Crewmax rear window
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by NLTRDPro, Nov 9, 2020.
  1. Nov 9, 2020 at 4:13 AM
    NLTRDPro
    NLTRDPro [OP] New Member
    Robert
    2019 TRD Pro CM
    Hi, Do anyone else notice that if the rear window is not used in a while that it is hard to get to go down. I may have to push and hold the button several times. I feel that sooner or later the window will let go in the track. Is there anything i could spray the seals with to prevent this.
    Thanks
  2. Nov 9, 2020 at 4:23 AM
    timsp8
    NY
    I haven’t noticed this, but now I’m going to have to go check. I rarely use the rear window. You might be able to spray se rubber conditioner or something in the seal.
  3. Nov 9, 2020 at 6:27 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I leave mine halfway down quite a bit. But lately, if I’ve been parked under a tree, I wait until I get going and the leaves are done blowing out of the bed. Too many end up flying into the cab with the rear window down.
  4. Nov 9, 2020 at 6:31 AM
    I've not had this issue. :popcorn: for resolution.
  5. Nov 9, 2020 at 6:32 AM
    Kevfran99
    Kevfran99 New Member
    Kevin
    Lilburn, GA
    '19 TRD PRO
    TRD Rear Sway Bar - Front tint - Caliraised LED Fogs & Light Bar-Bed LEDs-Bed Cover-Wireless Charger
    This is typical. You need to use the windows every so often or the window motors will stick. I've ran into this a bunch in the used car market.
  6. Nov 9, 2020 at 6:35 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Used mine several times with no issues at all (knock on wood). Hope I didn't just jinx myself.
  7. Nov 9, 2020 at 7:22 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    In the winter mine is seldom used. I'll lower monthly at best. No issues... 2016
  8. Nov 9, 2020 at 7:49 AM
    Tundra21!
    Tundra21! New Member
    2021 VooDoo Blue Tundra
    Just sold my 08 and had no problems what so ever!
  9. Nov 9, 2020 at 11:33 AM
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    I haven’t experienced this but I need to use my sunroof more. I think I’ve opened it 2 times in a year and half.
