CV boot torn; Replace boot or get new CV axle?
Discussion in '1st Gen Tundras (2000-2006)' started by Bubbadog, Jun 13, 2020.
  1. Jun 13, 2020 at 5:48 PM
    Bubbadog
    Bubbadog [OP] New Member
    I have a 2001 Tundra 4.7l V8 4X4 access cab with 215,000 miles.
    It has the original CV axles. It is all stock and used as my daily driver.
    While putting on brake pads today, I noticed the CV boot on the driver's side is torn.
    Looking for advice on whether to just replace the boot or the entire axle assembly.
    Rock Auto has a Cardone brand axle for about $55 shipped to my door.
    Any advice is appreciated.
  2. Jun 13, 2020 at 5:52 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Those things are junk. If you want to swap the axle out, have the oem unit rebuilt by a reputable shop.
    Elduder and Wynnded like this.
  3. Jun 13, 2020 at 6:14 PM
    Professional Hand Model
    Hand Protectors
    Bite the bullet and buy new OEM axles. You can buy some OEM Reman’d for around $600, but the brand new OEM ones cost about $800.
    These cheap aftermarket made in China ones are junk. I just bought some less than 2 years ago and they are making a swirl/chirp noise. Got a great deal on them, though! Lesson learned.
    JimboSlice413 likes this.
  4. Jun 13, 2020 at 6:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  5. Jun 13, 2020 at 6:36 PM
    Bubbadog
    Other than the torn boot, there are no current problems.
    What about just keeping my original axle and getting a new boot and clean new grease?
    Hooptytrix likes this.
  6. Jun 13, 2020 at 6:38 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You'll regret getting aftermarket axles. If it's just the torn boot you could always throw a new boot on.
  7. Jun 13, 2020 at 6:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've done that as well. If my memory serves, the grease from the local auto part store was like $2 a packet. Then I just re-banded with stainless hose clamps. I never had a problem/failure.
    Elduder likes this.
  8. Jun 13, 2020 at 6:56 PM
    Elduder
    Elduder New Member
    CVJReman re-manufactures OE CVs, very popular with the Tacoma guys, theres a thread somewhere on Tacomaworld that if I remember correctly is well over 50 pages with little in the way of issues.
    https://www.cvjreman.com/product-tag/9550/
    I've also used Napa axles, if you use the HD axle its comes with TPR boots rather than a neoprene outer (avoid neoprene). Napa HDs are good too, Im sure someone will disagree, but I've had no issues with first hand experience.
    You could also just reboot. The joints themselves are pretty robust, but if they're torn for a long period of time dirt can score and damage the inner joint and shaft. I'd recommend getting at least a OEM or CVJ reman and then reboot your old axle for a back up.
  9. Jun 14, 2020 at 5:46 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I agree with @Elduder that the joints are robust. I would take the low cost route to clean out any dirty grease, inspect, regrease, and reboot for now. Depending on how long the boot has been cracked, "maintenance by degrees" is probably a good plan here if you haven't noticed any noise or vibration. You will get some advance warning of CV joint failure. It is very unlikely to happen instantly and leave you stranded somewhere.
  10. Jun 14, 2020 at 5:56 AM
    Hand Protectors
    Seems like a lot of work to pack Grease and install a New Boot. Wouldn’t be the best route to just put in new axles (other than $800 cost for a pair) since doing all the work?
    My boots were torn like the OP’s and I had no issues other than grease slings. There were no noises/clicks/vibes etc. I should have just left them on until they failed mechanically.
    The other thing I forgot to mention is the OEM axles turn better than the cheapies when in 4WD conditions.
    chugs likes this.
  11. Jun 14, 2020 at 6:11 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    I gotta leaky boot as well, so when there is no grease slinging present then time for a replacement, as there may be not any more grease to sling.
  12. Jun 14, 2020 at 6:18 AM
    Hand Protectors
    In my case, I had no idea how long the boot was torn. I do know that the thing had thrown all the grease it could from the dry cakes on the frame. Axles still worked and no noises. I’d leave it until failure/noises/1full replacement time next time in my case in retrospect.
