Creaking sound
Discussion in 'Suspension' started by Jebell4747, Mar 9, 2019.
  1. Mar 9, 2019 at 3:26 PM
    Jebell4747
    Jebell4747 [OP] New Member
    2018 Tundra TSS
    Anyone else have a creaking sound after their lift? The new a arm bushings were greased really good so I doubt that’s it.
  2. Mar 9, 2019 at 7:10 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    What size of lift do you have?
  3. Mar 10, 2019 at 3:57 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    What did you have installed
  4. Mar 10, 2019 at 5:35 AM
    Jebell4747
    2018 Tundra TSS
    3.5” lift.
  5. Mar 10, 2019 at 5:38 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Yes but how? Coilovers or spacers? UCA’s installed? Pictures would help someone with a trained eye see something not installed correctly.
    TheBeast and 15whtrd like this.
  6. Mar 10, 2019 at 5:50 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    What kind? What parts? Need more information to help you out.
    That’s like bringing your vehicle to a mechanic and saying it’s making a noise, dropping the keys on the counter and walking out lol.
  7. Mar 10, 2019 at 6:33 AM
    Jebell4747
    2018 Tundra TSS
    Lol sorry guys. It’s a 3.5” rough country ( coil spacer/diff drop) with SPC arms. It did it before the arms and after. I’ve read some say it’s the skid plate but I don’t see anything hitting it
  8. Mar 10, 2019 at 6:42 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Did you check that everything is torqued correctly?
  9. Mar 10, 2019 at 6:54 AM
    Jebell4747
    2018 Tundra TSS
    I had a shop do it. Should I recheck behind them?
    TheBeast likes this.
  10. Mar 10, 2019 at 7:00 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Check the front sway bar. Make sure it’s seated properly. Does it do it all the time? Or when turning?
  11. Mar 10, 2019 at 7:15 AM
    Jebell4747
    2018 Tundra TSS
    I haven’t noticed it as much turning as I do when I’m just easing along through a parking lot hitting small bumps. It seems to be more noticeable then. Maybe less than 5 MPH.
  12. Mar 10, 2019 at 7:18 AM
    Jebell4747
    2018 Tundra TSS
    I’m about to head out and recheck all the bolts again
  13. Mar 10, 2019 at 9:31 AM
    Jebell4747
    2018 Tundra TSS
    I have a good video with the sound but I guess I can’t uoload it off my iPhone . It really doesn’t happen turning, it happens when I hit a bump. I did notice there is a rubber piece between the spring and the spacer. Shouldn’t that be between the spacer and where it mounts to the body?
  14. Mar 10, 2019 at 9:40 AM
    15whtrd
    15whtrd Mr. Blonde
    My stock front CO creaked. I sprayed lube on all mounting points and found mine was creaking from the upper mount. I could replicate it by standing on the passenger door threshold and bouncing the truck. The lube was temporary. Swapped in some lifted coil overs, problem solved. Once I found out the initial squeak wasn’t anything detrimental to the truck. I got past it. When it went away it was just a bonus LOL.
  15. Mar 10, 2019 at 10:09 AM
    Jebell4747
    2018 Tundra TSS
    I’m saving up from my coilovers lol. I can’t replicate this by bouncing
    15whtrd[QUOTED] likes this.
  16. Mar 11, 2019 at 12:37 PM
    Jebell4747
    2018 Tundra TSS
    Was informed today that either the sway bar is loose or the alignment is not correct. I know the bar is tight and I know I’ve had my doubts in the alignment for a few weeks
  17. Mar 11, 2019 at 1:52 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Did they tighten all the hardware with it suspended in the air or at ride height?
  18. Mar 11, 2019 at 2:41 PM
    Jebell4747
    2018 Tundra TSS
    That I don’t know
  19. Mar 11, 2019 at 2:48 PM
    TheBeast The Beach
    yes !! lol
  20. Mar 11, 2019 at 5:17 PM
    Jebell4747
    2018 Tundra TSS
    In the way home from work it started getting even more noticeable. The sound was really bad from the right, I jerked my wheel the the left, heard a pop and seems to be ok. I’m thinking 100% sway bar
  21. Mar 12, 2019 at 3:52 AM
    Jebell4747
    2018 Tundra TSS
    I don’t have RC control arms. I ditched them for SPC’s.lol But lift has been in for about 3 weeks.
  22. Mar 12, 2019 at 4:58 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Make sure they grease the ball joints fully and used the grease packs on the bushings when they installed them.
  23. Mar 12, 2019 at 7:42 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The skid plate noise is common and it's caused by the skid plate rubbing against the mounting points as the chassis flexes. I'm not sure the problem can be fixed by simply tightening the fasteners tighter. The lift wouldn't necessarily cause the noise, but removal/re-install for the lift could. The fix is to remove the skid plate and re-install with insulating washers between skid plate and mounting points. Material for the insulation washers is left to the owner's imagination, but they need to be waterproof and rustproof.
  24. Mar 12, 2019 at 9:58 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    A lot of people overlook greasing the SPC Bushings. I would bring it back to the shop and make sure they greased the bushings, also another thing that a lot of shops do is torque the upper control arm while its still in the air. That is not good, always do your final torque on the upper control arm "through bolt" while sitting at static ride height.
    15whtrd and JohnLakeman like this.
  25. Mar 12, 2019 at 9:59 AM
    Jebell4747
    2018 Tundra TSS
    I’m saving up for some
    Coilovers myself . RC told me either it’s the sway bar or the alignment. Also it did it with the RC control arms to. I’m going to remove the skid plate entirely and try that. The sounds is mire toward the passenger side. But I really appreciate they help!! Lots of things to try! I’ll keep y’all updated
  26. Mar 12, 2019 at 10:00 AM
    Jebell4747
    2018 Tundra TSS
    Can I losen the arms on the ground and retorque?
  27. Mar 12, 2019 at 10:14 AM
    Toytec Lifts
    Denver, CO.
    I would honestly recommend at least jacking the front end up a little bit to help "relieve" the bind that could be happening, loosen, set on ground, and then torque.
    Twinky and 15whtrd like this.
  28. Mar 12, 2019 at 11:03 AM
    JohnLakeman
    Good advice by @Toytec Lifts to jack it up before loosening.
    When you tighten the control arm bushings with the truck in the air, it locks the bushing relative to the control arm at it's lowest position...then, when you let the truck down, the rubber part of the bushing is constantly in a "pre-torqued" condition. When you jack it up before loosening, the bushing will (hopefully) return to it's original unstressed position. THEN loosen the bolt, let it down, and retorque.
  29. Mar 14, 2019 at 6:34 AM
    Jebell4747
    2018 Tundra TSS
    Thanks guys I’ll try that this weekend, I noticed it’s mainly the passenger side when turning left. I don’t see any thing hitting but I’m getting real in-depth checking this weekend
  30. Mar 14, 2019 at 11:45 AM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    I know that Total Chaos states in their install manual that you may get some squeaks from their UCA even if lubed and torqued correctly. I think its just a part of having poly bushings I guess.
    I'll just keep the windows closed, AC on, and music turned up loud. Either way I can't hear that well anymore so....:D
