Critical overfillure?
Discussion in 'Performance and Tuning' started by EmergencyMaximum, Aug 7, 2023.
  1. Aug 7, 2023 at 9:21 AM
    EmergencyMaximum
    EmergencyMaximum [OP] New Member
    Overfilling oil, how bad is it, gang? I just changed oil on my venza the other day and it is sitting about 1/8" higher than max fill on the dipstick. Maybe even 3/16". Should I drain half a cup? The engine is 4cyl and takes about 4.5 quarts total.
    Also, how do you tell when vehicle is level, especially on pickups? Theres always rake(?) when front end is lower than rear end.
  2. Aug 7, 2023 at 9:27 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    When the ground isn’t level. Don’t over think it. Find level ground and check.
    Yes, I would dump some oil. If you don’t, you’ll think about it all the time.
    Install a Fumoto valve on the next oil change. That way if it ever happens again you just open the valve and run some out.
    EmergencyMaximum[OP] likes this.
  3. Aug 7, 2023 at 9:35 AM
    CTundraForMe
    CTundraForMe New Member
    Once upon a time, my brother double filled the oil on a car of mine.
    Think spyhunter smoke.
    The engine lasted about 24 hours...
