Cv angles after 3” lifts
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fish2eat88, Nov 25, 2018.
  1. Nov 25, 2018 at 10:55 PM
    Fish2eat88
    Fish2eat88 [OP] New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Im pretty set on running a good 3” front lift (kings or OME BP51’s)
    And maybe 1.5-2” rear for factory rake. (22” front from center hub to fender, 24” rear from center hub to fender) so im looking atleAst 1.5” of rake. Im curious how much cv angle a 3” lift gets? Also how many of you are experiencing vibrations after the lift and how much of the rear did you lift. Is there still decent travel when going to a 3” lift? Here in hawaii I need the most clearance as possible so a DB lift is not out of the question but I dont want to cut the frame so might need to go bulletproofs 6-8” lift setup. I only like thr DB because cv’s is back to normal. We dont drive fast here in hawaii, just need good clearance on our types of trails. Thanks in advance.
    Sunnier likes this.
  2. Nov 26, 2018 at 2:23 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    give it minute lots of info to had plus a shout out to onos seafood poke on kapahulu
    Fish2eat88[OP] likes this.
  3. Nov 26, 2018 at 10:28 PM
    aperezsh
    Ali