    If you have the money and want to do them just buy brand new OEM. Better than Reman’d for only a little more money per the Reman websites own admission.
  13. Jun 14, 2020 at 6:38 AM
    Bubbadog
    Are the CV axles are always rotating?
    Even when not in 4WD?
  14. Jun 14, 2020 at 6:42 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes.
  15. Jun 14, 2020 at 8:00 AM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    $50, a mess and afternoon of work is all that’s needed to replace the boot. Granted you have the tools and mechanical capability, boots are easy enough to replace (done 4 on tundras and 10 on 4runners). Otherwise I wouldn’t do aftermarket if possible (maybe Napa premium). They often have issues and seen too many rust right away and thin cheap boots.
  16. Jun 14, 2020 at 11:14 AM
    Casper421
    In the woods
    06 DC
    Replace boot.
  17. Jun 15, 2020 at 8:47 AM
    I vote rebuild if possible. Not that hard to do. Mine got water in them and were clicking and grinding. I bought some from advanced auto to replace both front shafts at different times. Have held up well, have thicker shafts than the stock (doesn't mean better) and has all stainless hardware. About $90 each. Also has the larger boots that are needed for lifted front ends. Bonus. Haven't noticed any difference in steering when in 4WD. Also lifetime warranty.
  18. Jun 15, 2020 at 9:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was initially against a re-boot but after watching a video it really doesn't look that bad. Given how much better the OEM axles are than aftermarket I think it's worth trying a $30-50 boot repair vs spending nearly $1000 on new ones. If they are not clicking I doubt he's done damage yet.
  19. Jun 15, 2020 at 11:04 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Others have kinda said it, so I'll directly say it. Go find some dirt, put it in 4wd and turn and accelerate. If no clicky clicky, reboot. If clicky clicky, reaxle.
  20. Jun 15, 2020 at 10:43 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Now that's funny
  21. Jun 16, 2020 at 4:36 AM
    Elduder
    Elduder New Member
    Or just jack the front end up and turn the wheel by hand while someone turns the steering wheel lock to lock.
  22. Jun 16, 2020 at 5:06 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That won't work. The front axle has to be engaged for it to click. I have a bad one and it only does it in 4wd.
  23. Jun 16, 2020 at 8:32 AM
    Bubbadog
    OP here.
    I have decided to see what trouble I can get into doing it myself.
    I ordered a set of OEM Toyota CV boots. The outer is torn but I might as well replace the inner while the axle is out. They were about $60 online with shipping.
    They were just a little bit more than the universal CV boots available at the local auto parts stores. I thought it was worth it to get a good fit.
    Never done this repair before.
    Wish me luck!
  24. Jun 16, 2020 at 9:21 AM
    Hand Protectors
    Take pics! We like pics! And don’t mangle the job or we’ll never let you forget about it. :rofl:
    bmf4069 and Wynnded like this.
  25. Jun 16, 2020 at 9:29 AM
    Elduder
    Elduder New Member
    Inner CV I guess then? Had an outer failing on my driver side on a 2011 Fj, was able to catch the click with the front up and d.s. Wheel turned cab side.
  26. Jun 16, 2020 at 10:24 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Mines an outer. I may have to try that when it's off the ground again.
  27. Jun 20, 2020 at 5:01 PM
    Bubbadog
    OP here following up.
    I ordered OEM Toyota CV boots and checked three sources online to confirm I was buying the correct boots. They didn't fit once I had the axle out today. I went to the local auto store and purchased "universal fit" Dorman boots. I guess universal means the won't fit anything because they were no where close to working. I went back a second time and purchased a new aftermarket CV axle and it took all of 10 minutes to slide it in. I am never attempting to replace the boots again.
  28. Jun 20, 2020 at 6:51 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Dam, sorry to hear. Sounded like a good plan here, but reality is seldom that easy...glad you got it fixed.
  29. Jun 20, 2020 at 7:07 PM
    Bubbadog
    Thanks.
    Seldom do my vehicle adventures go smoothly.
  30. Jun 20, 2020 at 9:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Waxing, that has to be one of those thought, right?
