Cut factory antennae?
Discussion in '2.5 Gen Tundras (2014-2021)' started by harrisdoggy, Nov 14, 2016.
  1. Nov 14, 2016 at 6:29 PM
    harrisdoggy
    harrisdoggy [OP] New Member
    Josh
    2016 Toyota Tundra CrewMax SR5
    Been looking for a shorter antennae in order to get in and out of the garage without any issues. Bought one, but the reception is not great. Anyone tried taking a few inches off the factory antennae and replacing the ball at the end?
  2. Nov 14, 2016 at 6:33 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I saw this on Tacomaworld and actually wanted to do this with my Tundra but I bought my truck without an antenna and @Sean266 got rid of his stock one before I could steal it from him.
    harrisdoggy[OP] likes this.
  3. Nov 14, 2016 at 6:40 PM
    csuviper
    Broomfield, CO
  4. Nov 14, 2016 at 6:47 PM
    I cut my stock Tacoma one before. Worked fine
  5. Nov 15, 2016 at 2:52 AM
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    I've done this on my last 3 trucks with no issues
  6. Nov 15, 2016 at 8:18 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    From a fellow engineer, you'll be fine. It's not until you get down to scientific BS that you will see differences. And even then, the difference is mainly on paper and not in actual workability and reception in the antenna.
  7. Nov 15, 2016 at 1:32 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
  8. Nov 20, 2016 at 6:18 AM
    MartyWI
    MartyWI New Member
    Chad
    Wisconsin
    2017 Limited Crewmax Inferno
    Black KMC Rims Black Horse step bars Xtang 2.0 Tri-fold Cover 2018 LED Headlights (ordered 11/17)
    All of you need bigger garages. Stop cutting your antennas and build a bigger garage!
  9. Nov 20, 2016 at 6:21 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Hahaha I know right. honestly, half the time mine isn't even in because the car wash place around the corner takes it off and I just said screw it.
  10. Nov 20, 2016 at 6:23 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I cut about 4 inches off with my dremel tool. Doesn't seen to effect reception at all.
  11. Nov 20, 2016 at 6:25 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    It wont. the science behind reception tell you that cutting an inch or 2 won't affect anything.
  12. Nov 22, 2016 at 1:18 PM
    jwm9289
    jwm9289 New Member
    How much could you safely cut off in your opinion?
    Thanks,
  13. Nov 22, 2016 at 2:44 PM
    Pudge
    CT
    I cut off 4 and it's fine
  14. Nov 22, 2016 at 2:46 PM
    jwm9289
    jwm9289 New Member
    Thanks,
  15. Nov 29, 2016 at 6:15 PM
    harrisdoggy
    Josh
    Thanks. Did you replace the little ball or leave it straight? Is it easy to remove the ball?
  16. Nov 29, 2016 at 6:18 PM
    Pudge
    CT
    I couldn't get the little ball off. I put a little piece of heat shink wrap on the end
  17. Nov 30, 2016 at 8:16 AM
    harrisdoggy
    Josh
    Good idea, thanks. No whistling or anything when you drive at higher speeds?
  18. Nov 30, 2016 at 10:38 AM
    Pudge
    CT
    Not that I've noticed
