. I will do a vacuum test as well, have not done that yet.
