CV Axle Concern
Discussion in '2.5 Gen Tundras (2014-2021)' started by Acrotalus, Mar 11, 2019.
  1. Mar 11, 2019 at 4:38 PM
    Acrotalus
    Acrotalus [OP] New Member
    TX
    2016 Quicksand TRD Pro Tundra
    Fab Fours Elite Bumpers Total Chaos Shackle TRD front and rear sway bar Westin R7 Running boards
    picked up my truck today after getting 7” BDS Coilover Kit with Fox 2.5’s and adding 37” Ridge Grapplers. Everything is amazing, except when I turn, I get some clicking and feedback in my steering wheel. I’m afraid it’s the CV axle. I have taken a picture of it and a video of the play in it, but it won’t let me post it. It just has a bit of play that makes a noise when it’s pushed up on.
    Could the clicking be from the bumping of the CV (play) or would it be internal and a cause for concern? Did the shop that installed my Kit cause this, because it was never an issue before?
    Kgfit85 and TXRailRoadBandit73 like this.
  2. Mar 11, 2019 at 4:44 PM
    Acrotalus
    TX
  3. Mar 11, 2019 at 4:56 PM
    neirbot
    neirbot New Member
    I have the same thing going on. It clanks over small sharp bumps. Hoping to get it resolved this week with the ECGS bushing, but I'm not 100% that's the solution.
    Do you have a different drop installed? The CV angle looks steep.
  4. Mar 11, 2019 at 5:00 PM
    15whtrd
    15whtrd Mr. Blonde
    That angle does look pretty extreme. It’s possible the shop was hard on it and overextended it. I don’t normally suggest a diff drop but that looks like it might help.
  5. Mar 11, 2019 at 5:14 PM
    Mine looks almost the same, I'm on a 6" kit on 35's
    Mnorris1206 and 15whtrd like this.
  6. Mar 11, 2019 at 5:15 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    CV angle is your problem. Too steep and if you continue to drive it like that you will need new axles soon.
  7. Mar 11, 2019 at 5:17 PM
    I'm sure you know or have heard don't be turning in 4wd while on pavement, it's bad on the 4wd
    Black Wolf likes this.
  8. Mar 11, 2019 at 5:20 PM
    Good looking rig BTW
  9. Mar 11, 2019 at 5:59 PM
    Acrotalus
    TX
    It came with a diff drop and I was under the impression that the kit was supposed to maintain all those angles :(
    1engineer[QUOTED] likes this.
  10. Mar 11, 2019 at 6:00 PM
    Acrotalus
    TX
    Kit came with a diff drop, I was under the impression it was supppsed to maintain factory angles :(
    15whtrd[QUOTED] likes this.
  11. Mar 11, 2019 at 6:03 PM
    Larger tires n wheels plus extended steering knuckles are going to tweak those angles
  12. Mar 11, 2019 at 6:04 PM
    Mnorris1206
    08 tundra
    1engineer and TXRailRoadBandit73 like this.
  13. Mar 11, 2019 at 6:08 PM
    Mnorris1206
    08 tundra
    That video I wouldn't worry as much as far as that play goes what about if you grab the shaft of the CV axle when my driver side was bad it would move alot back and forth that way
  14. Mar 11, 2019 at 6:13 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    What he said. If you have a lot of miles on the CV joint that’s your canary and it will go. You usually start to notice during turns because it increases the angle and the Load on the joint.
  15. Mar 11, 2019 at 6:16 PM
    I thought we were supposed to according to Elk Hunter #2
  16. Mar 11, 2019 at 6:24 PM
    Acrotalus
    TX
    Is it hard to replace? I work in the oilfield, middle of nowhere and can’t be stranded if it goes.
  17. Mar 11, 2019 at 6:49 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    First pic makes 37’s look skinny which I love skinny tires but not many in 17” wheel size. Good looking truck, Cv’s look strangled. Take it back to the shop.
  18. Mar 11, 2019 at 7:11 PM
    Acrotalus
    TX
    Going back tomorrow to get CB shackles installed. What should I have them do regarding the CV’s?
    Thanks, they’re 37x12.5r18
  19. Mar 11, 2019 at 7:18 PM
    1engineer
    Appalachians
    Take it to the shop who did it and have them fix the angles.
    They are fairly easy to replace but you gotta have parts and the new one is just going to do the same thing until the angles are fixed.
    ZappBrannigan likes this.
  20. Mar 11, 2019 at 7:19 PM
    Curious does the cutting of the rear crossmember have anything to do with CV axle angles?
    Mnorris1206 likes this.
  21. Mar 11, 2019 at 7:21 PM
  22. Mar 11, 2019 at 7:22 PM
    Mnorris1206
    08 tundra
    Just for diff drop. Drive shift would hit it . I'm really surprised the O.P. is having this issue I have only really heard good things about bds lift kits
  23. Mar 11, 2019 at 7:28 PM
    Like I said earlier, I'm on a 6" kit, my CV axle angles almost just like that, no issues here
    Mnorris1206[QUOTED] likes this.
  24. Mar 11, 2019 at 7:29 PM
    Mnorris1206
    08 tundra
    Ikr I get lost in this and cant keep up sorry but you are running the r.c. lift like I am also right ?
  25. Mar 11, 2019 at 7:29 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    It's not the shop's fault so much as the kit itself. That CV angle is excessive and will lead to damage. I currently fit 35" tires on my truck by lifting the front about 1.5" and no lift in the back. Unless you really like the look of the 7" lift you could fit your tires with a lot less lift.
  26. Mar 11, 2019 at 7:30 PM
    Yes
  27. Mar 11, 2019 at 7:33 PM
    Mnorris1206
    08 tundra
    Not sure what other lift he can do for 37x12.5x18 I cant fit those on my truck lifted 6" unless I cut on some stuff. O and have you ever drove a big lifted truck before . I did it once yrs ago and always wanted one and now that I do won't ever have one not lifted high unless I'm just to old to get in Haha
  28. Mar 11, 2019 at 7:37 PM
    computeruser6
    Dirk
    Escondido
    Cutting is a way better solution than more lift. As the suspension cycles the larger tire will have to go somewhere; this means that you have to limit travel by adjusting bumpstops or cutting until the tires clear anyway. @papasmurf
  29. Mar 11, 2019 at 8:06 PM
    Acrotalus
    TX
    I had 35’s with just the Stock TRD pro level, but I wanted to get higher and run 37’s .. I’ve never heard a bad thing about the BDS coilover Kit and love it. I just want to make sure I don’t screw something up - how do I remedy the CV angles? Have them dial the coils down?
  30. Mar 11, 2019 at 8:13 PM
    Acrotalus
    TX
    No, there’s no RCM cut but I just looked and apparently the kit is supposed to come with a rear drop crossmember??
    They just added the blocks, the 2.0’s and relocated brakes in the rear.
