Cruise control issues
Discussion in '3rd Gen Tundras (2022+)' started by Nomoredomestics, Jul 19, 2023.
  1. Jul 19, 2023 at 1:24 PM
    Nomoredomestics
    Nomoredomestics [OP] New Member
    GA
    2023 TRD Sport 4x4
    Anyone had any issues with the c.c.? I took mine in yesterday for its first service and told the service writer and he said he's never heard of any doing this and obviously couldn't find anything wrong.
    Only does it once per week or so but just stops maintaining speed. The dash will still say the cruise is still set but will just stop pulling. .it drops 7, 8ish mph and then starts pulling again and will get back up to speed. Doesn't even do it often enough for me to notice a pattern as far as uphill/downhill or anything else. Any ideas?
  2. Jul 19, 2023 at 1:31 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    I always set on the lowest. . And this happens with no vehicle in front of me. .
  3. Jul 19, 2023 at 1:38 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Negative. . Most of the time it's been on straight roads. The ONLY think I think MAY be consistent is that I seems to happen on slight inclines. . And I'm not truly sure about that. The last couple times were anyway. And I mean an ever so slight incline. Not enough of a hill to even put any strain on the engine.
  4. Jul 19, 2023 at 1:40 PM
    DFS
    DFS New Member
    2022 Capstone Tundra
    Does the truck downshift when it finally starts get back to set speed?
  5. Jul 19, 2023 at 1:41 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Doesn't seem to. Accelerates at a pretty good rate but no downshifting.
  6. Jul 19, 2023 at 1:46 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Not one. . And a calibration issue is the only possible thing I can think of. .
  7. Jul 19, 2023 at 2:29 PM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Does it do the same thing in regular cruise control mode?
    pwpblue likes this.
  8. Jul 19, 2023 at 2:33 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Honestly haven't tried that. Not a bad idea though
  9. Jul 19, 2023 at 2:42 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
    Eco mode?
  10. Jul 19, 2023 at 2:42 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    No. . Never even tried it. . Stays in normal
  11. Jul 19, 2023 at 2:50 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    so you set it to Normal each time after you initially start it? I always thought mine was in Normal D mode too - after checking it on the steering wheel controls I found it defaulted to the ECO mode after every initial start and not to the D Normal as it thought it should/would. ??
  12. Jul 19, 2023 at 2:55 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    I'm pretty sure mine doesn't do that. Mi e is always in normal. . Atleast I think???
