Cutting bump stops down about an inch to level truck.
Discussion in 'Suspension' started by TheBeardedOne, Oct 12, 2024.
  1. Oct 12, 2024 at 5:43 AM
    TheBeardedOne
    TheBeardedOne [OP] New Member
    VA Beach
    2022 Army Green Tundra Limited
    Just here for info since I can't find anyone who has done it. I've got the rear load leveling option on my 22 tundra, so I'm thinking of lowering the rear by adjusting the arms to the sensors to lower the rear to kinda "level" the truck. I can't really afford a legit leveling kit right now, so this i feel would be alright till I can. My question is, since lowering the rear brings the bump stops closer to the axel, would it hurt anything to just cut about an inch of of them to prevent bottoming out? Thanks in advance.
  2. Oct 12, 2024 at 6:04 AM
    May damage the shock seals if they don't have the additional travel in them to accommodate that extra 1" of down travel.
  3. Oct 12, 2024 at 7:51 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would just wait until you can level by raising the front rather than trying to hack and lowering the rear. Confident that you would be happier with that in the long run.
    It will save you money and effort doing things right the first time. If you do this lowering hack now, you will have to undo it and replace those bump stops once you do end up doing any type of lift. And who knows if lowering the rear beyond the rear leveling specs will cause issue for you in the future.
    Id wait until you can set the truck up the way you actually want it.
