Cutting Acrylic / Plexiglass ?
Discussion in 'Off-Topic Discussion' started by TTU19, Jun 27, 2019.
  1. Jun 27, 2019 at 10:41 AM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    So I'm trying to make something out of acrylic that requires me to cut a logo out of the center. I've seen plenty of ways to cut a straight edge, but what would be the best way to cut shapes? Hope you understand what I'm trying to say, ha. Thanks..!
  2. Jun 27, 2019 at 10:48 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe a router? Or drill a hole and use a jigsaw with a fine tooth blade?
    TTU19[OP] and Ajkkane like this.
  3. Jun 27, 2019 at 10:53 AM
    Phantom Lord
    Phantom Lord New Member
    Byron
    2017 MGM CM Limited
    I’ve used a Dremel with a similar setup to this.
    15whtrd, TTU19[OP], joonbug and 3 others like this.
  4. Jun 27, 2019 at 11:17 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I use a Dremel also. I find anything rotary melts it but comes out cleaner and doesn't chip the edge like cutting with a blade. Just gotta break off the pieces leftover from melting it. Straight lines just score both sides and break off.
    Vizsla, TTU19[OP] and saybng like this.
  5. Jun 27, 2019 at 11:29 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    If using a jig saw or scroll saw just make sure to use the correct blade..and if u dont have a scroll saw flip your jig saw upside down and use it as a scroll saw..just dont cut your fingers..
  6. Jun 27, 2019 at 11:53 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks, will have to look into these options. Humm..
  7. Jun 27, 2019 at 12:34 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Dremel or small router is best. Scroll saws are next best. Jigsaws will cause a lot of up and down vibration which cause cracking, especially if the acrylic is thin. If you want to use a jigsaw, I recommend clamping the acrylic between 2 pieces of plywood and cutting all 3 at the same time.
  8. Jun 27, 2019 at 4:45 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    A roto-zip will do it, but make practice cuts first, so you're ready for the torque-walk. Also make sure you cover a wide area around the intended cut with painter's tape.
