Cruise control not working???
Discussion in '2.5 Gen Tundras (2014-2021)' started by blizz86, Feb 12, 2019.
  1. Feb 12, 2019 at 1:41 PM
    blizz86
    blizz86 [OP] New Member
    My cruise control hasn't been working for a while now, but it hasn't really bothered me until lately.
    I switched out the cruise control stalk and its still not working. All brake light bulbs are still functioning. I also checked the brake pedal pressure switch and it doesn't appear to have a rubber washer/stopper - did it come with one?
    Would there be any other culprits aside from the clock spring?
    Graeman likes this.
  2. Feb 12, 2019 at 1:42 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    This seems obvious but are you pushing the button to set your speed and then pressing down on the stock to turn it on?
  3. Feb 12, 2019 at 1:44 PM
    blizz86
    Yes lol. The little icon for cruise control on doesn't show on the dash display. Nothing comes up either when i set the speed following pushing down the on/off button.
    Graeman likes this.
  4. Feb 12, 2019 at 1:52 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I figured but it was worth mentioning just in case. I wonder if there's a fuse specific for cruise. Have you cut any wires for any mods like foglight any time, etc?
  5. Feb 12, 2019 at 2:00 PM
    blizz86
    I had a fortin evo one installed .. that i just took out this morning. But all my wires that were cut have been respliced :l
  6. Feb 12, 2019 at 3:36 PM
    blizz86
    2016. From what I’ve read no fuses control it
  7. Feb 12, 2019 at 9:26 PM
    blizz86
    Checked fuse 27 and the rest while i was at it, all good. Switch is fine, already tried a new one. I ended up cancelling my extended warranty a year in lol. shiet. Any other ideas?
  8. Feb 13, 2019 at 6:57 AM
    blizz86
    Many thanks. I’ll start reading
    NewImprovedRon likes this.
  9. Feb 13, 2019 at 7:01 AM
    blizz86
    Any way I can see those 3 pages?
  10. May 28, 2019 at 6:58 AM
    blizz86
    I brought it to the dealership finally.. they did all the diagnostics @NewImprovedRon attached, eventually (after 2 days) the tech found an open ground somewhere and grounded the switch directly. My cruise control is now back. $250 for diagnostics and labor. I'm glad thats over with.
  11. Nov 17, 2020 at 1:19 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I just noticed that I have this same issue on my 2008. The cruise control switch seem to be totally inactive.
    In addition, the "VSC Off" and slip indicator dash lights came on when I started it up and drove to the gym this morning. When I started it to come home from the gym everything was fine. There were no drivability issues either time. The same thing happened several months ago, but it resolved when I turned off and restarted the truck.
    I did find a broken grounding strap that grounds the transfer case to the frame. I'll replace that tonight and see if anything changes.
    @blizz86 Just out of curiosity, did the Toyota Tech tell you where the open ground was?
  12. Nov 17, 2020 at 1:36 PM
    careyrob
    Carey
    Massachusetts
    @NewImprovedRon I just read all of the troubleshooting PDFs you attached. There's an awful lot of "Replace ECM" endpoints on those pages.:(
  13. Nov 17, 2020 at 6:54 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    @NewImprovedRon Hey Ron, where did you get the TIS info? Do you have a subscription? PM me if you like.
  14. Nov 18, 2020 at 8:29 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would like that very much. Since I left the dealership I no longer have access to Toyota info.
    Thank you
  15. Nov 18, 2020 at 12:16 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Got it, thanks. I have really bad internet because I live in a rural area so it's going to awhile until I can read it.
  16. Nov 18, 2020 at 4:05 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    No worries, there's never too much info.
  17. Apr 18, 2021 at 6:45 PM
    Astrosworld
    Astrosworld New Member
    Josh
    I have a 2013 tundra and my cruise control light isn't even coming on much less working any ideas what could be the problem ? Checked all the fuses all are good break pressure switch seems fine break lights not staying on ... Horn works ... Any help would be appreciated
  18. Apr 18, 2021 at 9:06 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your going to have to diag it using Techstream. Basically you need to look at the datastream and look to see if the switch is showing ON and OFF as you cycle the switch on and off.
  19. Apr 18, 2021 at 9:11 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Probably just the cruise control stalk, that's what went out in mine. Cheap and easy to swap out.
  20. Apr 19, 2021 at 11:46 AM
    Astrosworld
    Josh
    Yeah it's still not working went and got two other cruise control stalks and nothing light still now coming on or setting cruise... Anyone else have a suggestion on what it could be ?????
  21. Apr 19, 2021 at 12:27 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You need techstream to diag it properly or you could keep playing "poke and hope".
    Search "Techstream" for a copy and what you need for and obd interface.
    Astrosworld[QUOTED] likes this.
  22. Apr 20, 2021 at 2:23 PM
    Astrosworld
    Josh
    Ok So I took it to a mechanic and it threw a code p1604 and p1605 but I'm not having any issues of those type of codes The truck cranks fine runs fine I'm completely mind blown. Is there a way I can reset the whole computer system?
  23. Apr 20, 2021 at 5:50 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Startability code and rough idle codes. When's the last time you changed the plugs? How many miles on the truck? When certain codes are set Toyota stops other systems from being used for safety reasons. I bet if you cleared the codes the cruise will work until the codes come back.
  24. Apr 21, 2021 at 9:52 AM
    Astrosworld
    Josh
    Ok I'm going to try to have that done today then keep ya posted
  25. Apr 23, 2021 at 12:10 PM
    Astrosworld
    Josh
    $287 dollars later it was the clock spring even though the horn worked . Appreciate everyone's help
    JohnLakeman likes this.
  26. Apr 23, 2021 at 1:06 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Thanks for the update.
    I was following this thread, and suspected the clockspring was going to be your problem. I was reluctant to throw a $$$ dart for someone else, and the problem turn out to be something like a fuse. The "clockspring" is made of a flat ribbon cable that has multiple thin conductors. Any one of those conductors can fail, and all the others still continue to function just fine.
  27. Mar 14, 2024 at 3:49 PM
    Smitty_MTB
    Smitty_MTB New Member
    2010 Tundra
    Just wanted to add another vote for the clock spring which worked for me. Recently bought a 2010 Tundra in great shape but has a bunch of minor issues I've been trying to sort through with the help of this forum. I tried the switch first as it seemed quicker than the clock spring to fix but unfortunately no luck. My horn worked and no issue with air bag lights so I figured switch would be a good place to start. But then after reading a bunch more posts, saw a bunch of people saying their horn worked and it still ended up being the clock spring.
    Just got done replacing the clock spring today and got to see that beautiful cruise light, light up. lol. Was worried I'd need a steering wheel puller but did like a few I saw on YouTube do and give a couple healthy bumps to either side of the wheel and she popped right off. This forum is fantastic!
    Graeman likes this.
