CREDIT CARD ABUSE build
Discussion in '2nd Gen Builds (2007-2013)' started by zackbremer, Sep 3, 2017.
  1. Sep 3, 2017 at 5:23 AM
    zackbremer
    zackbremer [OP] New Member
    Da Z
    started as a used 2008 crewmax, originally with a used set of fox 2.5 non res coilovers, rear 2.5 piggybacks, and coach builder +3 shackles...wheels and tires were fuel trophies with 35in toyo RTs..my bumper was custom made by a local fab shop..i wanted it light but to be able to hold a winch, total weight with winch is 146lb.
    for offroad accessories, i have
    demello rock sliders
    custom aluminum skids
    smittybuilt x20 winch
    arb dual air comp
    dual battery system
    42in rigid RDS
    custom bed rack
    fire extinguisher
    hi lift
    900w inverter
    ARB 62qt fridge w/ custom housing.
    DECKED system
    old roomates matching FJhis is 6in procomp in 35s bfg KOs
    first T2S meet, @dragos in the background
    came over a ledge and OOOOPS crunched it into my quarter panel
    nothing beats snow wheelin
    i pulled the back panel off put aluminum bar as a support bracket on the back side and bolted everything in place, hes held up grate, no rattles
    then i made the mistake of going to anza borrego with alex and a few other members here and the go fast bug really sunk his hooks into me...i smell and upgrade from these fox shocks
    BOOOOOM SEXY BLUE
    front king 2.5 rem res CO, king 2.5 triple bypass(TC spec valving), king 2.0 hydro bump, chopping the stock bumps off gave us about 2inches more of uptravel. total travel is 12.5 with no CV binding. i have limit straps on now that are not in the pictures
    20170705_133024.jpg 20170705_133040.jpg 20170728_083554.jpg 20170728_083605.jpg
    the rear has camburgs shock mount relocation kit...weld on lower mounts, bolt on upper mounts..puts both sides upper mounts in front of the axle. im also running deavers with 500lb of preload build it and king 2.0 hydrobumps...total travel is 14inches..again limit straps not shown
    20170802_084357.jpg 20170802_092617.jpg 20170802_092654.jpg 20170803_151104.jpg 20170803_151137.jpg
    flexxin on dem hoes
    the go fast life causes a lot of bed flex and the bed flex slowly started to tear away at my decked system..i have nothing but good things to say about that system and that company but it was not meant for high speed desert runs. i sold it to a member for cheap and had my self a bed rack built for my RTT. for RTT i went with the tuffstuff ranger, it came with the annex room which i wanted for my dog, and it was one of the lightest 127lb and cheapest 1200$ no pics of it mounted yet, its to hot to camp in az
    AZ tundras run great turn out, people here really like to wheel
    well the go fast life got me, hit some rock, had some blowouts, went sliding down an embankment, smashed up my front fender and pass door, truck almost rolled...had to winch out threw bushes and over rocks...it was a fun one...truck made it out mechanically fine but needs some body work and of course...bigger tires
    mmmm went with the toyo rt 37x12.5r17 with some kmc wheels
    20170901_063731.jpg 20170901_154021.jpg 20170901_154029.jpg 20170901_162307.jpg 20170901_162529.jpg Resized_20170901_160323.jpg
    and my partner in crime who always rides with 8 month old brady, cane corso
  2. Sep 3, 2017 at 5:31 AM
    zackbremer
    Da Z
    some pics of the decked and fridge
    glamis sand dunes
    towing my buddies chevy up to crownking after smoking the drive shaft
    and my bumper being built on my first truck
  3. Sep 3, 2017 at 5:55 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    how do you like the bypass shocks on the mid travel? Big difference from what you had before? I'm ready to pull the trigger as soon as MCM has a kit for sale.
    I'm digging that fridge mount too!!
  4. Sep 3, 2017 at 5:59 AM
    zackbremer
    Da Z
    yah huuuuuge difference..the reason i went with king, other than knowing i liked them from my previous truck was they made everything i wanted so i did have a frankenstien truck..if ADS had midtravel bypasses i would have used his k37spec triple bypassess in the rear and not done the camburg kit.
    if you go look at travel numbers the MT on tundra is quite impressive 4x4 silverados get 14in up front, and tacomas get 12-14...with proper valving this thing will fly..i def need to do some more fine tuning but so far i am really really happy with the performance
    and yes removing that jump seat as a spot for the fridge and to access my other offroad gear easier has been a great decision..one it unbolts in under 2 mins if i wanna throw the seat back in, the dog has room and it stays really secure.
    Tacotundra and PermaFrostTRD like this.
  5. Sep 3, 2017 at 9:21 AM
  6. Sep 7, 2017 at 10:24 AM
    FJ4 Tahoe
    FJ4 Tahoe New Member
    2012 Tundra SR5
    3." King lift with much much more to come
    Would you mind sharing your dual battery setup? I am looking into adding 1....thanks
  7. Sep 11, 2017 at 4:32 PM
    JBSTOY
    JBSTOY Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
    I really dig that front bumper you built.
