Curt 31998 Front Mount Hitch Review
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wintyfresh, May 10, 2018.
  1. May 10, 2018 at 10:48 AM
    Wintyfresh
    Wintyfresh [OP] New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    I use my truck for towing quite often, and have found it useful to have the option of using a front mount hitch. Having recently purchased my Tundra I decided to install the Curt 31998, and have to say I'm a bit disappointed. The hitch significantly hinders removal of the stock skidplate, the instructions recommending cutting a hole to allow for oil filter changes. Instead I've opted to replace it with an aftermarket unit from RCI Engineering.
    Perhaps the most annoying thing however is how far back the hitch receiver sits. Using a 12 inch shank triple ball trailer hitch I'm unable to even insert it, and if I could the ball will be sitting beneath the front bumper. Utilizing an extender cuts the allowed weight in half, and using a drop hitch will lead to ground clearance issues. I definitely feel like they could've put a little more thought into this design!
  2. May 10, 2018 at 11:37 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Maybe a longer custom shank could allow for more front bumper clearance? I don’t know but I’d either take it back or build a longer shank out of ½” steel. That’ll make it so your load capacity is not cut in half.
  3. May 10, 2018 at 12:06 PM
    Wintyfresh
    Ramona, CA
  4. May 10, 2018 at 12:21 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That seems really impractical. I have welded up and used front receivers on several trucks and they are sure useful for positioning trailers into tight spots. I don’t think that rating would bother me since you’re never gonna be on the road or going over 2 mph. Biggest drawback is how crappy the front clearance and approach angle is now. Plus, it looks like you’re gonna have to crawl under the front end to insert or pull the pin. I would return it and get one fabricated that is more reasonable.
    040Tundra and TheBeast like this.
  5. May 10, 2018 at 3:28 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  6. Dec 30, 2019 at 10:43 PM
    Vockroth
    Vockroth New Member
    Steven
    Santa Clarita, California, USA
    2008 Tundra Double Cab Limited 2WD Arrest Me Red
    Late Model 18" Factory Wheels | Michelin LTX M&S P275/65R18 116T Tires | TRD Sway Bar |Factory Running Boards | Ready Lift 66-5075 2.4" Front Leveling Kit | Bilstein B6 4600 Shocks and Struts | Curt Mfg 31198 Front Hitch | LLumar Formula One Stratos 30% Ceramic Tint Front Side Windows | K&N 33-2387 Filter Element | Morimoto Head Lights and Fogs | Snug Top Hi-Liner | Bed Rug | Anker ROAV T2 R5114 FM Transmitter | Intro-Tech #56060046 Custom Auto Shade | Ozium Air Freshener 4.5oz, (fits in ashtray hole)
    The stock bolts were long enough. I just happened to have longer ones I took off the wife's 2017 RX300 that bolted the Transportation Tie Down Bracket to the underneath of the car. These bolts were removed and not needed installing a Curt Mfg hitch to the RX350. I measured the bolts diameter at 12mm, the length of the bolt on my Tundra was 31.9. The usable length of the RX bolt is 35.3. Both bolts are flanged, have a captive washer and a 17mm hex head. I ordered two more bolts just to keep things matching. Toyota Part Number 90119-12391
    2008 Toyota Tundra Limited Double Cab 5.7 & Leveled. This hitch is heavy. It will mash anything before any other cross members. Stiffens front end. Great place to store ball mount, It's tucked in not like the rear where my shin hits it. Not going to store ball mount inside the cab with me, last thing I need hitting me in the head.
    If I had a skid plate I would bend the front mounting tabs down to mate with back of hitch. I would drill and tap holes to mount skid plate to hitch.
    ToyotasSuck!lol likes this.
