Crewmax Carpet Replacement?
Discussion in '2nd Gen Tundras (2007-2013)' started by rnavtom, Jun 4, 2023.
  1. Jun 4, 2023 at 3:46 PM
    rnavtom
    rnavtom [OP] New Member
    2011 Tundra Crewmax
    Howdy all,
    Anybody have the inside scoop on replacing the carpet (not floormats, actual carpet) in a 2nd gen crewmax?
    Everywhere I've looked online only has it available for regular cab or access cab, crewmax is out..
    There is a kit for 2014-2019 trucks with the split front/rear carpet, may end up ordering if the fit and finish is similar.
  2. Jun 4, 2023 at 3:58 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    You checked OC Auto Carpet?
  3. Jun 4, 2023 at 4:01 PM
    rnavtom
    2011 Tundra Crewmax
    I have checked OC Auto Carpet, they only list Double cab (Will not fit crewmax) on their site.
  4. Jun 4, 2023 at 4:05 PM
    Windsor
    Homeless in Oregon
    Some.
  5. Jun 4, 2023 at 4:09 PM
    rnavtom
    2011 Tundra Crewmax
    That's probably what I'll be buying. Hoping there aren't major differences.
  6. Jun 4, 2023 at 5:41 PM
    Ericsopa
    Ericsopa Old man and the sea
    Only difference I can imagine would be under the rear seat.
  7. Dec 11, 2023 at 12:42 PM
    jrh1010
    jrh1010 New Member
    Did you ever replace this carpet? I am figuring out which way to go now. I thought I might buy the carpet for an 07' double cab assuming the trucks were identical for the length of the carpet and I would just need a flat piece of cutpile for under the seat in the back (I'd be less concern about the look there). But if you did this and it worked, this would be preferable. Thanks.
  8. May 13, 2024 at 10:23 AM
    JP Tundra 2012
    JP Tundra 2012 New Member
    Hey guys, did you ever replace the carpet? I have a 2012 Tundra CrewMax and can't find carpet other than the dealer and it's way too much money. I was wondering if the 2014 Tundra carpet worked. I really only need to replace the rear carpet.
  9. May 13, 2024 at 1:19 PM
    jrh1010
    jrh1010 New Member
    I didnt. Planned on worrying about it in the next month. Been wearing on it to get hot.
  10. Jun 6, 2024 at 2:26 PM
    dylanschmarr
    dylanschmarr New Member
    dylan
    2013 White creamax
    6 inch procomp lift fox suspension 35x12.5 toyo open country a/t
    Any luck? I have a 2013 crew max that I need replacement carpets for and i’m wondering how and where to get them?