    Silverghost likes this.
  8. Sep 11, 2017 at 5:13 PM
  9. Sep 11, 2017 at 5:22 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Thats what up! Real nice setup man!
  10. Sep 11, 2017 at 6:39 PM
    TheBeast The Beach
    very very nice ! I like the suspension setup and the front bumper.
    how did the R/T perform in the snow ?
  11. Sep 12, 2017 at 12:09 AM
    zackbremer
    Da Z
    RT was great, put it in 4 hi and let the toyota trac control do its thing
  12. Sep 12, 2017 at 12:11 AM
    zackbremer
    Da Z
    yeah it came out really nice and waaaaaay cheaper than anything online (850$) i recommend anyone looking for a bumper just google a local fab shop in their area and go that route.
    Air2Ground likes this.
  13. Sep 12, 2017 at 12:17 AM
    zackbremer
    Da Z
    here is the dual battery isolater kit i went with
    https://www.amazon.com/Painless-401...5200338&sr=1-2&keywords=painless+dual+battery
    this is the battery i used..i actually fit it in the center console..fits perfect, no room to move around and i still fit gloves winch controller and a few other things next to it...i drilled a hole in the bottom of the center console and ran the wires out the bottom.
    https://www.vmaxtanks.com/MR127-100-Deep-Cycle-High-Performance-AGM-Battery_p_24.html
    i used a blue sea 12 circuit with cover an neg
    https://www.amazon.com/Blue-Systems-Blade-Fuse-Blocks/dp/B00WM2MWQ4?th=1
    and one of these bad boys running to the circuit
    https://www.amazon.com/InstallGear-...8&qid=1505200571&sr=8-5&keywords=100+amp+fuse
  14. Sep 12, 2017 at 4:46 AM
    JBSTOY
    Jack
    Unknown Origen
    Did you use a local fab shop or did you make yours? Thanks
  15. Sep 12, 2017 at 5:13 AM
    zackbremer
    Da Z
    i used a local shop called "bent fab" out of phoenix arizonA
  16. Sep 12, 2017 at 7:32 AM
    JBSTOY
    Jack
    Unknown Origen
    That's cool.
  17. Sep 12, 2017 at 8:14 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Love the build!
    That rear Camburg relocation is a nice setup. Would I have to call to order that? It's not listed on the site.
    Eclipsed & Floating likes this.
  18. Sep 12, 2017 at 8:41 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Do you like that setup instead of full long travel? I wanted LT but it's expensive and tundras are big and wide. I'm thinking add a 2.5 bypass to pair with my kings up front and a stock length bypass for the rear. Badass truck by the way.
    TheBeast and dcsleeper408 like this.
  19. Sep 12, 2017 at 9:58 PM
    zackbremer
    Da Z
    yeah they are really slow on updating their website, if you call them they have em ready to go...it is a fairly labor intensive install as you have to cycle the rear suspension to get the shock angle and mounting points correct.
    dcsleeper408[QUOTED] likes this.
  20. Sep 12, 2017 at 9:59 PM
    zackbremer
    Da Z
    check out the facebook group "arizona TUNDRAS GROUP" WE post a lot of meets on there
    Chefjjdecker[QUOTED] likes this.
  21. Sep 12, 2017 at 10:05 PM
    zackbremer
    Da Z
    its not as good as full LT but its about half the cost maybe less and will still romp in the desert. with the right valving and a little tuning youd be surprised what you can do. i added the king secondary bypasses(Stock LCA) up front and didnt want to Frankenstein my truck by doing the ads triple bypass in the rear. i know several people who run deavers with the spec length ads rear triple bypass and have no complaints. if money is more of a factor this is the route i would take over stock length kings in the rear.
    leaf springs are the most important and all the desert race guys say the rear should be about 1.5x the travel of the front so the more travel you can get in the rear the better
  22. Sep 13, 2017 at 8:14 PM
    JBSTOY
    Jack
    Unknown Origen
    You might want to reach out to @KevinK. He is a great guy. He might be on a run right now. @KevinK can you help out sir?
  23. Sep 22, 2017 at 7:42 AM
    Silveraptor
    Silveraptor New Member
    Aaron
    2011 Red Crew
    In Progress
    This is a nice build! And I like that you're out there actually using it and not afraid of some dents lol I ordered the same rear set up but with Fox shocks. Only because I'm doing the Camburg LT kit up front and they said they designed it around the Fox shocks. Are the Kings better than Fox at the same level? How did you learn how to do the relocation kit install? Camburg says there are no instructions lol Do you have any tips or pointers for me? @zackbremer
  24. Sep 24, 2017 at 12:24 AM
    zackbremer
    Da Z
    well bad news after about 10 hours total the upper mounts have broken. completely cracked on the top and bottom of the upper mount on the drivers side and starting to bend on the pass side. the lower mounts are still fine. the design was poorly executed. the mount bracket that comes off the flat bracket(which bolts to frame) is only spot welded instead of having a solid bead on both sides. and the force of the shock moving up and forward when compressing is way to much for this to handle....this kit seems to be geared towards people who want to run bypasses but not really use them.
