Crewmax Rear Space
Discussion in 'General Tundra Discussion' started by djallen, Mar 4, 2021.
  1. Mar 4, 2021 at 6:28 AM
    djallen
    djallen [OP] New Member
    Hi,
    New to the forum and am looking at new trucks. Need something larger than what I have now. I currently drive a 2013 Tacoma that seems to have shrank in the wash.
    I've searched but have been unable to find the answer to this question: with the rear seats folded up in a CM, how much horizontal distance is between the back of the front center console and the bottom of the folded up rear seats? Also, what is the vertical measurement from the floor to the window?
    I ask because I have an XL Ruffland dog kennel that I keep my dog in when in the cab. I had to remove the rear seats of my Tacoma and build a platform to get it it to fit. The two major downsides to this are: 1, obviously no rear seats; and, 2, the kennel sits up too high creating a blind spot in the right rear.
    I don't have easy access to a Tundra to measure so I'm hoping someone might be able to give some measurements so I have a better idea.
    The dimensions of the kennel are 41"L x 23"W x 31"H
    Thanks in advance for any help.
  2. Mar 6, 2021 at 12:47 PM
    grandmabetty
    grandmabetty New Member
    MN
    2021 Barcelona Red SX
    Looks like you haven't gotten a reply. I might recommend going to a dealer with your dog kennel and see if it fits. If you can find a dealer with a tundra that is
  3. Mar 6, 2021 at 2:07 PM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    I’d help you out if I had a third gen. The second gen CrewMax seats fold down. I’m sure someone with a 3rd gen CrewMax will chime in eventually.
  4. Mar 6, 2021 at 2:13 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Measured it for you:
  5. Mar 6, 2021 at 2:20 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    And I'll confirm for you. In a 2017 double cab (I just measured it) the 27" above is 24".
  6. Mar 6, 2021 at 3:19 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It might not be that secure there due to the floor being lower in front of the seats.
  7. Mar 8, 2021 at 4:18 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    This is true, but I fill the space with a couple folded tarps or something and then lay a dog bed over it.
  8. Mar 8, 2021 at 5:45 AM
    Rubberdown
    XL Ruffland won’t fit with the pass side seat down. If you have all the seats up it will. I wish the XL was about 4 inches shorter. That would be ideal.
    djallen[OP] likes this.
  9. Mar 8, 2021 at 6:27 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i have a giant pelican box that i use for my video production work. it measures 38.50 x 24.60 x 21.90. it fits with both seats folded up but the tricky part is the door. it takes a bit of sweet talking to get it squeezed in past the door and the rear of the center console. the corners tend to get hung up for me. also doesn't help that i'm usually manhandling it on my own.
  10. Mar 8, 2021 at 12:25 PM
    djallen
    I appreciate all the input! Thanks for taking the time.
  11. May 11, 2022 at 5:45 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Do you have a picture of this by chance ? I ordered this size for my 70lb malinois hoping it fits in my crew max.
