Creaking from front right tire
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Kevinpintz, May 1, 2021.
  1. May 1, 2021 at 5:34 PM
    Kevinpintz
    Kevinpintz [OP] New Member
    2021 tundra trd pro crewmax
    Hey everyone,
    I have a 2021 trd pro and work in southeast NM.
    The other day I started to hear a creaking sound from the front right tire. I removed a rock from near the dust guard and used a air compressor to spray out the rotor and brake area. After that, I drove it and there is still a consistent creaking coming from the front right side. It is consistent with tire rotation and gets faster with acceleration. The sound does not increase when turning or when stopped.
    I looked under the truck and everything is tight (heat shields, drive shaft, etc).
    Y'all have any ideas?
    https://youtube.com/shorts/qoz5DXRp2ZM?feature=share
  2. May 2, 2021 at 8:16 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Maybe the dust shield behind the rotor is bent?
  3. May 3, 2021 at 5:39 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    2021? Let the dealer figure it out.
    If it's too far to a dealer, jack the front wheel just off the ground, place a jack stand, and slowly turn the wheel to reproduce the "creak". Eye-ball all rotating components and points of stationary interface to see where in the wheel rotation the noise is occuring. Then, closely inspect the area to identify exactly where/when/what is causing the noise. Exactly what the technician would do.
  4. May 3, 2021 at 6:21 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Yep, get that corner off the ground and give the wheel/tire a good spin. Will be easy to pinpoint when you’re eyeball to eyeball with it.
  5. May 3, 2021 at 6:36 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Make sure your wheel nuts are correctly torqued, and get it to your dealer unless it’s been modified.
