Custom bumper update
Discussion in '1st Gen Builds (2000-2006)' started by DA Tunbrah, Aug 5, 2019.
  1. Aug 5, 2019 at 7:48 PM
    DA Tunbrah
    DA Tunbrah [OP] New Member
    Jeff
    2002 access cab limited
    Well here’s an update on this 1st gen I’ve been messing around with. Just Finished the paint and moving on to suspension. Hopefully I’ll have the coil overs from Fox soon.
    What do you guys think of the vintage color?
  2. Aug 5, 2019 at 7:54 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Looking good! :cool:
  3. Aug 5, 2019 at 9:06 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Looks like a nice truck.
    Rica25 likes this.
  4. Aug 5, 2019 at 9:22 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you're getting Fox 2.5 coilovers I suggest swapping your front brake lines for Tacoma lines. They're longer and use a banjo fitting at the caliper, they join at the hard line coming off your frame and eliminates the hard line at the caliper. Wheelers Offroad can set you up.
    Fox lower mounts like to bend stock brake lines, it's a bad design.
    speedtre, Pudge, Black Wolf and 4 others like this.
  5. Aug 6, 2019 at 12:00 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looks great man. Love the color. What size tire are those? They look bigger than 33's.
  6. Aug 6, 2019 at 12:15 PM
    DA Tunbrah
    Jeff
    285/75 16 tires
  7. Aug 7, 2019 at 9:34 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    looks great! What lift/suspension do you have now?
  8. Aug 7, 2019 at 10:20 AM
    Navi
    Navi New Member
    2019 CrewMax Limited
    The color is sweet looking
  9. Nov 8, 2019 at 7:15 AM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    How did you attach your bumper like that? did you take the plastic pieces off and then tac it on? I really like it and have been wanting to do something similar to my truck
  10. Nov 9, 2019 at 9:56 AM
    DA Tunbrah
    Jeff
    I cut my fenders out first (just cut along the upper side of the square holes for attaching the fender flares) if you wanna have the inner fender splash guards when your you’ll wanna weld some tabs back onto the sheet metal (I cut the tabs off the scrap fender metal and welded them back on along the new fender profile)
    Then remove the plastic which lives on the top side of the bumper. Cut the top of the bumper off, fill all the oval holes with fender metal scraps and use body filler to smooth out. I then welded pieces of angle onto the bumper to create a way to mount it to the grill/ radiator support.
    You’ll then have to mock the bumper into position and cut the ends off by following the new radius of the fenders.
  11. Nov 9, 2019 at 10:03 AM
    DA Tunbrah
    Jeff
  12. Nov 9, 2019 at 10:13 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Beautiful. I love it, nice work.
  13. Nov 10, 2019 at 11:49 AM
    DA Tunbrah
    Jeff
  14. Nov 10, 2019 at 11:51 AM
    DA Tunbrah
    Jeff
    After a bunch of trial and error I ended up using a 25 gallon plant container for the new inner fender splash guards...B10C82C8-68F4-4F3D-B7D6-B973E35E17C0.jpg
    Mountun Goat likes this.