    thankfully i check my mounts and torque specs on my bolts after each dirt trip or this could have been really bad had it finished breaking on the trail. i have reached out to camburg but have not heard anything yet(dont expect to until monday) again this was after less then 10 hours of dirt time, several of which were pretty gentile as i was breaking everything in and expected stuff to loosen and move. i bottomed the rear twice at various times but i have bump stops so it was not harsh by any means.
    camburg originally told me the design would fit any 12in bypass, but clearly it was designed around fox as my kings require a lil grinding on the bracket to get them to fit. if you plan to do dirt roads and camp this set up will be fine. if you plan to really hit the dirt and hit some whoops i would recommend reinforcing it. or returning it and doing something custom.
    i had a local fabrication shop do my install as it is pretty labor intensive, you need to strip the leaf pack and cycle the suspension to find the correct shock angle and make sure your bump zone is right. it require welding of the lower shock mounts and cutting and bolting of the upper shock mounts. my fab guy is going to runa shock hoop under the bed from one upper shock mount to the other and weld a support gusset to the frame and get rid of these upper mounts all together. the design was lazy and not well thought out. atleast not for people who intend to really use their bypasses.
    disappointed
  25. Sep 24, 2017 at 12:30 AM
    zackbremer
    Da Z
    edit: its not letting me attach the other pics ill try again later
    dcsleeper408 likes this.
  26. Sep 24, 2017 at 1:53 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    Wow Zack, sorry to hear about the Camburg kit. It’ll be interesting to see what Camburg has to say. They make some quality gear so I’d expect that they’d try to take care of you somehow.
    Luckily the failure didn’t leave you stranded somewhere, or worse.
    TRD15559 and zackbremer[OP] like this.
  27. Sep 24, 2017 at 9:53 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    This is the first I've come across you build. Nice truck and hope you get the shock mount situation resolved. Keep us posted on your progress :thumbsup:
  28. Sep 24, 2017 at 8:49 PM
    zackbremer
    Da Z
  29. Sep 26, 2017 at 8:18 AM
    Silveraptor
    Aaron
    2011 Red Crew
    In Progress
    Man sorry to hear that. I was excited to see your build as the rear is exactly what I was planning on doing. I already ordered the Deaver U748 and the Camburg stuff. I guess I'll be returning the mounts and going with shocks that fit my stock mounts... Less work that way and more reliable. The rear won't keep up with the front now though unfortunately. Is there a chance the local fab shop installed them in a way that added to the stress that broke them?
  30. Sep 26, 2017 at 10:31 AM
    motoxscott
    motoxscott New Member
    Scott
    Hurricane, UT
    2017 Tundra
    Camburg - FOX - Method - General Tire - Deaver - Rigid
    Hey Zack .... Scott @ Camburg here. Few things I want to hit on ....
    1) I checked with everyone here and checked all our incoming emails .... everyone is in the dark on this. Who did you reach out to and how? This is the first we've heard or seen about this.
    2) Our shock mount was designed around a FOX 2.5 and 3.0 bypass shock with a specific extended and collapsed length along with a custom bypass tube layout. I don't know how your Kings compare and could be part of the problem.
    3) Who's bumpstop mount kit is that and what was it designed around? Bumpstop mounts are very specific, hence why we have different versions based on the parts they're being used with.
    Looking at the few pics you've posted it looks like the bypass shock is bottoming out completely and that's going to put all the load into the shock mount. You need 1/2" min. of shock shaft exposed when everything is bottomed out metal on metal. If parts arent installed 100% correctly, issues can and will arise, especially offroad. Looks like you're missing a bolt in the shock mount attaching it to the frame, not life or death, but it's not 100% installed and can allow the part to flex, metal cracks when it flexs.
    To give you guys some insight on these mounts. We have these on our own Tundra with over 10,000 miles on them with zero issues and it's used hard offroad often and beat up for photo shoots in glamis, moab, etc. We have over 400 of these on military Tundras overseas with zero issues. Common denominator is they are all using the exact parts we spec out to be used. No short cuts we made on these mounts and it's a solid design. Certain things aren't 100% welded that don't need to be. The additional unneeded welding would end up warping the part for the amount of heat put into it. We spend countless hours designing parts and do everything for a reason and make many revisions prior to producing something. We don't just throw something together even with over 20 years experience doing this.
    I'll be putting these on my own truck shortly, with the FOX shocks we designed for them with no concern for the design being an issue.
    Give me a call at the shop so we can troubleshoot this issue for you or send me an email scott@camburg.com to start the process.
    We're always down to work with customers and address issues, just have to give us the opportunity. We'd much rather work through your problem then randomly stumble upon it online.
    - Scott @ Camburg
